View Full Version : '96-'00 Civic
Pages : 1 [2] 3 4 5 6 7 8 9
  1. engine spewing coolant
  2. Where to buy a brake caliper?
  3. Weird noise during tighter turns
  4. Civic 2000 LX: Manual vs. Automatic (fuel efficiency)
  5. d16y5 swap for b series
  6. 98 hx civic engine swaps
  7. 1997 Civic Intermittent A/C
  8. 99 civic paint is peeling on roof
  9. 2000 Civic sohc engine noise
  10. 99 Honda Civic EX coil spring problems
  11. 99 Honda Civic EX windows rolling up/down problems
  12. Need help getting faceplate off
  13. I need to settle a argument
  14. wet trunk
  15. Civic Ex overheating HELP! 140K
  16. Civic Ex overheating 140K
  17. Shifter problems 99 Si
  18. Sloppy Shifter feel
  19. 96 civic not running as good as usual
  20. what motors wil bolt right up
  21. honda civic sir ????????
  22. 1997 Civic been sitting 2 years
  23. Aftermarket or dealer
  24. Engine popping when accelerating
  25. A/C Problems
  26. Can't get ignition advance set correctly
  27. Crank no start
  28. Recall?
  29. 96 Civic Coupe, outer door handle removal, HELP ASAP!!
  30. A/C Compressor Belt Change
  31. what to do to my civic
  32. its spring again time for new pics of the car
  33. Sunroof won't close
  34. Questions on my 98 civic ex
  35. civic si muffler
  36. now we've changed the wires too...
  37. after replacement of distributer car wont start
  38. after replacement of distributer car wont start
  39. Body parts
  40. 96 Civic Transmission Issue
  41. looking for 98 ex coupe specs
  42. engine poor acceleration help!!!
  43. Location of Vtec Solenoid Valve/oil pressure switch on 98 civic
  44. Aftermarket car alarm problems?
  45. Expansion Valve location? '97 Civic
  46. 98 Civic Alternator Step by Step
  47. bent valves on a 97 honda civic lx........Help
  48. 99 civic cx
  49. Intermittent misfires on cold start/acceleration only
  50. valve timing on 96 civic...
  51. need hepl!
  52. ls vtec?
  53. speedometer stuck
  54. V-tecTrouble Code P1259 But no V-tec engine!
  55. Car not starting
  56. 99 civic si window is stuck please help!!!
  57. halo install help on 96 civic
  58. 1998 Civic LX Transmission has started to slip
  59. Wanting to build honda motor
  60. camber kits
  61. 98 Civic wont start/no power at all
  62. 98 Civic DX antenna replacement problems
  63. Honda HX with EX tranny?
  64. Car shaking on highway
  65. Help My car won't start!!!
  66. 200 cx front plate screw
  67. 98 ex starting problems
  68. 1997 Honda Civic DX Problems.
  69. Help Installing Type R Lips front and rear
  70. what did you pay for your timing belt change?
  71. Radiator problem
  72. 99 Civic intermittently runs rough
  73. 99 civic cat converter operating below threshold
  74. Problem getting rear seat (passenger side) to fold down
  75. Civic DX 98
  76. Rear door lock problem
  77. Gas Gauge adjustment
  78. 9.3mm spark plug wires
  79. Buying a 98 Civic Ex
  80. Your opinion?
  81. 99 EM1 rear brake pads
  82. need help diagnosing codes on my honda
  83. Honda Civic 99
  84. 98 civic rough idle/ check engine light
  85. Honda Civic
  86. purchasing a salvaged honda civic 98 ex?(PICS)
  87. '99 EX (D16Y8) burning oil?
  88. Motor oil Vs Transmission Fluid Question
  89. vtech valve and speed sensor ?
  90. lights surging
  91. 07 SI seats
  92. air bags
  93. honda civic air bag help
  94. Swap Information Help please......
  95. window regulator/motor
  96. 99' Civic Transmission swap questions
  97. Swap questions EK series (Y7 to B16A2)
  98. HELP!!!! 97 honda civic
  99. exhaust question
  100. 11" slotted rotors with 4x100 bolt pattern.
  101. automatic
  102. 1/4 mile stats
  103. 99 Civic DX fuse panel diagram
  104. help!!!! turbo auto civic??
  105. lca's
  106. help with possible buy
  107. 96 EX civic heat control problems....
  108. Dangerous or no effect?
  109. Code- P0420
  110. antenna
  111. suspension
  112. aghh someone help me!!
  113. Replacing Antenna
  114. HELP: Clutch pedal on EK
  115. 2000 honda civic AC compressor
  116. exhaust research
  117. 98 Civic SI wipers won't stop
  118. B16a2 (automatic) swap help!!
  119. 4Cylinder civic and v6 accord please help
  120. Need Suspension Help Please Look.......
  121. '96 honda civic gas gauge stuck on full????
  122. Intake swap from another Civic?
  123. jerks upon acceleration
  124. Alternator caused speedometer to fail...?
  125. parts needed for auto to manual trans swap for 2000 Civic Si???
