View Full Version : '96-'00 Civic
Pages : 1 2 3 4 5 6 7 [8] 9
  1. regarding a new gauge cluster...
  2. CC/header questions..
  3. knocking/thumping noise
  4. security / keyless entry problem
  5. Greddy exh. vs. Apexi exh.
  6. Cyl' Head Temp' Sender into D16 ?
  7. Noob question about stock bumbers
  8. CD Player installation
  9. will 4th gen shocks and springs fit a 6th gen
  10. vtec or not
  11. 2000 acura 1.6 power lock motor
  12. After-market AC install in Civic?
  13. help 1st piston is out
  14. Poor mans scan tool
  15. clutch
  16. Clutch install
  17. speakers
  18. many NooB questions, please help....
  19. Ring compressor
  20. 00 civic pic's
  21. After gauge install...
  22. how would i piece together a turbo kit
  23. just got a 98 civic
  24. Poor acceleration/hesitation HELP PLEASE
  25. Gotta Go Jdm Big Diff. Ecu Help?
  26. Heat/Defrost '96 Civic EX
  27. Header/cat
  28. SRS light on.
  29. help on engine swap
  30. Sponsorships
  31. Car will turn over, but no fuel help!
  32. Drive conversions...
  33. Cheap horsepower...
  34. ecu tuning?
  35. !!! WTF is "V-Tec 20"
  36. Which Exhaust?
  37. Question about engine wear, shifting, and the throttle body
  38. I have a 00 civic dx hlp cnt find!!!!
  39. Fuel Consumption in Civic RTi
  40. B20 in a 99 Civic DX
  41. B18c1 In Cixic Lx
  42. EXACT specs required
  43. trans. shuddering
  44. correct tire profile
  45. she got some balls or what?
  46. Washer Fuild Light???
  47. switching teams
  48. converting my d16
  49. LBS. of torque?
  50. shift improver for honda
  51. what do you think
  52. Gas help
  53. what to do with a b16a2
  54. Yellowing euro taillights???HELP!!
  55. help!!!!!!
  56. How to change Fuel Filter
  57. license plate led
  58. Hood release cable
  59. i have read nonsense before
  60. 98 ex still having idle problems
  61. Air Conditioning Problems w/ 00 Civic
  62. 97 ex with sohc v-tech zc won't run
  63. Ex Trasmission on Civic Dx
  64. 99-00 SI Brake Question
  65. Slight knocking sound for first few minutes driving
  66. Tailight Modification Question
  67. Climate control/radio bezel electrical
  68. my clutch problem
  69. vibrations...mounts?
  70. Stupid Questions...
  71. b16a2 how much boost?
  72. 99 civic accel. problems...
  73. JDM motor in my 97
  74. Intake manifold for d16y7
  75. 99 civic rear discs
  76. 99 civic lx header..
  77. 98 civic ex vs 97 accord ex
  78. Pulleys
  79. 99 civic ?
  80. Guess what?
  81. crazy idle problem
  82. 6th Gen Photos
  83. moderators... can i ask a favor?
  84. Got an extra $1750?? Acura RSX anyone?
  85. Front Speakers wire color
  86. Which engine?
  87. magnaflow vs apexi 1?
  88. Looking Good, but What to do now?? (lots of pics)
  89. Code P0135
  90. distrubitor
  91. Need some help with boost options.
  92. SRS Airbag Light on
  93. damage after throttle body cleaned?
  94. 98 EX stalling intermittently
  95. civic coupe and hatchback
  96. Oem
  97. Putting a Grant steering wheel on a 99
  98. another misfire detected?
  99. designing exhaust...muffler inlet size
  100. 2000 Civic SE noise when disengaging clutch
  101. engine knocking sound at cold start
  102. Heat
  103. 99 civic completly dead
  104. h22 help
  105. Quick question about honda performance?
  106. New CV boots...
  107. Question about throwout bearings...
  108. Check Engine light after header swap...
  109. 98 Honda Civic HX - check engine light
  110. Auto to Manual Swap: Cost, Parts needed
  111. What is an EK, EK3 , EG etc.....
  112. RPM drop badly when aircon is on
  113. b16 alt.
  114. fender wheel molding...
  115. window won't go up all the way
  116. what mods should i do . just got 99civic
  117. Looking for some 00 Civic Floormats
  118. CAT Question....
  119. Tranny Bearing Replacement?
  120. What is the best brand of Air Intake for a 00 Civic?
  121. Check Engine Light Came On When....
  122. can someone explain this code to me?
