plugs of choice these days
Mingish
01-16-2005, 08:03 PM
im gonna get some new spark plugs tomorrow..i just wanna know what are the best ones going? and is it even worth putting top of the line plugs into a D series motor? even tho i got aftermarket wires
civickiller
01-18-2005, 04:01 AM
ngks are the best
Dweezil6969
01-18-2005, 04:15 AM
Same here I only buy NGK plugs.
LittleGSEclipse
01-18-2005, 09:42 AM
I would definately go with NGK's . They are recommended from the factory. And they are not expensive the NGK V-Power's run about 1.90 a plug.
95civicgsr
01-18-2005, 11:05 AM
ngk plugs and wires here
95RSV
01-18-2005, 05:01 PM
I got NGK Iridiums
Ace$nyper
01-18-2005, 05:06 PM
I got NGK Iridiums
:1:
:1:
bingisSD
01-18-2005, 08:34 PM
i cannot emphasize this enough for anyone out there who is planning on getting quadruple platinum plugs, and extra thick wires, ****you do not need extra spark unless you are running turbo or supercharger AND are adding much more fuel/air mixture.***** ESPECIALLY on a single cam motor
civicnation425
01-18-2005, 09:06 PM
NGK's only for me... for some reason NGK's create a great friendship with honda motors.
Privatebigandrew
01-18-2005, 09:30 PM
NGK iridiums at rockauto.com....can't be beat
civickiller
01-18-2005, 10:22 PM
you still dont need better spark plugs or thicker wires when going turbo or sc.
the best setup for turbo or sc, is regular old ngks with oem spark plug wires.
Civic_D16Y5
01-18-2005, 10:26 PM
i replced my spark plugs with bosch +4's the place i bought em at didnt have ngks, so i went with the next best
bingisSD
01-19-2005, 02:11 AM
how about when using nitrous, i was taught the more air/fuel mixture the more spark needed
bingisSD
01-19-2005, 02:15 AM
can you please explain msd ignitions role then
civickiller
01-19-2005, 03:59 AM
you dont need any msd ign boxes like the 6al or anything. some people have run itno problems when using the msd ign boxes, when they removed it the problems went away, it was usually missing.
all you need is a coil, like a msd blaster ss coil.
also when using nitrous you should get colder plugs, you can still use ngks, just get them colder to fit the nitrous
