View Full Version : Sportage
Pages : 1 [2] 3
  1. driver side window just disappeared...
  2. 2001 Sportage engine smells and compartment feels hot
  3. 2000 Sportage overheating
  4. 2000 Kia after fixing 4 wheel drive problem
  5. 2000 sportage intermittant starting problem
  6. 1999 Kia Sportage code Po440
  7. blower moter issues on 2000 sportage
  8. Kia Sportage 2.0 TDI 07/2000 Engine does not start
  9. '99 Tportage transmission problem
  10. Hold Blinks, CEL on, codes: P0122, P1309, P1624, P0101 PLEASE HELP!!
  11. 1998 kia sportage
  12. 2002 Kia Sportage misfiring
  13. 2000 Kia Sportage 2wd misfire problem
  14. Corrosion
  15. Fuel tank/sender Corrosion
  16. Too much pressure in fuel line
  17. Trouble starting 99 Sportage
  18. Engine cranks but only starts when it wants to
  19. Shifting noise - 5spd
  20. problems starting Kia sportage 2000
  21. 2000 Sportages Flashers
  22. Location of the main computer for a 1998 Kia Sportage 4x4
  23. Cyl#2 missfire on 96 sportage
  24. Kia Sportage Recall
  25. help with 2001 sportage
  26. Help Please
  27. 2001 kia sportage P0171 error & rough idle
  28. 2001 Kia Sportage EGR valve location
  29. Any one have any use for a Sportage Tranny?
  30. Intake Manifold-Vacuum Line???
  31. 95 Sportage Stick Drop Link Shaft!!!!!
  32. starting prob.
  33. starting prob again
  34. From CAJUNHOPPER : problem with heater
  35. Problem with heater
  36. Another problem, flickering lights
  37. 98 Sportage overheating
  38. 2000 kia sportage
  39. Sportage won't start in wierd temperature range
  40. Kia rear axle help Bearings
  41. valve cover torque question
  42. air bag light.....
  43. codes and CEL
  44. allergic to gas
  45. starts but extremely rough
  46. 1999 Sportage won't restart
  47. Kia overheats / heavy gas fumes when cold
  48. wont start back up
  49. 2006 Sportage Fog Lights
  50. Fuel Tank INspection
  51. 2005 sportage
  52. kia sportage won't start
  53. got in 4 wheel drive-- but more problems...
  54. how to engage 4 wheel drive
  55. 2000 sportage reboot
  56. 2000 kia sportage engine issues
  57. 2001 Sportage Fuel Pump Relay ???
  58. '98: engine light on, hold blinking, what do the trouble codes mean?
  59. gas cap door release
  60. Error Code P422
  61. Hard to start when cold
  62. Changing bearings 2001 Kia Sportage 2WD.
  63. gqas dripping
  64. changing lub in front and rear universals
  65. The 2007 Kia Sportage - New set of wheels
  66. 1996 Sportage-temperature related idle problem
  67. 97 Kia Sportage Fuel Pump/ Fuse Problem
  68. 2000 Kia Sportage 2 Timing belts in 2 weeks
  69. HELP!!2001 sportage HELP!!!
  70. Battery Draining
  71. Raw Gasoline Smell Thru Heater Vent
  72. 2001 Heater Blower Died, How to test / troubleshoot?
  73. Ruff idle and slight shake !!!
  74. 2000 Sportage Misfire When Cold
  75. 2000 Kia Sportage
  76. flat tire caused damage to wiring harness?
  77. found what the problem was the hard way
  78. thinking of buying a kia
  79. 2000 Kia Sportage Died And Won't Start, Help
  80. Problems with my 2001 Kia Sportage
  81. 2002 Sportage RKE button??!!
  82. Head gasket? and Door remote problems
  83. 2001 Clutch Slipping
  84. Squeeky belts
  85. 2000 kia sportage
  86. fan blower switch
  87. Miracle needed Kia sportage
  88. 2000 kia sportage
  89. 2001 sportage loss of power while at 60up
  90. Fuel filter fittings
  91. Dead '95 Sportage
  92. Replaced IAC but still stutters at idle
  93. help help
  94. Kia Sportage 1997 transmission PROBLEM
  95. sudden power loss - 2001
  96. 1997 2WD Sportage Problem
  97. car starts but cant move or it stalls, HELP!
  98. starts but cant move or it stalls, HELP!
  99. 2000 Kia Sportage
  100. Brake light and battery light come on intermittently.
  101. Trans fluid change
  102. dying sportage needs help
  103. I love my KIA Sportage
  104. 2002 sportage making squealling noise in front driver side tire
  105. Blown Fuses
  106. New stereo
  107. Towing Advice
  108. 2000 Sportage Check Engine light
  109. idle problems on sportage
  110. Less power and pinging down low
  111. Water leaking IN the rider side floor board.
  112. Car unlocked on its own
  113. loose wheel
  114. Sportage with Overheating issues
  115. Genuine vs aftermarket.
  116. fuse problems on my KIA Sportage 2001
  117. Kia Information Needed
  118. Not sure what to do.
  119. Need help
  120. I need help
  121. 2001 sportage stalling/codes
  122. 2000 Sportage Engine Squeals, Help
  123. what years are cross compatible for the spare tire carrier?
