View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24
  1. 2.2L oil pressure
  2. Hard to start
  3. Need input on 96 S-10 cylinder head
  4. Help Replaced everything and still crappy
  5. (2) Compressors For Air Ride F/S Ebay!
  6. 2.8L Pistons
  7. idle problems
  8. 5 speed trans grinding help
  9. s-10 has mind of its own with flashers
  10. lifting my blazer
  11. Rear End
  12. 98 S-10 2.2 90,000 miles surges and hesitates
  13. 4x4 help
  14. Transfer case leak
  15. Fuel Gauge Reading
  16. 87 s-10 tire size
  17. Stuck in 4 wheel high
  18. good exhaust for a 98' 2.2L S-10
  19. shifter knob
  20. 95 s-10 2.2l to 2.8l swap
  21. SB S10 Transmission Snag
  22. cold air intake for 95 s10 cpi vortec
  23. 94 & 95 S-10 help
  24. transmission fluid blows out of fill tube
  25. 1987 electrical problem.
  26. max tire size
  27. Catalytic Converter replacement 87 S10 Blazer
  28. switched to synthetic, low power
  29. 87 1.5L distributor cap ?
  30. surges of power upon acceleration
  31. Tranny noise
  32. Can someone help me w/ my 99 PWR Locks/windows/heated mirror install?
  33. starter replacement
  34. Sputtering engine
  35. digital dash swap help needed
  36. lowering my 84 s-10 help?
  37. Help! Integra antenna change
  38. Check Engine Light won't come ON
  39. cooling
  40. 94 S-10 misfire, no SES, vin W
  41. Wanted Rims that fit s-10's
  42. 1987 S-10 Blazer for Sale
  43. 2001 chevy S10 Extreme4.3 dropping 350 in
  44. 4.3 Vortec distributor
  45. no oil in oil pan
  46. dead speedomiter
  47. s-10 shuts off while driving
  48. Fuel Gauge Problems
  49. 2000 S10
  50. A Little Guidance.....please???
  51. 1987 S10 Tahoe XCab Pick 4 Sale
  52. lost horse power
  53. no ac through the dash
  54. Need some help with a 1995 S-10
  55. 98 S-10 No start, F.I.?
  56. 1994 4.3 Vortec (W) EGR
  57. Clutch Noises
  58. My S10 any suggestions?
  59. ecm or prom ?
  60. zo6 rims
  61. distributor plug in
  62. fuel pump not running when key is turned
  63. 4x4 acting up
  64. Hard to start s-10 4.3 L
  65. tire width
  66. Suspension on my 89 S10
  67. Help! '97 has no brake lights or turn signals
  68. Electric chock coming from engine!
  69. clutch bleeding help please
  70. What's a good engine conversion for fuel efficiency?
  71. Install Hood Pistons?
  72. No Data to aldl and no spark,fuel,inj pulse
  73. P1509 IAC System High RPM
  74. warning oil lines
  75. run away truck
  76. trans fluid cpapaciyy
  77. 1987 Chev s10 Electrical Help
  78. Hesitation, stalling, hard to start
  79. This CAI a ripoff?
  80. Whats Happening???
  81. 4.3 supercharger
  82. 4.3 ltr black smoke
  83. NEED HELP with Hesitation Problem
  84. Buying 98 s10 pickup - All advice welcome
  85. lowering my chevy s10 question.
  86. Transmission Problems... Need Help Asap!
  87. New project '94 with lots of issues...wana help?
  88. 2000 s10 alternator went bad now help!!!
  89. window motors...
  90. underside car rust
  91. Mpg
  92. Where is the bleed valve?
  93. Can tow jet ski with Extreme pkg?
  94. installing power windows/locks/mirrors questions....
  95. Gas saving devices...
  96. 97 s10 turn signals stay on
  97. clutch problems
  98. 91 2.8L Problems
  99. 98 S-10 loud vibrating noises
  100. 87 s-10 Blazer 2.8L nead HELP (Computer Problems?)
  101. 02 front on a 94?
  102. 2wd to 4wd on 4cyl yes or no
  103. Auto Tranny fluid
  104. Blowing ECM1 fuses on 99 S10
  105. buying a zr2
  106. SES Light on at 60 MPH
  107. 97 s-10 bearing replacement
  108. 4L60 rebuilt messed up no 1st 2nd gear
  109. Audio help needed
  110. Some info on a shift kit?
  111. cold start problems
  112. S-10 transmission interchangeability?
  113. s-10 frame question....
  114. Need help with plug order on 4.3 cap
  115. Jammed access door
  116. 96 s-10 not starting - clicking noise
  117. 89 4.3L S10 Blazer performance
  118. V8 S-10
  119. Power window motor change on 2dr S10 '94
  120. a good lowering kit...
  121. ecotech????
  122. 2.8 s-10 stalling out
  123. Carb swap question on '85 2.8 V6
  124. slave cylinder?
