Automotive Forums Car Chat
Honda
> Let's get Technical!
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
Car making wierd noises
Wiring Harness Help
H22 SwaP!. actin Funny!
will the oil pressure gauge work without hooking it up to the 12v
91 hatch obd0 obd1 question cars is sittin HELP!!!!!
Help !!!Turbo M35
rotten egg smell
my piece of shit dont start
Sudden oil burning
N/A or Turbo ?
sqweeking from clutch
Where's my PCV Valve? uh oh...
Horrible Engine Knock
Ticking sound could be lifter or cam???
Flamethrower
obd2 harness
how do i test a TPS?
Del Sol Si, Z6 problem..
89 accord lxi surges and dies and hard to start afterward
hole in my muffler
Internals question
Sleeve the block on a B18C1
piston problem
vtec solenoid wire question
to swap or not to swap....
Engine Help!
Engine Help!
96 accord ac air compressor question
valve clearence
possible gains from basic n/a Mods
apex vafc
apexi vafc
engine question
Compression #'s?
Need more power
ATTS/engine light on
Skunk2 Stage3 Cams - can i use on the street? Have anyone information about this?
No compression all 4 !!!!!!!
Valve lash on a 96 DX head. Oil control jet?
engine squeak at higher rpms
unstable idle and rev
blue smoke
problem starting
Water in my H22
White smoke and Oily Plugs
91 octane map, switch to 116 map
Eagle Crank Rods, Pistons
F22 starting problems
Need help with turbo cams for b16a gen-I
help me
Loud hum / noise! 98 civic
Dumping oil/fluids
street tuning and dyno tuning
SCS Short Connector
shifter
car shakes from 70-85 mph
What axles for b16a? please help
89 Civic Manual Transmission Issue
Need Advce!!!!
whistling noise
po7
turbo or not
Crank Shaft questions
Engine Swap ?
injectors not opening
Fixed Valve Lash... ticking worse!
how to install a short shifter
Short Shifter???
3rd synchro gone out.. what now?
please help.. trans problems
weird idle
Prelude Wiring Diagram
3g prelude/b20 idea/question
vtec controller
b16 need more power!!!
will po7 run d15b
D16 mine me swap
boosted ls once made 325 hp, needs help
sr20 in a 2000 civic ex??
My lude likes to turn off....
JDM Vtec H23 Question
exhaust size ???
Is this normal?
Blown suspension
CV Joints or New Axles
91 accord probs...
99accord 2dr questions
GSR Swap.
jdm b16a3 184 whp 128 tq with just bolt ons ??
Honda Accord 92 Cooling Sytem Prob
How do I install the msd blaster to 94 civic
AEM intake question
I got a question about the VAFC
RSX Type-S
loud buzzing noise near rear left door lock
YS1 LSD Conversion?
Please Help!!! Cracking CV Joints
zex stage 2 cam questions d16y8
b20 acceleration probs
91 Integra RS speed
Muffler
How to bypass the second o2 sensor
ecu identity
engine getting hot
new stainless steel exhaust
out of curiosity
speedo cable
Gettin Ready to Put B18a in 91 Civic SI
Honda accord accord 92 cooling system problem
RPMs hesitating during shifting (load issue?)
91 CRX Project Many Questions - new to forum.
My engine
shaking and idle problems
95 ex single cam vtec or swap?
idle wont stop surging b18c1-gsr
stainless stell mufller question
engine upgrading
A/C capacities
help me guys.
High HP Maintenance(sp)
What's a good engine for 92 Integra?
1991 Integra GS Tranny Problem!!!!
turbos for automatic transmissions....
intercoolers
94 civic no start
Idling Problems on my GSR
what is a spoon engine
clutch problem
90 b 16 motor swap
vtec hook up????
95 Gsr in 91 RS Integra
This is great.... well not really but funny
Help a Nissan Driver**Please** VTEC advice needed.
Safe to flush engine?
My cars temp flexes
Cold Air Intake Blues
How do I beef up an LS Transmission?
HELP!! Please
b16 Pistons and rods in b18 block
88 prelude engine?
b16 distributor 1st gen
Won't start, HELP!!!
I need help with this!
B series Clutches
LS/V-Tech
Source for ECU units.
Help Electrical problems
What head is this? PR3-4??
Ignition Output Signal
No reverse!!!!!
what size turbo to use?
Honda Insight
97 dx hatch motor swap vtec INFO
B Series Trannys
Greddy e-manage vs. SAFC
Smogg Test Help
I have synrco issue....
Cat Error Code?
About headers
VTEC Problems
accord V6 harmonic balancer removal
Air Impact Gun
B18 in Civic Hatch Help!!
GSR vs LS
B series headers
New Trans for the V6
JDM S1 Tranny Question
b16 starter vs d16 starter
Any Shop Owners Willing To Help A Scammed Guy?
Hot Wire
ABS problems
accord f22 rebuild
D16 block differences?
3.0L V6 in my 93DX?
what should i do next?
What engine is best ? Rotary? Four banger?
Mini-Me swap
d16y8 head porting
Internal Work
piston face
B16A2 with ITR head???
B16A3 swap
Heard Work for turboing
engine/starter problem?
EF Speed sensor
Aftermarket Radiator cap
ZC motor
Diagnosing Accord AutoTranny Symptoms
A Chip?
Aem Ems
440cc injector injector ?
!!!!!Aftermarket JDM vs American parts!!!!!!!!!
check engine
b20 help
any one with honda knowledge HELP ASAP
are b20b vtec's unstable
fast idle
difference between ZC SOHC, Z6, and Y8 cams
zc swap in a 90 dx
b16, GSR head info
2000 Honda Accord V6 cylinder misfire
wideband oxygen sensor
Brake booster.
help me along (b18a1) info.
*B20B Questions*
wierd mpfi swap problem
MoNsTeR B18b
Looking for info on a 94 civic ex
D16Y8 rebuild
b20 axle
QuEsTiOn
86 Honda Accord needs 100 key turns to start
valves??
remote start?
installing lsd??
talk
Starting problem
Gel Cell Battery
need help: exhaust warning light???
building ls/vtec
Lack of Back Pressure - Possible Solution?
Valve Adjustment Problem
Coolant Question
Draining Coolant in 1995 Prelude Si
1994 vtec head gasket
Does JET reprogramming work?
b16a to d16z6
Turbo Timer To Non Turbo Car?!
Take off caliper or leave it on
losing sign os any hope
b20a6 vtec?
plugs of choice these days
Hey ppl me back agian
No.1 Misfire Bad Injector?? JDM Engine Help
Performance?
1994 Prelude new heads
Clutch problem or adjustment??
my LS/VTEC
sdfdfhjy
Did my battery die??
88 prelude 2.0s engine/fuel delivery problem
Oops wrong gear
new clutch not going into gear! ('98 Wrangler) HELP!
clutch question
LIKE new engine
B16 Power
1987 Honda Prelude engines stalls at high rpms
Help a beginner please!
i need help fast
ecu code or problem
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
