View Full Version : Galant
Pages : 1 2 3 4 [5]
  1. Engine in 1998 Galant ES? Durability?
  2. 2001 battery replacement & programming
  3. 1997 Galant VR-G info please
  4. ECS problem
  5. bogging out
  6. Throttle stuck wide open
  7. TPS replaced, still acting weird
  8. kick ass body kit for 99-03 galants
  9. Why?????
  10. Transmission Problems(No reverse)
  11. Questions.....HELP.......
  12. Need Manual Bad
  13. Good place to find everything you need for a Galant???
  14. Tranny kick when driving any clue?
  15. 95 Galant dies out???
  16. Transmission/Overdrive problem, Please help!
  17. turbo parts list
  18. Help
  19. rpm's possessed by the devil \m/
  20. rpm's possessed by devil
  21. Galant Engine Swaps
  22. where can buy the carbon dash board?
  23. car is making a squeking noise....
  24. Check engine light is on...etc
  25. Problem with lights in the car
  26. '91 Galant won't start
  27. Central Lock doesen't Work- Electric problem ?
  28. 2000 GTZ Stalls after wreck
  29. somebody help!!!
  30. My 97 Galant Is making a clonking noise on its rear axile..
  31. Galant es 97 bodykit?
  32. Galant 2001 driverside Halo headlight removal
  33. 95 Galant automatic transmission fluid
  34. 97 Galant ES
  35. Galant engine swap with FTO's 6A12 mivec
  36. Need Help...
  37. how to instal the gauge on my car?
  38. where can buy the asian style body kits of galant 99-2001
  39. going turbo
  40. how do you remove rear drums 2000 galant
  41. Electrical Problem
  42. Timing Belt Put On wrong
  43. Galant head light assembly
  44. remote for car
  45. New Engine needed for 2000 Galant
  46. 92 Galant won't start!!
  47. swap 1999 Mitsu Galant 57,000m mint condition for Roadtrek or custom van w/sleeper.
  48. garage opener programming steps?
  49. 95 galant torque convertor not disengaging
  50. gdi
  51. 92, blew enging, need quick info on swap
  52. I want one!
  53. Looking for a Galant to be used in a Photoshoot
  54. 1990 Galant GSX
  55. Oil
  56. Rear End Knock
  57. 1992 engine knocking
  58. Firewall in 2002 Galant
  59. 2001 Galant radio code
  60. 98 Galant - Japanese model
  61. Many Questions Needing Answers
  62. Water leaking into passenger compartment
  63. radio code for 2000 galant?
  64. How long do 1989 Galants last (motor)????
  65. Parting out 92 Galant LS
  66. engine & tranny swap
  67. Unpredictable occurance of high idle. ECU problem?
  68. Galant GSX, Can it be a VR4,should I buy a gsx?
  69. 97 Galant 4 cyl : Cold air intake?
  70. Electrical Problem - Need Help
  71. 1990 Mitsi Galant - Why I hate it!!!
  72. 1995 Galant This squeaking is driving me crazy
  73. HELP! Inconsistent starting problem!
  74. Best engine swap for 89 galant
  75. Stereo Unlock Codes
  76. NO POWER IN CLOCK, STEREO and LIGHT
  77. car wont start
  78. Aftermarkrt Coil packs for 4g93 GDI
  79. '01 Galant ES won't start -- freezing temp's
  80. need pic. of fusebox- Mitsubichi 91 sr4??
  81. Blower motor stop working!
  82. transmission trouble
  83. 1992 galant gti gear ratio????
  84. Galant Clutch Problem
  85. clicking noise in passenger dash
  86. galant intake
  87. Performance Parts For A 95 Galant
  88. Radio Code for 2000 Mitsubishi Galant??
  89. ECM location on 97 Galant !!
  90. Spark plug gap !!
  91. VR4's
  92. Transmission Override Problem
  93. ? on power antenna not going down
  94. Engine Idle Too High
  95. transmission in {limpin} mode have you seen this problem
  96. Help, start problem
  97. Reprogramming a transmitter (remote)
  98. What are the keyless entry model numbers for 2001 Galant?
  99. no power to sunroof and...