  124. HELP! my 2001 Sportage DIED on Hwy 99
  125. 98 Kia Sportage Key Stuck in Ignition
  126. Changed motor wont start now
  127. transmisions
  128. Leaking AC Unit
  129. Timming belt fix
  130. Front brake fix
  131. Some Sportage information here
  132. Please Help!
  133. 2001 Sportage 4x4 -Check Engine Light won't go off
  134. $4000 to repair blown gasket?
  135. Help Changing Spark Plugs Please
  136. the screws that seal the air cleaner
  137. Strange smell on 99 Kia convertable
  138. ICV Valve Fixed 99 Kia problem now blinking hold
  139. 2000 Kia Sportage Double Din Installation:
  140. AC is leaking onto the floor board.
  141. P440 Error code problem
  142. abs light
  143. Sportage 97 Big problem. HELP!
  144. 99 sportage alternator
  145. heatercore
  146. sportage overheating
  147. warn auto locking hubs?
  148. Universal Cup Holder for Sportage?
  149. Tranny problems???????
  150. replacing pitman arm?
  151. Another hub question . . .
  152. Tranny fluid in manifold journal??
  153. Surges whilst driving.
  154. 01 sportage big gas problem
  155. neeeddd heeelppp!!!!!
  156. Squeaky Belts won't go away!
  157. I Give Up! Need Help! P0326 Knock Sensor
  158. Is it the timing belt?
  159. Frustrated Technician - 2+3 Misfire 2001 4wd
  160. '01 Kia stutters in idle and jumps
  161. Fuses? Please help!
  162. Kia Sportage 97
  163. Kia Sportage '96
  164. engine problems
  165. 99 sportage no signal lights
  166. Grinding nose in the front end
  167. 97 sportage starter removal, whats the trick ?
  168. Normal gas mileage check
  169. 2000 Kia Sportage
  170. '95 Kia Sportage with leaky gas tank
  171. Sportage maintenance question
  172. Yet another timing belt question
  173. Ruff start after gas up
  174. A/C Heat vent on Kia Sportage etc HELP!
  175. 2000 Sportage Problems with Heat/Starting
  176. 99 sportage heater core where do i start
  177. 2000 Sportage Engine Design and control
  178. i need timing belt specs
  179. low pressure fuel filter attached to fuel pump
  180. What's REALLY needed at 30,000 miles??
  181. HELP - Urgent! O2 sensors/running rich/ cat problem
  182. 1998 Kia Sportage. Hard to Crank/Start
  183. Need Help
  184. 98 Kia Sportage EX leaking by oil filter area
  185. 1999 sportage in dominican republic
  186. Sportage overheats and temp gauge reads normal
  187. start problems
  188. 1999 Kia Sportage
  189. 2000 sportage running rough
  190. spark plug coils
  191. 1999 sportage engine start but wont stay on
  192. Radio/CD clock reset question
  193. 2000 Kia Sportage Rear Hatch Problem
  194. 2001 Sportage Rear Main Leak
  195. 99 Sportage EX/Sudden stalling
  196. timing belt broke
  197. Sportage Missing and not pulling
  198. LED turn signal headlights and mirrors?
  199. 2001 sportage w/ fuel smell in cab
  200. 2001 Kia Sportage catalytic converter problem?
  201. Still waiting on a wire hareness
  202. 4WD trouble on '95 Sportage
  203. obdII p0453
  204. i need help fuel pump problem
  205. 98 4 whel drive
  206. 2001 Kia Sportage Bezel radio removel
  207. Fuel Pump vs. Wire Harness?
  208. driver window failure
  209. 2001 Sportage - Should I buy one?
  210. ABS and Warning Light Appear for few seconds
  211. 2001 Sportage cd/cass/radio
  212. A/C and temp meter problem
  213. Flashing hold light!
  214. No Heat
  215. 1997 sportage oil leak
  216. 2000 Sportage - Losing power & understandig codes
  217. Sportage Trans.overdrive
  218. fuel tank leak
  219. ADVICE ON 99 SPORTAGE - Do they go over 89,000 of the engine?
  220. Low Fuel Warning Light?
  221. 1999 Kia sportage problem
  222. HELP!! Radio Blown Fuse
  223. Power steering belt
  224. 2002 sportage AC compressor pulley
  225. Loss of power
  226. 1993 sportage dlc location
  227. 1999 Sportage keyless remote
  228. Front wheel bearing adjustment
  229. switch on the dashboard question
  230. Help. Website needed
  231. fuel injectors
  232. detachable faceplate for the radio cd player
  233. Rod Knock
  234. Gas Cap Door
  235. Engine studders when it is cold
  236. Airbag Light Question.......
  237. alternator/battery/charging problems
  238. 2005 oil drain plug
  239. What could be wrong?
  240. Thinking of Purchasing a cheap Sportage, input wanted.
  241. 1999 Sportage problem
  242. Knocking Sensor
  243. '95 Sportage misfiring badly
  244. sportage overheating
  245. 2000 sportage runs but verry hard to start, HELP
  246. 2002 Kia replacement battery
  247. 2000 Sportage Aftermarket parts
  248. a few questions wiper prob/ and a studder
  249. Excessive auto tranny shifting
  250. Car not starting I unplug batery wait 60 sec it starts Help
