View Full Version : Galant
Pages : 1 2 [3] 4 5
  1. cabin air filter
  2. Horrible knocking/bumping noise
  3. I4 vs V6
  4. headlight and foglight replacement
  5. 01 Galant Key Transponder Programming
  6. Changing inner tie rod end, HELP!!
  7. 97 eclipse electrical problem
  8. Wanted-4g63 Any Condition
  9. KRAP!.....No spark with 92 Galant!...Any ideas?
  10. 2000 Rough idle and tapping sound
  11. Front Driver and Passenger doors rattle... 01 Galant
  12. 2001 crash
  13. Window
  14. Galant vs Audi A4
  15. How many miles does ur Galant has?
  16. Timing`Belt/ Transmission
  17. 99 galant no heat
  18. 2002 Galant Timing Belt
  19. 03 Galant vibrating in floorboard
  20. 97 Galant Transmission Problem???
  21. Freeze Plug Problem!! Anyone Please Help..?!
  22. Engine Ran out of oil too fast!
  23. GTZ not firing one cilinder
  24. fuel filter replacement
  25. radio code
  26. 98 Galant-Somethings about to die
  27. 2002 Galant Brake problem
  28. head gasket help
  29. Need help interpreting codes
  30. 95 Galant automatic transmission problems!
  31. Need help with g/f 95 galant
  32. 2002 galant keyless entry problem
  33. Draining Engine Oil on 2003 Galant
  34. Here's a good one on a '01 Galant
  35. Fuel Gauge has a mind of it's own
  36. 1991 Car Stereo wiring
  37. How do i remove the dash
  38. 99 Nitrous Equiped Galant 4 Sale.. Heavily Modified Must See!
  39. 60K tuneup
  40. 94 galant won't shift into 4th gear/ over drive automatic
  41. OBD II Scanner Port
  42. Aluminium or Stainless Piping kit
  43. More Intake Issues
  44. help need window
  45. 05' Aftermarket Radios ??
  46. Corresct A/c recharge pressure.
  47. 2003 Galant radio help
  48. 91 Eagle/Mitsubishi starting problems...
  49. Main Ecu On A 94 Galant??????
  50. Check Engine Light sometimes comes on
  51. Discount OEM parts for Galant?
  52. overheating
  53. I need code for my cd player Mitsubishi Galant 2001
  54. Code
  55. Intake Install
  56. New 1996 Galant ES owner. Problems.
  57. speakers in a 1998
  58. need Navigator Unit
  59. Galant's, Any chronic problems? especially the 2002
  60. my gearbox is noisey
  61. Help!!! Galant will not start...
  62. Very Loud Engine noise..what going on!??
  63. seatbelt
  64. Galant Horn
  65. where is tranny ecu on a 94 galant
  66. rear shocks wanted !
  67. Squeeking problem
  68. 1999 Galant + Radio Help
  69. Service Issues
  70. Dedication to my 98' Galant
  71. Water pump for 6A1x family engines
  72. Speaker Installation
  73. Left Turn Signal
  74. Trans. slipping at 109k
  75. wet passenger carpet
  76. Window
  77. WTB vr4 rear cradel and control arms for rear left
  78. air condition vent knocking
  79. exhaust leak?
  80. I wanna hook my galant up!!pleez help
  81. 1990 Galant power windows... down, but not up..
  82. The overview of 2005 Mitsubishi Galant
  83. Help me fix my Galant!
  84. Advice on buying a 1999 Galant estate please
  85. car shaking at 65 mph
  86. vr4 ecu WIRING
  87. When Brakes pressed - parking lights, brake lights and dash lights come on.
  88. recharging a/c
  89. parting out 1997 galant 4 door silver w/ gray interier
  90. horsepower gain
  91. For Sale: 98 Mitsubishi Galant ES (Needs some work)
  92. air conditioning overservice
  93. Speedometer Fix?
  94. Galant VR4 #1279 For Sale
  95. 1999 Galant ES Trans. Out
  96. motor mounts
  97. 94 Galant ES
  98. 4g94 Gdi
  99. Windscreen Washer - Wiring
  100. Low revs - poor performance
  101. wheel bearings
  102. no dash or tail lights
  103. Replace serpentine belt 97 Galant
  104. 2001 V6 Galant timing belt R & R
  105. Galant Turbo Kits
  106. Air Conditioning PLEASE HELP
  107. Spark plugs
  108. how hard is it to change spark plugs on a 99 galant?
  109. Eclipse Exhaust on a Galant?
  110. Air conditioning
  111. 6a13
  112. Cleaning the MAF
  113. 1994 galant with 97 trans having problem!!
  114. help, JVC CD troubleshooting
  115. Throttle restrictor?
  116. o2 sensor help
  117. metra turbo kit bracket for 7th Gen
  118. do you guys suggest buying a galant ?
  119. my left turn signal wont turn off
  120. Power Loss
  121. Error codes 11 and 59
  122. 99 AC condensation drain tube?
