View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24
  1. Transmission fluid dumping in engind compartment
  2. Brake lights staying on
  3. Blown speakers
  4. power steering
  5. i want to sell how can i make it better?
  6. cranking fine, but occasionally doesn't start??
  7. fuel pump pressure
  8. what clear lense would you guys like to see?
  9. S10 Rear Swap Question
  10. Instrument cluster problems 2000 S 10 2.2 eng. speedometer not working
  11. wheel bearings...at what millage did u replace them?
  12. 1983 parts for sale
  13. removing door panels
  14. Starting Problems
  15. 1992 s10 Blazer speaker short
  16. 1992 s10 Blazer Instrument cluster lights
  17. 1992 s10 Blazer Vaccum leak
  18. 99 Blazer s10 4x4 help
  19. i do not have luck with door handles.
  20. Oil Fill Tube
  21. ecm
  22. rpm meters question
  23. Lifter noise
  24. Vortec turbo charged
  25. will not start!!!
  26. speedometer
  27. need help!!!
  28. fuel pump??
  29. transmission fluid
  30. Amp to factory stero hookup
  31. rear
  32. lowered painted 1985 chevy s-10 pickup for sale
  33. Don't know where to mount subs
  34. Seats
  35. door hinges
  36. S-10 Blazer warms, surges and stalls
  37. Four wheel drive problem
  38. 94 4.6 no start - Experience, please?
  39. Help Please
  40. S10 Cruise Control Blinker Switch Assembly
  41. low oil pressure???
  42. 4wheel drive
  43. a few questions
  44. 99 S10 4x4 problems HELP
  45. my poor truck...
  46. oil sending unit? & lean exhaust code?
  47. No heat!
  48. How interchangeable are 4.3/vortec parts?
  49. Good Shocks????
  50. 98 S-10: Emissions - SES Lamp ON/DTC P0420 Set
  51. 1996 2.2l fuel pump????
  52. brake and blinker problems
  53. drifting
  54. cant switch vent
  55. front end of my s-10 blazer
  56. Front End Generation Swap ???
  57. 91 S10 Heater Core
  58. steering shock absorber
  59. frequent no-start when cold
  60. think outside the box
  61. Engine dies when lights turned on!
  62. speaker problems
  63. Fusible Links to Solenoid?
  64. Drl On 99 Chevy S10 2.2
  65. removal of door panel
  66. clunk/rattle in drivetrain
  67. wiper relay?
  68. Again a nightmare with my S10
  69. dimmer install
  70. Fire order
  71. truck not always starting
  72. 91 s10 stalls at idle
  73. 1989 S-10 Blazer Starting/Electrical Issues
  74. 84 upgrades?
  75. tires and tilting and sorts
  76. odd suspension? brake? differential? problem
  77. installing sun roof
  78. Extreme gets wheel hop
  79. Turn signal assembley switch
  80. Get some bass for your buck
  81. pin out for checking error codes
  82. IAC valve? '97 S-10
  83. Cleaning EGR on 95 4.3L 4x4
  84. bell howsing question
  85. 2.8 stalls after you take your foot off the brake
  86. Want to add a sub what will fit
  87. S10 making a ticking noise.
  88. Can it cut it? 4l60e with a v8?
  89. help please!!!!!!!!!
  90. TCV cable
  91. 4x4 not shifting back to 2hi...
  92. remove wiper from shaft 98 S10
  93. 92 s-10 no fuel at injector
  94. hinge noise
  95. what tires should i get
  96. Idiot lights on dash....
  97. Got Electric Supercharger?
  98. Positive cable grnding to engine
  99. fuel pump not pumping93 s10 blazer
  100. Idiot Lights On Dash
  101. not getting any power to the new cd player
  102. chassis ground wire on harness
  103. Surge and ping
  104. Idling problems on '95 S10 4.3 Z
  105. 2001 s-10 dtc p1153 anyone have this problem?
  106. 93 S-10 Blzr the 4x4 wont work
  107. supercharged s-10 extreme
  108. removing radio and installing new one...few questions
  109. 86 S-10 dash lights
  110. Pictures of 1995 S-10 Engine
  111. Brake problems...
  112. engine problems 89 s-10 blazer
  113. Would like to motor swap
  114. Black Smoke...
  115. big problem need help really quick.
  116. Gas odor in 1995 S-10
  117. question about engine replacement
  118. bucks like in 4x4 but its only 2wd
  119. 91 s10 shift light
  120. 97 4.3L Temp Problems
  121. gibson or not?
  122. vortec problem?
  123. Where is that EGR Valve on a 1993 S10?
  124. 93' Blazer Needs All New Fuel Lines
  125. will it fit
  126. turn signal problems
  127. yoke from hell
  128. starting out
  129. "Y" Pipe
  130. Freeze Plugs (?)
  131. 96 s-10 starting problems
  132. Fog light bulb
  133. After Market Tach Hook-up
  134. some winter driving sense
  135. Ghost Sensor
  136. Ghost Sensor
  137. Blazer Won't Start When It Rains! Please Help!!!
  138. Radiator drain cock
  139. i think im out of my league, can anyone help?
