View Full Version : '96-'00 Civic
Pages : 1 2 3 [4] 5 6 7 8 9
  1. oscillating revs
  2. 2000 civic need help w/ dash lights
  3. A/C troubleshooting help....
  4. Dizzy A/C
  5. tool question
  6. 2000 civic 1.6 ID/PCM ?
  7. SRS light on my 98 Civic
  8. WTB stock springs for 1996 civic
  9. ECU Wiring harness
  10. Different Intake Systems..
  11. help my 96 wont start
  12. Wiring Harness 4 Sale!
  13. best type of headers 4 a N.A. single cam
  14. Splicing wires for wire harness
  15. Parts in Arizona?
  16. A/C Idle Up Not Working
  17. squeeling belt on 96 civic
  18. Engine light with rough idle
  19. loud sound when driving my car ? help please!
  20. tire psi for 17inchers
  21. srs
  22. 96 Civics Installing new radio
  23. 96 Civic Ex
  24. help Civic Ex 95'
  25. 99 lx stock exaust manifold
  26. Window Regulator Down for the Count
  27. help with spark plug torque spec
  28. Need MAJOR advice- hydrolocked my d16y7 and now ready to swap on a budget
  29. 98 Honda Civic - SRS Light
  30. transmission swap
  31. air conditioning noise
  32. 1.6 Vtec To 1.6 Non Vtec Swap
  33. gas milage
  34. need to know about engine mounts
  35. can't accelerate sometimes past 4000 RPM
  36. VSS Help
  37. leaking water from rear of engine compartment?
  38. hi guys i have a question that i want to ask!!
  39. 97 civic has p1298 fuel air mixture code
  40. new car
  41. obd 2 smog check problems
  42. where could i find the ecu fuse to see if it's blown?
  43. Any Civic owners in PA ??
  44. SRS light
  45. d17 question
  46. what halo lights are best?
  47. i have a 1997 honda civic
  48. will this work/ doors
  49. Help with 96 Civic EX
  50. 97 rear lower control arm bushing...
  51. Speedo Problems
  52. APC Seat install
  53. rebuilt title
  54. 96 Civic dash cluster swap
  55. mil/check engine light test failure? smog check experts?
  56. sometimes the turn signal buzzes and doesn't work
  57. 2000 si 2 problems
  58. selling 96 civic in south florida
  59. what do you think?
  60. 98 civic lx transmission dipstick loose?
  61. Sounds like a Lawn Mower...
  62. Direct Replacement Cat for '99 EX
  63. Interior Colour
  64. exhaust
  65. header
  66. '00 Civic EX Check Engine Light
  67. Civic hatchback DX power doors
  68. MexSiR Pictures (99 Si Ebp)
  69. 99 Civic LX 4 Door "REAR DOORS WILL NOT UNLOCK" HELP!!!!!!!!
  70. 1997 Honda Civic DX
  71. Bulbs for JDM Type-R headlights
  72. help please on a swap problem
  73. Help!
  74. 97 Civic EX SRS light on
  75. 2000 Civic EX Caliper Issue
  76. 96 civic - 00 si front end conversion
  77. Engine rev fluctuates
  78. wireing
  79. MAP sensor question...
  80. High Flow Cat Question
  81. 99 Civic Si HELP!!!
  82. lowering civic hatchback
  83. so confused?!?!?!?1
  84. 97 Civic EX Idleing High (Idle Screw Question)
  85. eyebrow and headlights
  86. need help asap, what's wrong with my idle?
  87. 96 civic hatchback rear brake conversion
  88. To Rice or Not to Rice
  89. So im new
  90. CD Player always starts at track 1
  91. 97 Civic HX Dual Exahst
  92. fuse box layout
  93. engine code 0420 in 96 civic dx
  94. What Blow Off Valve?
  95. 97 hx electrical malfunction...
  96. The Final word on keyless remote
  97. Mudflap differences
  98. 98 civic hx cvt transmission problem surges when cold
  99. 00 Si Bumper Fit 96 Civic EX???
  100. Is $2k good for B18C1 Full Swap?
  101. 97' Civic EX - Engine Quit
  102. 97 Civic Cx (Type R)B18C5
  103. Buying a new car - wut should i get?
  104. piston help!!!
  105. 95 acura integra gs-r motor swap into a 2000 honda civic coupe
  106. Civic SI lip and jdm Civic type R difference?
  107. Ehlp
  108. 97 civic black smoke?
  109. XM radio on 97 civic anyone?
  110. 00 civic low idle
  111. New MexSiR (PICS)
  112. 96 civic DX hatchback Power Steering
  113. Short Ram intake with odd problem
  114. new alarm installed but doesn't activate when door opens!!!