  100. 2000 Galant radio "off"
  101. Timing belt change...
  102. Galant Transmission Help
  103. Cold Weather Starting Problem
  104. computer REFLASH fixed
  105. 97 galant radio code
  106. 1990 Galant No Power
  107. japanese/Europe spec Galant parts
  108. Help! New rims vibration..
  109. How to take my factory radio out? Galant 2000
  110. 2001 Galant for sale!!
  111. The Galant Center (Clubtgc)
  112. Too Rich...
  113. Resetting and removing 2000 Galant Radio
  114. need help
  115. Acceleration Issue
  116. JDM 91 Galant VR4 parting out..
  117. Please Help!!!! Engine Problem
  118. Galant throttle position sensor
  119. 6a12 mivec
  120. Programing Key Fob
  121. Correct way to take out a 2.4l out of a 1995 galant??
  122. So what could it be, and where could I get it?
  123. Convince me to buy a galant
  124. my australian spec vr4
  125. FS: E39A chrome grill from Japan
  126. HELP!!!!!! need help on installing gauges PLEASE HELP ANYONE
  127. really weird problem
  128. Selling a Galant
  129. 2003 Gtz Rims
  130. Upgrading the 2003 ES 2.4L 4cyl
  131. Upgrading a 2003 ES 2.4L 4cyl...
  132. Transmission stuck in 3rd gear
  133. Noise in Engine
  134. Check Engine Light
  135. Problems under the hood.
  136. Transmission Problem ~ Plz Help!!
  137. Galant GTZ
  138. bad vibration 4G63 engine
  139. fuse box layout
  140. 99 Galant radio removal
  141. '74 Galant GB/GC engine swap
  142. Reverse glow gauges, any good?
  143. Galant engine codes
  144. Programming instruction of 98 Model Galant
  145. programing remote for '99 galant
  146. how do you clear the SRS Light
  147. New and need help :)
  148. stereo help needed
  149. fender 1997 Galant
  150. Battery dead now running very bad
  151. Newb to the galant!
  152. going through firewall
  153. Subject: audio wiring diagram needed!!!
  154. Wiring Diagram 4 4G63 DOHC non turbo
  155. 1991 Galant Electrical Problem w/MPI relay
  156. Galant 4G63T wiring diagram
  157. 1997 Galant Brake Problems
  158. 1999 Galant V6 with 19" wheels
  159. galant help
  160. galant engine swap
  161. 1998 Mitsubishi galant
  162. FS: Axxis Metal Master brake pads for Galant
  163. Vr4/gsx?
  164. Help! Galant 2000 radio needs a code
  165. 4g63b Wiring Diagram
  166. 90 Galant Where does radiator wire plug into??
  167. VR-4 maps
  168. 96 Galant
  169. Turbo on Galant GSX
  170. Amp
  171. 1999 Galant Tie Rod End
  172. upgrading the galant
  173. information about a 98 Galant VR-G GDi from Japan
  174. 90 mitsubishi galant
  175. 1998 galant 5 speed 67k FOR SALE
  176. radiator overpressurized
  177. 1990 gsx galant
  178. 95' any good?
  179. Thunder programmable chips for 4G63T
  180. My Galant
  181. HKS 550cc injectors for sale
  182. body kits?
  183. FAO "TheGalantCentre" staffers`
  184. MIts Galant 6th Gen Parts for sale CHEAP!!
  185. FS: Lowenhart BR5's
  186. 94 Galant Check Engine Light
  187. 94 Galant Oil Problem
  188. question
  189. Where to go through firewall
  190. it is alive
  191. Bring Some Life!!!
  192. Where are they???
  193. thegalantcenter.com galantspeed.com
  194. slipping trany
  195. Programming keyless entry
  196. wanted... intercooler
  197. programming keyless
  198. Jap. Spec. 1995 Galant VR-4 Performance Parts
  199. 1990 Galant
  200. Can Anyone Help
  201. where are the clear lights ???
  202. Galant Transmission
  203. I need Help
  204. wheres the galants??
