Help Electrical problems
Vafan
02-16-2005, 06:44 AM
Hi, I just stumble onto this website. This is a really nice website. I have a 2001 Integra GSR coupe. It is beginning to have electical problems. One day, an injector did not the fire(1). I put a noid on the injector and it did not light up. On the same day, the front right turn signal does not work. A couple of days later, the right headlight does not come on and the ABS light is on. I look at the manual for causes. All these problems have one thing in common and that the wiring is connected for the ground is connected to a connection junction. Does any one know what this is? Does anyone ever have this problem before or know what the cause is? Thanks for any advice.
h22meangreen
02-16-2005, 07:18 PM
best advice sell the car and let someone else deal with it
superbluecivicsi
02-17-2005, 12:47 AM
the obd2 teg injectors each have a singal wire going directly to the ecu. the other wires are 12v wires (not grounds) that each share a junction with the IACV, the primary o2 sensor, and the evap emissions seloniod (i believe that is it, correct me if im missing something). they should all be yellow black wires leading into the #11 or 12 pin on the ecu (i believe its the #12 pin, use the manual to verify since you have one). since the noid test failed on the injectors, why dont you take the test further with a voltmeter from the 12v junction plug to the injector connector. then check from the 12v junction plug to the ecu. if all looks good there, then check from the singal wire of the #1 injector to the ecu. your problem is bound to be in the wires, ecu injector driver, or injector itself.
you also said the abs light is on..................pulled the code yet? it should read somethign.
since you said your right headlight and turn signal light is out....................have you checked the bulbs and and fuses yet? if they are fine..............check for a break or short from the switch to the bulbs.
