View Full Version : Accent | Verna
Pages : 1 [2] 3
  1. smoking battery
  2. Got an Accent gave to me....
  3. Parts needed...need help to find
  4. Accent acceleration problem
  5. Been looking at another 95 Accent
  6. Is The Excel Sprint 2 Cars In 1 ?
  7. Exterior Handle
  8. O2 Sensor or what?
  9. 98 accent
  10. standard 2 gear
  11. Air??
  12. How good?
  13. 01' Hyundai Accent
  14. How much is a 95 Accent worth?
  15. 2000 accent code 1128 and 1123
  16. flex pipe problems
  17. accent codes P1529, P0740
  18. 1998 Accent Transmission Problems
  19. When they do an alignment, can they see other things wrong
  20. changing oil pan
  21. VIN decoding?
  22. 2002 Accent Right Front Window Regulator
  23. 2002 Accent P0444 code
  24. reverse lights not working
  25. battery ?
  26. Dash light doesnt work 96 accent
  27. Cheap easy turbo for an Accent? No BS
  28. 2002 Accent GS Wont start need help...
  29. 95 accent horn
  30. 96 Accent Headlight Low Beams are out
  31. Accent 01 Body Kits
  32. 96 accent smell gas on start up
  33. 96 accent.. sloppy stickshift and steering?
  34. i need quick fast help plsss
  35. 99 Accent Speed Sensor
  36. engine and ecu codes
  37. ruff idle? any ideas?
  38. Whining noise from gas tank area
  39. where is the ecu located??
  40. Are accents good cars?
  41. Antenna Jack
  42. i hear clicks when i turn
  43. 96 accent overheated wont start
  44. can anybody lend a helping hand?
  45. a bad ass pic of my hyundai!
  46. My 01 Accent's engine purrs too loud..
  47. window handle ???
  48. 96 accent scaner port
  49. Good article on the Accent
  50. help 96 accent brakes
  51. 2003 Accent loud squealing when turning
  52. Transmission Problems
  53. Shifting Cable
  54. hyundai accent need help
  55. Accent runs good when cold - after 40 minutes engine races 4K and transmission slips
  56. Engine Code P0133 Oxygen Sensor slow to respond
  57. transmission troubles, please can anybody help?
  58. Hyunday Accent ATF type
  59. Blown Engine, 1.6L, how to swap out?
  60. 2005 Accent - Mileage sucks - Advise
  61. transmission slip bettween second and third
  62. Help w/ Cigarette Lighter !!!!!
  63. 2005/2006 Accents
  64. 2001 Accent 1.5 Fuel Filter
  65. PO11 O2 Sensor responding slow
  66. Hyundai Accent Overdrive Problem & Solution
  67. Air Filter '95 Accent
  68. accent 60k mile service
  69. Transmission troubles
  70. Check engine, misfiring, high idle..
  71. setting the time
  72. New and with questions
  73. what a friggin LEMON 01 accent
  74. OMG 99 accent problems??
  75. 97 Accent "Economy Button"
  76. shark racing
  77. Hi Bro i need help>
  78. 98 accent CAN'T REMOVE ROTORS
  79. Brake problems - low break pedal.
  80. Radio Install Help for 2005 Accent
  81. beta swap
  82. tranny Problems?
  83. Replacing front rotors, 2000 Accent
  84. Wiring Kit for Radio/CD
  85. Power steering to -91 Pony
  86. transmission problem
  87. Is your Accent a little slow? Try this!
  88. 96 accent timing belt change
  89. 01 Accent Died, won't start
  90. Odd Electrical issues-Plz help!
  91. 96 accent using oil
  92. hyunday accent complain
  93. popping noise
  94. Hyundai Transmission No Reverse Help!!
  95. sticking brakes
  96. www.hmaservice.com website
  97. car wont start
  98. engine swap
  99. Hyundai has finally done it!
  100. Inside Diameter of intake tube.
  101. 02accent ground and wires
  102. Accent Diagnosis codes
  103. Few ?'s about 05 Accent
  104. 110 Volt Adapter for Cigarette Lighter - Alternator
  105. Any News on '06 Accent?
  106. cat
  107. Won't start after a short rest
  108. check engine light
  109. 2 MAF's and now transmisson slipping.
  110. The 2005 Hyundai Accent
  111. 99 Accent 66000 miles Check Engine Light
  112. info on exhaust system
  113. check engine light :(
  114. radio removal and installation
  115. making a beta rev to 9000 rpm???
  116. check this
  117. dashboard lights switched off randomly
  118. my 2005 accent
  119. Rattling sound...2000 Accent
  120. 1996 Accent - Intermittant stall
  121. check engine light is on....
