smoking battery
merlyncoso
07-16-2006, 03:35 PM
My 2002 accent recently needed a new camshaft position sensor. After replacing said sensor. The engine would not crank. There were no obd codes. the batter positive terminal did let out a little smoke. Here's where it is odd. If I disconnect the battery and reconnect it I can turn on the lights. When I try and start it the engine won't start and all the electrical components such as the light won't work. If I disconnect the battery again I can turn on the lights, unless I try and start it again. This sounds like a short in the wire to the starter, but it seems so weird that the car would "reset" each time the battery is reconnected.
A Jeeze
09-10-2006, 10:03 PM
it is very weird that it is doing that but there must be a short/slice in the main battery wire u should try replacing that and that will more than likly do the trick and all cars reset when the positive battery wire is taken off and put back on.
