1991 S-10 body kit
comp24
12-22-2004, 10:24 AM
Ive had a 1991 s-10 2.8 litter for about 4 months now and i cant find any body kits anywere. Its the reagular 2 door cab with nothing special. Also i was wonderin some goods mods for the engine without any engine swaps. Currently i got a k and n filter and a tach. any ideas
OverBoardProject
12-22-2004, 02:31 PM
I can't help you on the body kits, although I did find some on a site for newer s-10 body kits and poasted them on this forum a few weeks ago. I believe that I called it Body Kits.
As for the 2.8L I can help you
Try these 2 links
http://s-series.org/index.php?module=htmlpages&func=display&pid=27
http://users.spec.net/home/emxjc/performance.html
Where I live body kits colect dirt, and road salt which in turn causes the trucks to rust out faster than normal
Try these 2 links
dmbrisket 51
12-22-2004, 02:32 PM
check and keep checking e bay, they had my body kit for a 98 long box s 10, i had to look for quite a while but i found it, just keep plucken youll come up with it sooner or later, throttle body spacer and exhaust... thats all i can think of for mods
comp24
12-24-2004, 01:10 PM
I just wont something thats kinda cheap and it wont effect my engine to much. Its a 1991 so its pretty old. Also i Havent found and bodykits on 19 s-10s on ebay and i cant find them seperatly either.
OverBoardProject
12-24-2004, 01:31 PM
I've seen visors from Lund, and I'm sure that you can get a hood scoop. Then how about a hard box cover. You can probably make the box cover yourself for less than 100 bux.
Engine wise how about a dual exhaust, and if you get something like a msd ignition you can put it on your next truck.
Chevy had some pretty nice wheels that are cheap in the wrecking yard, and you can polish them to a mirror like finish if you want.
If you have nice chrome bumpers on your truck Por-15 has a paint that will color the chrome, and still leave the shine come through (spray gun only application) http://www.por15.com/default.asp
I can't see everything costing 1000bux if you shop around, and you can do all the labour yourself, except the exhaust
justin311
01-11-2005, 04:08 PM
you can find a body kit at godfathercustoms.com, it's difficult to put on but it's pretty cheap and it's fiberglass...I've got a 91 extend cab, 2.8 liter and the only engine mod is the K&N which only helps a little, i'd rather have it supercharged...duals are possible too.