  126. rear disk brakes
  127. converting 97 civic to 99-00?selling velside bodykit
  128. Clutch Help
  129. replacing inner tie rod 97th pw steering
  130. excessive inner wear, rear tire
  131. Fixing power window on '00 civic
  132. help!!! coupe or sedan?
  133. help asap please!
  134. Fidanza Flywheel Help
  135. swap in ek
  136. 1998 Civic Dx Hatchback
  137. Turbo Automatic civic
  138. Help with 2000 Civic
  139. my civic....
  140. civic vtec
  141. '96 Civic Engine Issues
  142. jdm d15b into a 96 dx??
  143. 1997 Civic EX clutch engages starter
  144. 98 Civic Keyless Entry - pwr locks problem
  145. Need help......
  146. Hand Break is realy loose
  147. Hey Need Info Asap!!
  148. overheat when got stuck
  149. 98 civic lx CEL headers exhaust
  150. supercharger on a civic
  151. Idle air problem, 99 civic
  152. HELP!! Stereo/dash lights/alarm HELP
  153. Obd1?!obd2?!
  154. Getting a B18A1
  155. Power window kits.
  156. 2000 cvic dx
  157. valves
  158. 2000 Civic Lx a/c problems!!
  159. Help with '97 Remote
  160. Bizarre Soft Brake Pedal
  161. programming keyless fob
  162. overheating civic ???
  163. how do you know if vtec is kicking in?
  164. Newb from ohio
  165. Testing waters..how much?
  166. How to install Front Oxygen Sensor for 1998 Honda Civic EX coupe
  167. connecting CD player in civic '96
  168. air conditioner whistling
  169. '00 Civic Possible Swap.
  170. 00 civic ex help remove side view mirror and wiring diagram
  171. 99 Civic LX - Low RPM Problem
  172. Radiator support
  173. 97 civic hx afc neo install?
  174. swap question
  175. fiixing an aluminum rim? getting rid of dime size rust spot? help!
  176. 97 Civic A/C Problems
  177. 2000 EX help please! AHHHHH!
  178. Door restraints grinding on 98 Civic
  179. Stereo problem
  180. 97 EX (d16ya) Valve Adjustment Help
  181. H23A1 Swap into my 98 civic EX?
  182. Wrecked civic
  183. wtb 99-00 civic front end
  184. Rear brakes squeal / squeak
  185. whistling sound
  186. how to replace ac thermostat on 96 civic
  187. need opinions
  188. Manifold & throttle question
  189. What other years could I take a hood/bumpers from to fit my 97 civic cx hatch?
  190. checking the timing on a 97 civic
  191. Neon bulbs in defrost switch
  192. Color Code
  193. Engine miss/backfire '97 Civic EX
  194. HIDs with angel eyes from ebay
  195. 1997 civic LX problems with somethin!
  196. The Conversion
  197. ex to vx
  198. Old Rusty.
  199. Timing Belt
  200. Third Brake Light on Spoiler....
  201. vibration on civic 99 LXi manual when AC compressor on
  202. Interior Question????
  203. My clutch won't come back up!!!
  204. iacv
  205. vtec controller
  206. SI vs. PRELUDE OPINIONS!! PZL HELP!!
  207. installing throttle body?
  208. clutch problems
  209. throttle
  210. Mystery Cooling System Problem
  211. 02 sensors
  212. idle prblem
  213. z1 fenders
  214. Intake Tube Lengh/Filter Cone Length
  215. Tach, speedometer, fuel, temp gauges
  216. Center console
  217. Sponsors
  218. AEM CAI = bad throttle body???
  219. Rear Disc Brake Caliper Piston Retraction
  220. What engines can be put in a 2000 Civic EX Coupe
  221. d16
  222. what do i need to hit vtec?
  223. cv boot
  224. buying a civic
  225. enigine swap exaust compatability D16-B18B1
  226. Paint!
  227. 2000 Honda Civic EX Rust
  228. muffler/exhaust installation help
  229. reprogram a Honda remote to arm/disarm antitheft system
  230. no vtec
  231. How much tranny fluid in a 98 civic hatch?
  232. A/T cooler-safe to drive without?
  233. help! pops when turned
  234. Belt noise when using accessories
  235. Civic 1.6i ES - Alarm/beeps goes off
  236. HELP! Error codes P0420 and P1457
  237. gauge light not working
  238. Warning Light Code
  239. Throttle body?
  240. 98 civic brake rotors
  241. 2000 civic turn signals wont work
  242. How to keep the exhaust quiet
  243. loose tranny dipstick '00 Civic EX
  244. Civic leaking connecting pipe, help!
  245. Help! civic won't start
  246. New Horn
  247. messed up firing order leading to engine not starting...
  248. Shag's Ex Photoshoot (56k, oh my)
  249. Interested in purchasing a 97 or 98 civic..
  250. oxygen sensor simulator
