View Full Version : 1st Gen 95-99
Pages : 1 2 3 [4] 5 6
  1. performance?
  2. 98 Plymouth Neon problem
  3. 2.0L sohc to 2.0L dohc conversion questions
  4. Piston
  5. Window Crank
  6. 95 Neon Ignition Switch Jammed
  7. 96 Neon Start Problem
  8. Exhaust question!
  9. Wired sandy metal noise when driving (95 Neon)
  10. 95 Neon Gauge Problem
  11. 95 Neon hard starts
  12. 95 neon won't hold a charge
  13. No AC in 97 Neon
  14. 92 Neon will not go in reverse
  15. 95 sohc rebuild
  16. 98 NEON running issue
  17. airbag and horn problems
  18. 95-99 neon question
  19. grounding hub install
  20. 95 neon
  21. 95 Neon Check Engine (Code 12,Code 21)
  22. Running
  23. Cruise Control, 1997 Neon
  24. Death of a Neon
  25. Safc Ii
  26. Head Gasket Help!!!!!
  27. wont turn over, need help with gauges too
  28. wont turn over, need help with gauges too
  29. 1995 code 43
  30. Please help me find a left motor mount (transmission) 1995 Dodge Neon standard
  31. exhaust question....
  32. compression
  33. 98 voyager motor into 2005 neon???
  34. TEMP Gage wacks out and my car doesnt start unless I tap the nut on the starter
  35. water looks muddy
  36. 99 Neon-CEL on and here's the fault code
  37. 99' r/t computer problems
  38. oil pans compatable?
  39. what do you guys think of my mirrors?
  40. 96 Plymouth Neon Won't Start
  41. 95 neon wont go over 55
  42. Don't buy the Pacesetter Exhaust
  43. it says to connect to parking lights
  44. '97 Neon's Paint Peeling Off !! --> Is this common?!
  45. 96 neon 5 speed clutch question
  46. 97 Neon transmission problem
  47. starter problems 95/98 dohc
  48. 98 neon CS help please!
  49. how much tranny fluid?
  50. little shock when i close the door
  51. reverse switch on a 97 Neon
  52. 95 Neon Dying Out Codes 24 and 31
  53. My 97 dodge neon
  54. Non Power accessories to Power
  55. Help...99 Dodge Neon
  56. 96 neon wont start (something with electrical) pleaaaase help!!!!
  57. Rockers and Lifters
  58. 97 dodge neon having overheating problem
  59. 99'sohc-loud tapping for 1 minute at start
  60. drilled slotted rotors
  61. 96 neon (service engine soon)
  62. 98 Neon will nt start
  63. 1998 neon auto help
  64. no back up lights
  65. Engine/transmission swap procedure help
  66. 02 delete
  67. engine timeing
  68. Porting intake manifold
  69. 96 Neon Trouble Code 72
  70. Window adjustment
  71. a few questions
  72. '95 Neon problem
  73. Battery box sensor
  74. Dies out after it starts
  75. Auto Tranny Valve Body replacement advice?
  76. Quick Neon Question
  77. What is that clunking??
  78. 97 dodge neon
  79. 95 dodge neon hard to start
  80. nitrous
  81. lol code 31?
  82. Motor building help
  83. I wants others opinions PLEASE! 98 neon rims..
  84. problems with my 96 neon expresso 4dr sohc
  85. defrost froze???
  86. Fixed headlights and now this....
  87. "Neon Knock"
  88. 96 neon won't start, blows fuel pump fuse
  89. Clutch problem on '96 SOHC
  90. transmission gasket, use or don't use?
  91. 95 neon engine shut down and will not start
  92. map+iat sensor question 95 sohc neon
  93. Anybody want a non-modular stage 3 clutch?
  94. plymouth neon tranny trouble
  95. code p0743 help!!!
  96. How do you torque the lugs???
  97. aluminum flywheel help!
  98. 95 neon fan problems
  99. possible pcm problems???
  100. damn f*ckin thing
  101. 95 neon flash out codes
  102. just started
  103. were can i buy cheap headers for a 96 sohc neon
  104. 95 Neon Sohc problem
  105. cooling fan operation
  106. I might be buying a 1998 Dodge Neon..Need your advice.
  107. Auto Tranny Trouble 98 sport (follow up, and question)
  108. What's the cooling capacity '98 neon SOHC?
  109. whats the thread pitch for lugnuts?
  110. '98 Neon with code C0000 and P0701
  111. Window Crank Removal... Stumped.
  112. Where to get instrument light bulbs? `96
  113. rear motor mounting assemblage on a 96
  114. Oil pan
  115. 95 neon problems
  116. HELP PLEASE!!! 96 neon tranny trouble
  117. DOHC motor swap
  118. DOHC and SOHC crankshaft????
  119. Neon Springs
  120. Rim question
  121. Anybody install a Fidanaza flyweel?
  122. Turbo kit help
  123. Door Seals
  124. 97 neon won't start
  125. 98 expresso 2.4 swap
  126. (Window Seal) Sorry about the mutliple Posts!!