  125. 94ss w please tell me how to adjust timing
  126. Fuel Pump Connected to brakes!?
  127. ECM B Fuse keeps blowing, engine won't run.
  128. 95 S10 Transmission removal
  129. 91 s10 body lift
  130. Replacing Bumper With Roll Pan...question
  131. 5-speed help
  132. Help!! 97 S-10 Not starting!!!
  133. always finding problems
  134. 95 s 10 complete front for sale
  135. Tune-up and upgrade info
  136. ZR2 tach
  137. Oil filter conversion question
  138. Cold Air Intake
  139. more advice needed...
  140. 95 s10..what shud i do first?
  141. can a cpi cause my truck not to start?
  142. door locks
  143. 2.2 intake and mileage
  144. 2003 keyless elect door locks
  145. 1999 Chev. S-10 Pickup 2.2 Liter
  146. Chevy Cyclone Picture
  147. 96 S-10 Ext cab back-up lights
  148. I sat there at a home depot for 22minutes
  149. ABS light @ high speeds
  150. towing S-10
  151. no power to ignition switch... HELP!!
  152. just purchased a 95 s10
  153. Compatibility?
  154. New Motor Wont Start
  155. Truck acts like it is starving for fuel
  156. High Idle
  157. tailgate stuck
  158. 2000 S-10 Flex-Fuel Fuel Pump
  159. Won't start...
  160. truck will not start
  161. 4.3 L Granatelli MAF Sensor
  162. A/c Squeals!
  163. 93 s-10 header dual exhaust problem
  164. Need Help
  165. Just Got 20's Now What??
  166. HELP- how to remove dist. rotor on 91 4-cyl
  167. engine stalling when turning right
  168. 350 swap
  169. Cat Converter
  170. 2.2L to 4.3L NEED INFO PLEASE!
  171. 2000 s-10 2.2L
  172. Rear End Pricing?
  173. xtreme fog lights
  174. Switching from 15" to 14" Rims
  175. 95 S10 with 65K miles for sale
  176. 88 s-10 2.8L bog down with map sensor plugged in
  177. bogging down
  178. Swap 96 S10 Ext. cab 2.2 a/t to 2000 4.3
  179. Need help
  180. Brake Pad Mount Bolts..
  181. 91' 2.5L- 40K miles- maintenance questions
  182. Bogging down on acceleration
  183. Pitman And Idler Arm Question
  184. 86 dash conversion
  185. leaking anti-freeze.. !! HELP !!
  186. Clutch and Pitman and Idler Arm
  187. ZR2 tach problem
  188. 91 S-10 Blazer Sport Troublecode 24...
  189. Crank Case Pressure High
  190. 91 S-10 No Fuel & No Spark
  191. Disc Brake Dragging
  192. Studdering at takeoff
  193. 97 zr2 manual tranmissions
  194. gas mixed eith my oil, egr
  195. 4x4 switch problem
  196. anti theft cd player code?
  197. Need to find the Oxygen Sensor wire
  198. truck making noises
  199. PS help needed!!
  200. 2003 s10 noise when on gas pedal
  201. Where is my diagnostic port??? help!!!
  202. battery draining out on s10
  203. 1986 s-10 erratic starting
  204. 2.2 head bolt sequence
  205. Adding an Air Conditioner unit
  206. want to swap motors
  207. S-10 Stalls when hot
  208. ZR2 aftermarket wheels?
  209. short throw shifter for 02 s10 v6
  210. s-10 quirks
  211. '86 Rims on a '98 S-10? Problems? 14" and 15"
  212. towing capacities
  213. Rewiring S-10
  214. two ?'s tach, and fuel system fault codes
  215. Bad signal to EGR Valve?
  216. 91 S-10 4.3 oil leak
  217. erratic fuel gauge
  218. 1989 Jimmy 4wd tranny swap
  219. Windshield Wiper Help
  220. key stuck in ignition
  221. rear end (camaro 2 blazer
  222. Vortec V6 heads
  223. '01 removing window crank (manual)
  224. S-10 tail light fuse
  225. tail gate malfunction
  226. 94 s-10 doesnt go past half tank gas
  227. instument panel illumination
  228. rear end
  229. carb - injection
  230. 89 high pedal on clutch 2.8L
  231. replacing leaking oil cooler lines
  232. 1995 S10 For Sale
  233. Wiper Motor Help
  234. a/c help
  235. swap of injection to carb need help
  236. Engine temp on 02 s-10
  237. 97 s10 clutch
  238. 1999 s-10 keyless install not originally equipped
  239. stuck in 4WD LO
  240. Weird clunk and humming
  241. 1985 S-10 Blazer
  242. engine block heater
  243. are all gm 93 4.3 liter the same?
  244. Sunroof on 93 s-10 stock?
  245. For Sale 98 Red S10 SS
  246. Need help please!!
  247. 2.8 Intake & Cam Mods
  248. my erratic startin S-10, is this a breed problem ya'll?
  249. shifting problems
  250. thinking fuel pump - Help
