1997 sportage oil leak
leber
11-13-2005, 11:40 PM
My '97 Sportage developed a problem. oil began streaming from around oil filter. I changed oil filter and it did not correct problem. Any ideas?
ruyam29
07-22-2007, 03:29 PM
I have a 2001 Kia Sportage (115,000 miles) and this same issue has started to happen to me. I changed my oil filter also, but the pressure when reving the engine happens to pop the oil filter and oil sprays over the engine.
ruyam29
07-23-2007, 01:36 PM
Went to mechanics and he mentioned to me that the oil fillter leak is occuring because of the oil pump is bad. That does not make sense to me because the oil is streaming out when the car is turned on.
Any ideas anyone???
Any ideas anyone???
hvac1000
07-24-2007, 09:46 AM
Any ideas anyone???
I believe the oil filter adapter has a gasket between it and the motor block. Your oil filter is not leaking it is the gasket gone bad.
Any ideas anyone???
MeettheCreeper
07-27-2007, 05:40 PM
Thats correct the filter adapter is leakin. It can be nightmare to remove.
