Clutch problem or adjustment??
RedCivicSi
01-15-2005, 01:39 AM
When my clutch is engaged at a higher rpm and I shift into 4th or 5th I hear and feel a grinding noise sometimes. Plus when i shift into 2nd my tires don't catch the pavement. Is it time for a new clutch or can it be adjusted?
civickiller
01-15-2005, 01:32 PM
is the clutch slipping when you hit 2nd ? what kind car do you have ?
RedCivicSi
01-17-2005, 01:52 AM
I have a 99 civic si. Yeah it slips when shifting into 2nd but not all the time..
Privatebigandrew
01-17-2005, 10:45 PM
ahhh the all to famous grind of the B16 trans. Put a shortthrow on it with polurethane bushings and replace your fluid with GM syncromesh. You will never hear a grind again.