  115. Rear main seal leak on 2000 DX with 77K.
  116. 96 Civic Cluster
  117. OIL PRESSURE ON STOCK civic 98
  118. 96 civic suspension problems
  119. 98 civic window ?/ whats the cables
  120. just 6 questions
  121. K20A Type 'iS' Long Block Questions
  122. cancel key code
  123. cancel key code
  124. 2000 Honda Civic CX pcv location
  125. What motor mount fits my ek??
  126. Turbo EX D16Y8 Questions
  127. Suspension noise
  128. 97 Civic Cx H/B help question
  129. 98 civic power window broken
  130. a/c works sometimes
  131. 98 civic dies while driving
  132. '00 Civic MAF Location?
  133. civic drop time
  134. tire problem
  135. Need Swap Advice Now Help!!!
  136. Check engine light on but NO CODES!
  137. cx or dx hatch?
  138. help please
  139. Please Help
  140. radiator question
  141. doing a mini me this week or next.
  142. help!
  143. 99' 5 spd Civic Ex Won't Start~Help Me
  144. 98 civic lx high idle
  145. 99 Honda Si IDLE PROBLEM PLEASE HELP!
  146. Have fun with this one
  147. 2000 civic hx cvt
  148. cracked exhaust manifold/bad o2 sensor
  149. Transmission Question
  150. lowering car...question?
  151. header+cat+o2=emissions?
  152. 98 civic light brake pedal
  153. 00 Civic EX Rear Disc Conversion
  154. 98 honda...parts?
  155. cold startup noise fix
  156. Floating Si Emblem
  157. Help a Chick
  158. 98 lx civ sputter take off
  159. mini swap help
  160. 97 HX Dual Mufflers
  161. the D on drive is flashing
  162. ls/vtec internals
  163. weight of a 96 hx?
  164. whats the HP for this car ?
  165. 96 Hatch; Electrical Problem
  166. is this reparable?
  167. back seats
  168. 97 civic ex w/SI motor ecu ?
  169. noise
  170. 1996 Civic 4dr LX
  171. Well, I bought a Civic (was DX, EX, and HX gas mileage)
  172. 1996 Honda Civic
  173. 00 Si Turbo Set-Up Help Needed and More Newbie Questions
  174. '00 Civic won't start...please help
  175. help please
  176. D16Y8 swap to ?
  177. tried google sorry still need help
  178. WTF is this noise??? Please help me if you know
  179. headers for a 1998 honda civic cx
  180. ticket
  181. help with wiring a new o2 sensor
  182. I need help!!! Any guys that know anything about Honda Civic's PLEASE READ THIS!!
  183. More than one Speedometer or Tach.
  184. Cold start engine 'tapping' FIXED!
  185. 1997 honda civic ex swap
  186. !997 honda civic ex grinding in nuatral
  187. Comparison - Injen Short Ram PLUS Extension
  188. OEM Honda tweeter kit for 96 Civic LX
  189. EK seat swap 4-door
  190. Choking at stop on D
  191. pulsing lights
  192. Some major problems.
  193. How do you Remove a Stock head Unit?
  194. Mugen, Spoon
  195. Serious, Very Serious, Let's Talk About Rice
  196. Help with Light Configuration wiring
  197. 5th or 6th gen
  198. Last exhaust '?'
  199. Cleaning the Throttle Body
  200. Can you go without Heat shield?????
  201. Oil/Air Problem
  202. redline for a 1998 honda civic cx
  203. type r motor
  204. How to get better gas mileage
  205. just bought a civic cx
  206. Valve adjustment
  207. Head question
  208. 2000 Si Turbo Questions
  209. Where do I add brake fluid to 98 Civic LX?
  210. Rough @ idle and drop rpm
  211. Si front end conversion
  212. DX and HX gas mileage, and general gas mileage questions
  213. Brake System
  214. NewBie's Questions
  215. 5th gen d15z1/ 6th gen d16y8 head swap?
  216. little knocking
  217. Smoke is coming out of my AC vent???
  218. Losing gas mileage
  219. How much does it cost to paint rims black?
  220. Remote start on a 1997 DX Hatchback manual
  221. 97 HX what i need to do....
  222. Park brake indicator on acceleration
  223. '97 Honda Civic EX .... A VTEC?
  224. cost to raise my car?
  225. 97 HX need help please
  226. Yucky oil
  227. Auto to manual
  228. Civic Single Belt Pulley
  229. fuses under the hood?
  230. grinding noise
  231. 96 and 2000 coupe doors
  232. how do i tell if its obd1 or obd2?
  233. Motor getting wet ???
  234. unstableness at high speeds
  235. A/C problem when outside temp is cold.
  236. SUV-Civic side impact!
  237. Does a Civic SI exhaust fit HX??
  238. what problems am i going to have with my hx?
  239. Are 4 doors slower than 2 doors?
  240. Weird Cold Weather Headlight Problem
  241. Auto Transimission problem
  242. civic dx
  243. Civic Question
  244. 75000 miles
  245. Changing Spark plug wires/Rotor/Distributor Cap
  246. 97 Civic Wiring Diagram
  247. brake fluid for '96 civic
  248. 2000 si b16
  249. will it fit?
  250. Catalytic Converter location