  123. everything looks good(i think)(pics inside)
  124. 00 Civic DOHC - Integra-R Engine swap
  125. Wanting to build turbo system, no kit!
  126. exhaust help
  127. code 90, leak in the gas tank????
  128. Is ex exhaust the same as lx?
  129. FORUM RULES AND GUIDELINES - MUST READ!!!
  130. Does having a civic lx 99 suck or can i do stuff with it?
  131. buying headers w/ down pipe??
  132. SRS alarm light "On" in Honda Civic
  133. Need a question answered
  134. K24 Swap
  135. idle problem
  136. 1996 Honda Civic DX
  137. Tach jumping and engine stalling.
  138. check engine light on agian misfire???????
  139. Please post any pics of rear suicide doors!!!
  140. trunk dimensions PLEASE!
  141. Noise from crank/pulley??
  142. New Part. Like sex(for the car)pics
  143. 97 Civic EX Coupe for sale
  144. CAI vs. Short Ram
  145. ignition won't acknowledge key removal - '97 Civic
  146. Car became a gas hog
  147. Where can I buy brakes for my 96 lx
  148. CVT tranny Issues (I think it's Electrical)
  149. 96-98 to 99-00
  150. build up or swap?
  151. 00' Civic FUSE BOX Panel Diagram - Please HELP
  152. Does cat converter really make a difference?
  153. Exhaust question
  154. problem with 96 civic
  155. Cut Vtec Signal Wire!!!!
  156. je pistons, computer programming?
  157. OH no check engine light
  158. i hate snow
  159. 700 dollars... help me shop.
  160. 96 Civic Removing rear speakers?
  161. Removing silencer
  162. aem v2
  163. apexi vafc 11
  164. I'm new to imports...
  165. what kind of power is needed?
  166. si supercar
  167. compatibility question
  168. aem v2 installation
  169. viper alarm?
  170. civic bearings
  171. 1997 Civic--Malfunction Indicator Light On
  172. little bit of a problem
  173. holy $#!t is it cold
  174. wheel shopping
  175. alternator + lubricant = good idea?
  176. CD Changer with 96 honda civic LX
  177. Brakes and questions
  178. want to trade 98 coupe for 96+ hb
  179. Aem V2
  180. Header for a Civic CX Hatch 1997
  181. 2000 - S2000 Suspition
  182. trim choice
  183. Off topic thread
  184. Stalling 96 Civic hatch
  185. 00 D16Y7 sudden loss of power...
  186. misfire detected again???
  187. sparks plugs and wires
  188. 98 civic dx problems
  189. S2K/rsk s pedals in a civic(96-00)
  190. P0135 code
  191. Civic Drum Brake Conversion
  192. spoiler Q+A
  193. Cam Question.
  194. How can I turn my parking lots off with headlights on?
  195. misfire detected?????
  196. rattling hood
  197. transmission flush
  198. power mirrors
  199. To the mod's
  200. To the Supreme Champion who suspended me
  201. girlfriend got me a christmas present
  202. anyone in southeast michigan?
  203. Cat converter o2 sensor problems
  204. Civic Signature
  205. if i only cought them
  206. Code p0131 p0132
  207. Installing new wiper motor
  208. Water / coolant sprayed in engine
  209. Some mod questions
  210. Need a stock airbox for a 96 DX
  211. 98 Civic EX coupe opinions please
  212. Block heater
  213. CAI in the winter
  214. greddy turbo kits
  215. What to do first??
  216. Is this normal?
  217. cylinder mess up
  218. 97 civic hx?? low idling
  219. 1998 Civic EX Air Bags
  220. 99 Si parts
  221. 99 civic 4 door- fcc #'s on back of remote
  222. Car's broke
  223. how to install a CAI ??? HELP
  224. how to install a CAI ??? HELP
  225. need some opinions on my 2000 civic si
  226. free laptop
  227. new Headers throwing a code
  228. gauges
  229. air intake/fuel system
  230. civic 92-95 and 96-00 comparison
  231. Engine Trouble
  232. Help! My civic is hesitating while driving
  233. Removing civic rear seat
  234. motor options
  235. Body Kit Questions
  236. Classified section is back. Sell, trade, or buy your items here.
  237. Cheap speed
  238. rear sway bar help
  239. Lowering Question
  240. Rs type vtec controller.... help!
  241. looking for d16 power
  242. Blew up my d16
  243. When is your civic considered a "ricer"?
  244. Electrical Problem
  245. obd1 distributor and obd2 distributor
  246. Looking for Civic Gauges In Kanji
  247. If you could..would you do it all over again?!
  248. Looky
  249. o2 sensor
  250. Cold Air intake/hydrolock