  123. knock 2001 2.4 es galant
  124. oil change frequency
  125. Starter replacement
  126. 1999 Won't start. @.@
  127. galant tail lights
  128. 99 Galant sterter replacement
  129. Car won't start....alternator?
  130. '92 Eagle gtx 2000 won't start-problem solved
  131. Crank Pully '95 Galant
  132. Error 25 - Barometric pressure sensor
  133. 1999 Galant Factory stereo wiring
  134. 1994 Mitsu Gallant Running to rich?
  135. transmission filter
  136. is it just me
  137. programming keyless remote for galant
  138. mitsubishi galant es check engine light??
  139. Anti-freeze reservoir and AC (semi-long)
  140. Accessing Rear and Door Speakers
  141. whats your idling? and other concern
  142. Mass Air Flow Sensor Help!!!!!
  143. Timing Belt Cover
  144. 99-03 front speakers
  145. FOR SALE --- 97 misubishi galant --- FOR SALE
  146. 1995 Gallant needs new rack and pinion steering
  147. help 02 galant cant find my spark plugs
  148. body shop replaced oem tire with mismatched tire
  149. Car starter or battrey?
  150. 2001 Galant Radio reset
  151. american-european designs
  152. 98 radio harness
  153. WTB: Used 96 Auto Tranny for Galant ES. Help!
  154. Quick ???
  155. Power failure
  156. Engine Noise like loose rocker
  157. 2005 Fog Lights
  158. 2001 Galant/radio Code?
  159. Raido
  160. galant engine swap
  161. 1990 GSX engine swap?
  162. Infinity Success Story
  163. Please Help with 03 CD Player Problem
  164. Car sitting about a year
  165. Headlight Bulbs
  166. odd noise (seemingly) from front wheels
  167. 94 Galant GS troubles
  168. radio code for 2003 galant..please help...
  169. FS: 1990 Galant AWD parts
  170. FS: 96 Mitsu Galant S
  171. lost keys on 2000 galant
  172. 99 Galant-Does bad tie rod mean new rack and pinion
  173. Crazy iddle on Galant GSR 91
  174. timing belt install 98. galant 1997cc doch
  175. Stereo reset...HELP!
  176. Opinions on 2001 Galant Es 2.4L
  177. 98 galant gls 2.0 auto throwing off pss belt
  178. Help
  179. Rear Disc brake job who can help?99 galant
  180. oil on boots and on plugs
  181. Parting out whole car!!!! 02 galant charcoal
  182. trans flush service
  183. ignition
  184. Soch inj 2.0ltr 4963(SB6P41G Series)
  185. Blinking A/C LED, compressor shut off ('99 Galant)
  186. FS: Galant stock spoiler + Galant door emblems
  187. 99 Galant dies when ac is on
  188. need tps for 89
  189. Checking timing belt
  190. galant gearbox fitting????
  191. Electrical problems
  192. Wiring for cd deck install needed for amp bypass!
  193. GVR4 for sale???
  194. hood pin installation??
  195. GT vr-4 jdm
  196. No drive forward or reverse
  197. 1997 Galant PS belt
  198. 98 computer to a 96, will it work?
  199. Removing wheel/speed sensor from Hub Assy
  200. WTB: 94-98 Silver door mold/trim
  201. Time to start building
  202. Front & Rear Fog light switch
  203. 2001 Mitsubishi Galant ES Won't Fire
  204. wheels for sale
  205. 92 Galant Check Engine Light On Wont Keep Running
  206. WANTED: 98 Galant car...wrecked or blown engine OK
  207. Help with 01 Galant, Lights dont work after Cd player Install
  208. Galant 2000 Timing belt
  209. 2001 Galant CD player troubles
  210. 1998 galant help please
  211. vented fender
  212. What transmission fluid for a 1997 galant in owner's manual...
  213. "97 galant" every 97 galant radio code is not 3844! here is what I did to get my code
  214. 97 Galant Lifters Need Help
  215. 1998 Galant Woes. . . . .
  216. need help with skunk 2 coilovers for galant 01
  217. 97 galants do they have two keys???
  218. help!
  219. 1999 Galant Viento GDI
  220. Am i putting to much weight in my trunk?
  221. I finally got pics of my galant up, here they are!
  222. removing the wheel cover/ hubcap of a 2001 galant
  223. help : wind screens
  224. help! PLEASE "97 galant" tran problem not working look for help:(?
  225. 92 Galant Acceleration problems
  226. Angel/demon headlights
  227. SRS Light wont turn off!!!!
  228. My Friend Ethans Galant
  229. ECU in a 1990 Galant
  230. different tranny fluid
  231. 97 galant check engine light
  232. Exhaust Cost
  233. pwr steering flush
  234. 2001 Galant Banging Sound on the Right Side
  235. Instruction for removing galant 2000 stereo
  236. electrical windows wont go down
  237. idle problem???
  238. how to fit wheels and supention on 2001
  239. Radio codes for my 97 Galant
  240. The little red light
  241. Headlights Cleared Corners
  242. simulated wood dash kit
  243. 2000 gallant brake & timing questions
  244. ECU Question
  245. Dyin While Drivin, Help!!
  246. 96 Gallant S/ horn installation
  247. Help! Car wont start.
  248. how to replace radiator support
  249. 95 galant electrical problems
  250. 01 galant stereo wiring question
