How to change powersteering piping
MooseNelson
01-24-2007, 08:01 PM
Hello there,
I'm gradually losing more and more PS fluid, ahhhh, mixes in with that oil spot in the garage, gulash.
i changed a fuel line once when I was about 18, basically my first repair, so I know it can be done with those connecting bolts:screwy: here's the situation, recommend cutting and splicing?
http://img120.imageshack.us/img120/1026/dsci00028yl.jpg
Thanks M8s!:rofl:
curtis73
01-25-2007, 09:34 PM
If its leaking from a hole in the line itself, I would replace the line. If its the pressure side, don't patch it. There can be anywhere from 800-1500 psi in some parts of the pressure side. The return side only sees about 40 psi so you could temporarily patch it with high pressure hose and a few clamps, but the only real way to do it is get new lines.
MooseNelson
01-28-2007, 08:31 AM
Right this is what my friend at work (jiffy lube, aw jeez) said, just replace the line, forget about splicing.
Thanks for the infos on return/send pressures I'll check that out.
g:cwm27:
2.2 Straight six
01-28-2007, 09:29 AM
find out the OEM code for the parts, order them and replace. there's not point patching up rusted-through piping, it'll just fail somewhere else another time. better safe than sorry.
MooseNelson
01-28-2007, 07:01 PM
Gents, thought I would share my daily success (so I hope)
So Napa was closed (must be a franchise), Pep Boys told me they don't sell any kind of metal piping, and well autozone always prevails here, they sold me a 3/4 3ft brake line and a flair tool.
yanking out the old one was pretty easy, required jacking up the cah, and I disconnected the reservoir lines so they were dripping on me,
putting the new line in was fine, it came with a screw on end that was the same diameter but sae size instead of metric, screwed in fine right into the turning box, i had bent the line as best as possible, but required some bending while in place, pulling it out, using the axel to bend it around
i flaired the end and stuck it on the hose, no leaks, had to fill the reserv a few times and start before enough new fluid got back into the pump, steering is working fine, but I've still got a puddle in the garage, getting alot of leakeage from under the timing belt cover dunno we'll see where we go, but i think it was leaking or would have been shortly.
http://img407.imageshack.us/img407/1295/dsci0002ie2.jpg
http://img170.imageshack.us/img170/5930/dsci0005ee6.jpg
:naughty:
Steel
01-28-2007, 10:55 PM
Man. I always hated having to redo those damn pressure pipes.