  140. 98 blazer wont start when cold
  141. blackout lights?
  142. guages, many problems, 1 cause?
  143. A little cockeyed!
  144. Missing anti freeze?
  145. heater not getting hot
  146. temp. gauge
  147. oil pressure
  148. HELP ME PLEASE!!! 2000 S10 2.2 Vin5
  149. s-10 power
  150. 2000 s-10 4x4 wont engage
  151. 2003 Chevy S-10 2WD LongBed For Sale
  152. fuel pump relay question
  153. S10 blazer rain water entering vehicle
  154. recalls....how long do dealers have to honor them?
  155. 95 chevy s10 wont start...help???
  156. 95 chevy s10 wont start...help???
  157. 1999 Chevy S10 2.2L Hesitation probs
  158. Fuel Pump
  159. 4X4 control panel lights not working 4 wheel drive not working
  160. ac/heater
  161. can anyone help me?
  162. EGR Valve?
  163. 1998 s-10 Blazer transmission fluid line removal
  164. Rear seating...
  165. Hello, new to the board with problems. 4.3 tbi
  166. 98SonomaMan
  167. How fast in 4Lo Lock
  168. fuel system/
  169. 1998 s-10 Blazer Tranny leaking
  170. What transmission on Iron Duke 1st Gen?
  171. installing starter
  172. s-10 extreme 2.2L
  173. INterIor AfterMARket PLZ READ
  174. no more s10 :(
  175. Bumper or rollpan?
  176. Bumper?
  177. 93 4.3 no 4x4 hi
  178. No heat!HELP!
  179. oil leak in 98 s 10 p/u
  180. 98 s-10 blazer transmission dip tube removal
  181. 93 4.3 w ....cruise control prob/mph drop in use
  182. Buying 2001 S-10 Crew cab
  183. 2000 s-10 for sale
  184. stereo help in my 85
  185. which would you rather have???? ford or chevy
  186. 97 s10 blazer wont shift out of park
  187. i cannot turn off my windshield wipers
  188. Fuel level sending unit replacement
  189. 1986 Blazer TBI problem?
  190. 1991 S-10 body kit
  191. Dash cracking on '95 S10 pickup
  192. need numbers from 4.3
  193. ABS light stays on
  194. new alternator
  195. caravan to truck tires is it safe?
  196. Problem stalling
  197. 4x4 will not engage please help
  198. 2000 s10 ecotec motor swap
  199. v6 s15 no spark
  200. B.S. or not sounds like it
  201. bolt pattern?
  202. intakes
  203. problom with my s-10
  204. Starter removal help!!!!!!!!!!!!
  205. Auto trans shift problem. (Help!)
  206. 2003 Radio wiring color codes
  207. ravin or flowmaster?
  208. 2.2 Vibration at 3500-4000 RPM
  209. clutch problem in cold weather
  210. How would you know if your clutch was going out?
  211. could it be the fly wheel?
  212. Wingnut from oil drain plug lost inside oil pan! HELP!
  213. SES Light...There are many posts but nothing that helps me!!
  214. 85 s10 blazer
  215. whistling sound from R. differential
  216. Oil filter location: 1989 S-10 Blazer 4.3 v6
  217. Oil filter location: 1989 S-10 Blazer 4.3 v6
  218. 2.8 to 4.3
  219. 4.3 vortec is toast what will fit?
  220. 95 Blazer Oil Pressure problem.
  221. ENGINE sWap 4X4 possible?
  222. PVC question
  223. Removing Stock Grille
  224. WTB: S-10 Parts Needed
  225. Noise driving me nuts
  226. pilot bearing
  227. 4.3 Rough Running Solution!!!
  228. WATCH OUT for AIM Industries Inc!
  229. 87' Tail light assembly?
  230. starting problems on a 91 s10
  231. Bad fuel pump????
  232. Just Got an s-10 Xtreme v6. Need Advise!
  233. 91 S10 blazer front differential doesnt always engage
  234. ignition fuse keeps blowing
  235. 1999 Chevy S-10 Front Brakes Questions
  236. 89 Chevy s-10
  237. ac working all the time
  238. shaving door handles
  239. 2.2L 99 Engine Vibration Please Help!!!!
  240. When floored, it revs then goes
  241. high flow cats? reccomendations?
  242. wanting to trick out my daughters s10 blazer
  243. oil change....time vs. millage
  244. 1983 S10 Carb Swap
  245. 2001 S10 350 Swap
  246. Rebuilding 97 2.2
  247. unlevel truck
  248. Seat Warmers
  249. 88 s10 pickup starting problem
  250. S-10 P/U Bed repair question
