View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. Cant figure it out
  2. 94 S10 4.3L 2wd starter replacement
  3. 95 S-10 4.3 vortec surge
  4. ac blower relay fuse
  5. installing (all) ball joints/replacing bad ones
  6. 87, s10, 4 wheel drive.
  7. Complete and utter loss of power while on the highway
  8. Cold Startup problems
  9. poor acceleration
  10. load ability of the xtreme
  11. light bulbs
  12. headers and exaust
  13. Only runs with timing advance disconnected
  14. How much oil do you add when you change your oil and filter?
  15. horn relay?
  16. 87 s-10 4 cyclinder 2wd reg cab (standard)
  17. help runs like s@#%
  18. tur signal/wiper
  19. V8 swap and steering column
  20. 2001 S10 Power Steering Problem
  21. Gas smell!!! Cant be good, help wntd
  22. Gas smell!!! Cant be good, help wntd
  23. supercharger
  24. 2.2L HP Tuners- read
  25. S10 44 Error
  26. pix of truck b4 paint, will post those later (56k, come back after work)
  27. 1995 Blazer/timing spout connector location
  28. E85 Flex fuel
  29. It will not stay running
  30. Blinkers and Brake lights are out
  31. upper, lower bumper, grill, LH & RH fender.....
  32. Vaccum switch for defrost/vent/heat
  33. various vacuum problems
  34. Why Start?
  35. 98 blazer up and dies
  36. (Another)lift kit question
  37. Gas mileage problems
  38. possible egr stopping up
  39. help me get the bushing out
  40. Location of Oxygen Sensor for 1998 S-10
  41. Sputtering Issue
  42. '87 S-10 ECM fuse blows instantly??
  43. electronic instrument panel dims ??
  44. 93' Chevy S-10 Blazer
  45. 89 blazer 4.3 vortec swap? will this work?
  46. ext cab speaker
  47. 1997 S10 wont start need help fast
  48. 91 s10 misfires and sputters
  49. 95 ABS Recall???
  50. Cat Converter - trouble removing
  51. Possible Blown Head Gasket
  52. 93 S-10 Blazer Transfer Case Lubricant?
  53. Lifting
  54. **??Custom Lift Kit??**
  55. Quick question about a cpi replacement!!!
  56. Gas problem, poor gas mileage
  57. 64 half ton pick up S10?
  58. 89 S-10 sucking up my gas. Please help!
  59. truck not starting without pouring gas in intake
  60. 85 s-10 4.3 swap
  61. A Few Questions On A 89 S-10 Pickup
  62. What are these wires for?
  63. Anti-lock breaks
  64. my 1991 s-10
  65. 1988 radio wiring diagram
  66. headlight conversion?
  67. A/c
  68. 01 s-10 lifts
  69. 4X4 not working on 84 S10 Some help needed Please
  70. This ? is for the GM guys out there.
  71. 1990 S10 Blazer electric problem??
  72. Air Conditioning
  73. Help on my decision
  74. 96 S10 - Stalling out while driving and then the Air Bag/ABS lights come on (cont)
  75. Simple s10 Question
  76. Trouble code 45
  77. Timing check
  78. 88 s10 problems
  79. AC issue
  80. 1990 S-10 Blazer 4X4 5 Speed Manual Tanny
  81. 99 S-10 takes some time to start
  82. Egr OR CPI problem. Do you Know?
  83. Engine oil in Radiator
  84. Engine Oil in Radiator
  85. VIN # locationS
  86. 91 2.5L Engine Problem HELP!
  87. 87 S10 Blazer Wont Go in Gear
  88. grease on front end frame
  89. 93 4x4
  90. 98 s-10 break lights wont go off
  91. 1990 S-10 / S-15 Pick up TUNE UP
  92. Driver's Side Window Problem :-/
  93. Timing and trouble codes
  94. new exhaust
  95. runs today and not tomorrow
  96. rear ends
  97. Lowering a S10
  98. Vacuum leak, 4x4, a/c, cruise control
  99. Engine and Trans Donors for 1999 2.2 Auto
  100. 92 S10 Blazer smoke
  101. S-10 (1998)
  102. 3rd Brake Light Out
  103. gas
  104. S-10 transmission
  105. Breakin Down 8(
  106. '96 s10 blazer electrical problems????
  107. **Where To Get A Lift Kit**
  108. Question
  109. 2001 ls s-10 blazer wont start
  110. 93 s-10 hard start
  111. 93' S10 2.8 stalls and backfires after warm up
  112. Automotive Repair Books
  113. how to pull engine codes
  114. Is there a difference?
  115. About how much will running the air conditioner affect gas mileage?
  116. S10 also making a grinding noise when I turn
  117. S10 shaking and making a rattling noise when parked
  118. 89 s10 2.8 swap to 2002 4.3l Vortec
  119. Were to buy metal cab mounts
  120. 92 sonoma with v 8
  121. overhead lights won't go out.. all sudden
  122. rusted body mount t-bar crank
  123. clutch problems
  124. Radio Shorting Out
  125. 94 blazer 4.3 4x4 really hard to start??