  122. rear door wont open
  123. a/c
  124. I have an overheating problem
  125. 95 Hyundai Accent Spark Problem
  126. Help on getting first car
  127. Turbonator
  128. power loss in my 96 accent
  129. Accent 2000 bearing change
  130. 97 Accent Gas Tank
  131. 2000 accent runs like crap!!!!!!
  132. 2001 Accent Wipers
  133. 2000 Accent P1128
  134. Strange pulsating noise in front end.....
  135. mica or metallic
  136. worth modding
  137. Water Pump Leak
  138. Air bag
  139. O2 Sensor adapter wire colors?
  140. 1.8L Beta in LC2 and hi-revving
  141. Timing adjustment 2001 Accent
  142. 95 accent tranny shift problems
  143. How to install an aftermarket Tacho?
  144. Accent problems
  145. Where is my Fuel Filter on Accent 2000 GL
  146. Where is my fuel filter
  147. carburetor
  148. High Beams Stuck On
  149. Engine suddenly dies and doesn´t restart inmediatly
  150. How hard is it to Remove rear seats to get to speakers
  151. cd player removal? 2001 accent GSI
  152. 99 accent bucks, or jumps while driving
  153. Clutch Leaking Fluid
  154. lowering and wheels
  155. 1995 Starting Problem
  156. Engine noise
  157. ACCENT 01 brakes
  158. Auxiliary Emission Controls (P1403/P1402)
  159. P1128 Code
  160. summer tires
  161. sloppy shifter/rear struts
  162. Installing custom accent grill question
  163. Iat
  164. 2 or 1 oxygen sensors
  165. horn problems
  166. Accent low compression
  167. '98 Accent - Stutters after rain.
  168. Catalytic Conveter Cover
  169. where is fuel filter on 2001 accent 1.5
  170. Squeeky belt
  171. users experience
  172. 2001 Mysterious Brake Grinding
  173. 1999 Accent losing oil
  174. hub bearings and brakes
  175. 97 Accent Won't Start
  176. Help Check Engine Light
  177. Check eng. lt. P0138 P0141
  178. P0441 Check Engine Light
  179. bad fuel economy
  180. Accent 2004 ODB-II
  181. 1998 Accent - Removing Window Crank
  182. HELP! After reconnecting the battery, Accent won't start
  183. The Turbonator aaaaanyone
  184. 1999 Accent rust freckles
  185. where is my fuel filter
  186. Where is the Mass Air Flow sensor?
  187. electrical problem?
  188. engine swap
  189. Fuel Problem...can anybody help??
  190. heater/air vent problems
  191. 1997 hyundai accent body kits
  192. Performance 1.5L vs 1.6L
  193. Advice on buying a used Accent
  194. Accent quit shifting into overdrive
  195. Bad thermostat or vent problem?
  196. Tachometer
  197. clutch problems? please help!
  198. Check Engine Light
  199. P0303 Fix
  200. multiple misfire
  201. Wiper problem
  202. 96 Accent - transmission problem? help or advice?
  203. 1998 Hyundai accent Tranny problem
  204. Trouble Pumping Gas
  205. Check engine light-lean mixture code
  206. Brake problem?
  207. "Check Engine Light"
  208. where da e brake at......
  209. Brakes!!!!!!!!!!!1
  210. Rpm
  211. Making accent faster????
  212. Wiper problems..need help fast
  213. Buying a 1998 Accent - What should I get checked?
  214. Injection problem?? Please help
  215. 2000 Accent P1128 error code
  216. need help quick
  217. Removing Dash when installing deck in 05 Accent
  218. bigger brakes
  219. check engine light and air bag light are on!
  220. My Accent is slow
  221. 00 Accent - Wing Mirror Change
  222. Heater problem help please??
  223. I need help! 97 accent
  224. '98 Accent - Knock Sensor?
  225. Cargo Racks
  226. Strike 3 - Spark plug and wires question
  227. Fog lights
  228. 2002 accent gs- AIRBAG QUESTION
  229. Interrmittnet dies or no restart
  230. odd problem
  231. remote starter help
  232. Fuel Injector Cleaning
  233. body kit 4 sale and wheels
  234. Oil Change Question
  235. rev limiter?
  236. Overdrive Problem Automatic Trans
  237. Starting it up
  238. shifting hard
  239. TSB for Brake lights?
  240. Throwout bearing, how difficult?
  241. remote starter help
  242. 02 Accent Wont Start
  243. fuel filter location
  244. Accent interchange with Pontiac LeMans?
  245. motor try to stall, please help
  246. Check Engine Light
  247. tranny slipping to neutral
  248. Security codes?
  249. Misconcepions of Hyundai
  250. 02 accent for sale