  127. 98 Neon rear disc conversion.
  128. Auto Tranny Trouble 98 sport
  129. Buying 1998 Neon: Anything I should look out for?
  130. T&D code trans question
  131. Need some tech help!!!!!!!
  132. would a eclipse GS-T engine fit in my 95 neon
  133. Msd
  134. 2.0l sohc damper wornt come off
  135. headlight conversions?
  136. I think it finally died!!!!
  137. Quieter Exhaust for 98 Neon Sport
  138. Right Fog light that almost never works.
  139. 98 Neon Sport problems
  140. Exhaust
  141. 97 Dodge Neon 16 vavle keeps dieing
  142. 1995 neon transmission
  143. 96 neon problem list
  144. 1st Gen Neon manual transmission stuck. Am I screwed?
  145. Hard Starting
  146. right turn signal not working........
  147. Does neons set off the oil light if it gets low on oil or just when pressure drops?
  148. performance garages? CAI?
  149. Lean Fuel Mixture on 96 Neon
  150. I took my '98 Neon
  151. 98 neon tranny trouble
  152. ditching the a/c
  153. 95 Neon
  154. Engine Noise after water pump replacement
  155. 98 sport, no start.
  156. Hard to start
  157. Neon/Avenger engine interchange?
  158. Does anyone know of a way to clean stock....
  159. 1995 Neon Cruise Control
  160. 98 neon sport
  161. put a fart can on
  162. Rack&Pinion for 98 Neon
  163. what kind of turbo?
  164. ground problem
  165. clutch fluid?
  166. Gauges don't work at all
  167. 95 neon wont start need help code 35...42
  168. She'll just die
  169. 95 neon fuel pump or wiring problem
  170. 97 neon burnout!
  171. Muffler Question
  172. where is the fuse for the ciggerate lighter?
  173. no more problems...again
  174. Neon "Projector" headlights
  175. steering problems
  176. 99 Plymouth Neon Car is Knocking/ Shaking
  177. intermittent stalling when cold,code 11
  178. transmission sludge
  179. Just boughta 98 Neon
  180. 1996 Neon starting problem
  181. 95 neon starting troubles
  182. 97 neon starting trouble
  183. power chip question
  184. Dash Needles Not Working Properly
  185. transmission fluid
  186. Doing swap will this work???
  187. Need Help.. Rad fan not kickin in
  188. 97 neon pcv valve how to
  189. Front end question
  190. dead neon, and i'm confused
  191. no more engine problem!!!!!..thanks everyone
  192. Auto start on a 1996 Neon
  193. Engine problems
  194. ebay short throw shifter
  195. 95 neon no accelleration
  196. 96 plymouth neon engine swap
  197. new head?
  198. 98 Neon Crank Pulley
  199. Hahn turbo kit
  200. 96neon pcm ?
  201. PCV location 96 neon
  202. 96 PLYMOUTH neon problemS
  203. Headlight switch
  204. motor bulid
  205. clicking noise
  206. Headlights won't turn off
  207. 99 neon multiple misfire HELP
  208. Neon doesn't start.
  209. 2004 srt-4 turbo/1998 2.0L neon
  210. Speedometer not working
  211. 95 neon turning problem
  212. Underdrive Crank Pulley
  213. 2.0 interchangabilty with 2.4
  214. 1997 plymouth neon engine noise
  215. Motor reving
  216. Reader's Opinions - '97 Ply Neon - Opinions of car?
  217. Neon motor build
  218. 97 Neon will not start
  219. 96 Neon sohc intermittant no start
  220. 95 Neon auto transmission trouble when cold
  221. 98 Neon 2.0 DOHC Starting Problem
  222. Transmission swap question
  223. 97 neon problem
  224. 96/srt-4 Turbo Engine Swap Help Please!!!!!!!!
  225. Thinking About Buying 1997 Neon - Help!
  226. 2.0 turbo vs 2.4 turbo swap
  227. 2.2 turbo II turbo and wastegate??
  228. first gen intake manifold
  229. Motor Mount Question!
  230. bottle question
  231. 1995 Dodge Neon!!!!! Help!!!!!
  232. Turbo interchangeability
  233. EGR Valve replacement
  234. My neon Spudders
  235. 96 neon engine swap
  236. 2.0 non turbo
  237. 95 neon bubbling reservoir
  238. Subing a Neon
  239. 99 rt engine swap question
  240. 1999 Neon shakes & jerky at 50 mph
  241. what does sohc and dohc stand for?? which do i have??
  242. A Few Neon Questions
  243. 96 Neon AT, Help, Reverse Lights Out
  244. 98 Neon with a stall problem
  245. 96 neon brakes
  246. My neon spits and gurgles
  247. 95 sohc to 98 dohc acr swap, problems please help!!
  248. 1996 Dodge Neon won't start how do I remove the starter
  249. 92 mitsubishi eclipse-is it easy to swap out a SOHC 1.8 with a DOHC 2.0/ or TURBO???
  250. performance intake manofold?