  126. couple of problems...
  127. AC Odor
  128. Glasspack on a 4.3?
  129. Clear/white replement front signals
  130. 2.5 drive shaft fit 350 trans?
  131. front shocks
  132. cold air intake systems
  133. hood scoops
  134. Over Heating
  135. Oil
  136. 1998 S-10 fan removal to replace water pump.
  137. Dexcool-checking level of protection
  138. 96 S-10 engine wont start
  139. fuel pump????
  140. fuel pump realy
  141. Disable automatic lights at nite
  142. S10 rear bumper
  143. Wiper Problem
  144. Strange misfire
  145. Fuel economy
  146. 2002 ZR2 and the Dexcool nightmare
  147. Rusted cab mounts
  148. 02 Leaking Differential Fluid
  149. gas no go HELP!!!
  150. Chevy S-10 pickup Brake lights fuse blows
  151. A/C leaking
  152. 97' S-10 ZR2 4x4 prob!
  153. '96 Chevy S-10 throttle limiter
  154. mods
  155. Leak in firewall!!
  156. 1997 s-10
  157. 1995 S-10 Head Problems
  158. 1998 s-10 v-6
  159. engine rattle with A/C on
  160. 97 blazer power brake booster ???
  161. S10 Fuel Guage Prob
  162. valve question
  163. A/C heater help
  164. shift timing solenoid
  165. national backorder
  166. 2000 s10 security, starts,then stops in 2 sec
  167. Knock, knock
  168. 1986 S-10 Change Turn Signal Switch?
  169. 87 s-10 help
  170. slipping transmission
  171. 95' S10 2.2 Fuel Pump constantly runs...
  172. intermittant service engine soon light
  173. '94 s-10 starter replacement
  174. o/t need to vent damaged truck tonight
  175. tachometer
  176. tires
  177. 91 s-10 v6
  178. Turn Signal / Wiper Switch
  179. Add on lights blowing fuse
  180. 2000 S10 ticking
  181. 99 s-10 fuel pump bad?
  182. Reverse lights
  183. Turning Signals
  184. Vents are whistleing
  185. 96 s10 2.2 fuel pump relay question need help
  186. plzz help 95 S-10 sluggish acceleration /good midrange/ good full trottle
  187. windshield wiperswitch doesn't work?
  188. Lift Kits 2WD?
  189. Need Help
  190. Upgrades - Suggestions?
  191. Upgrade suggestions
  192. help blazer is dead and wont start
  193. help blazer is dead and wont start
  194. Need help with swap
  195. Oil Pressure
  196. chev s10 horn & elec prob
  197. I have an auto-xray 5000/I need to know where to get list of values
  198. S10 heat problem
  199. wheres the drain for AC condenser
  200. clutch bleed valve
  201. add a ;eaf
  202. 95 S-10 pinging and clattering
  203. 2000 S10 cooling system
  204. Garage put R12 into R134a system
  205. Surging
  206. 2.5L Burning oil - going to remove cylinder head. Help please.
  207. How Low Can I Go With....
  208. Transmission Will Not Shift Right When On Interstate
  209. S-10 Truck won't start when raining
  210. 2.5 to 2.8 or 4.3
  211. rebuilt 2.5 wont stay running
  212. 1991 oil burning s10 blazer, miles 75k
  213. '94 S-10 fuel pump relay
  214. brake booster
  215. 'Nuther day, 'Nuther problem...The Sequel
  216. aftermarket wheels questions
  217. I have the codes - how do I fix???
  218. 1991 S10 Blazer electrical problem??
  219. Low Oil Pressure Fix
  220. about 2 buy a '00 extreme 4.3, please advise!
  221. rear lowing question
  222. 'Nuther day, 'Nuther problem...?
  223. s10 starter re and re
  224. power and exhaust problems
  225. '00 S-10 2.2L 4 cyl - increase power tricks?
  226. 2000 plug socket
  227. 1999 S-10 Problems
  228. 91 2.5L New Engine Won't Run
  229. Help with stereo
  230. egr mods
  231. How do I set timing on 1996 Chvey 2.2L
  232. 2.2 liter a/c compressor change
  233. O2 sensor
  234. S-10 Rear View Mirror Repair
  235. brake is making nose
  236. 03' Sonoma , new here* need help
  237. 94 S10 Blazer A/C relay where is it????
  238. Had to take tent off windows, so now how do I remove the glue?
  239. Signals and Brake Lights?
  240. s10
  241. s-10 blazer running rough
  242. 86 S-15 4x4 Parking Lights
  243. 99 S10 Stalled/Won't crank
  244. trouble code p0171 what do i check out
  245. s10 blazer not running
  246. No fuel no spark
  247. s10 Backfiring
  248. S-10 AC system
  249. Spark from coil
  250. electronic 4 wheel drive enegages itself
