crankwalk?
ooljima
09-07-2003, 01:31 AM
i dunno what that crankwalk is....... what the hell is it? i just bought my GSX.... i'm havin some high pitch noises that are annoying me........ and no.... it's not the turbo makin the sound when i rev it. it's the sound that a messed up TV makes.... can anybody help?
FourG63 97GST
09-07-2003, 12:11 PM
Never heard of it
Try searchin though, you may get lucky
Japmetal
09-07-2003, 01:26 PM
If you search this forum there's a post with an actual sound-byte of CW attatched; it's enough to send shivers down your spine, and it's not even something my car is likely to suffer from :-s
turbo2nr
09-07-2003, 03:25 PM
c-walk is when the bearings in your crak goes which doesnt let yor clutch in.. or sumthing like that
look at this:c-walk (http://www.magnusmotorsports.com/crankwalktheory.htm)
:wink:
1
Talon007
09-07-2003, 03:59 PM
Never heard of it
Me either :confused:
Japmetal
09-08-2003, 06:13 PM
Crankwalk is the Bane of the post-95 4G63 [when they changed the pattern of runways thru the block for the oilflow]
it is basically a condition where the crank bearing shells wear excessively due to oil starvation, allowing excessive movement in the crankshaft itself & in extreme cases the crank will actually 'slosh' back and forth in the block as the car corners [and can also rest against the clutch plates, making the clutch difficult to disengage]
Altho it seems to be fairly common among later DSM 4G63s, I've not yet heard of an Evo with this problem [altho I dont know why this is]
Anything else youw ant to know, you'll have to find yourself - it comes up often enough !
kjewer1
09-08-2003, 09:19 PM
Please poeple, dont post one cause of crankwalk like is the only one. This is how misinformation spreads. ;) Go to www.racingknowledge.org, DSM section, and read the sticky I put up on CW. I crankwalked 3 motors, and like to think I know a little bit about it... And for what its worth, of the 3 motors that CWed, not one of them made unusal noises ;)
zer0bot
09-10-2003, 02:06 AM
you walked three motors :eek7: wow thats harsh. my sincere condolences go out to you.
zer0 :sunglasse
kjewer1
09-10-2003, 05:23 AM
It builds character ;) I dont have a single regret. I learned a lot in the process, including how to do 6 bolt conversions, which has paid for a parge portion of my mod list :D
