1st Gen Neon manual transmission stuck. Am I screwed?
neoncbd
01-11-2006, 11:34 PM
My 98 Neon all of a sudden won't shift. When I try to shift from 1st to 2nd, the transmission is stuck (can't get into 2nd) and I have no gear. Car won't move. Meaning it is not even in neutral..
How do I check the manual transmission fluid level? Must I go under the car to check?
How big of a trouble am I in? I don't think manual transmission is a common problem w/ 1st generation Neon. But I might be wrong. Am I looking at a $1000+ bill?
das2123
01-12-2006, 07:57 AM
How do I check the manual transmission fluid level? Must I go under the car to check?Yes, I think the fill plug is on the driver's side of the tranny and the fluid should be within 3/16 of an inch from the bottom of the tranny fill hole. Make sure the car is level when you check it.
How big of a trouble am I in? I don't think manual transmission is a common problem w/ 1st generation Neon. But I might be wrong. Am I looking at a $1000+ bill?It's not a common problem, but the amount of trouble depends on how well you have treated the tranny. You could always just swap in a new or used tranny for about $100-$200 for the tranny.
neoncbd
01-12-2006, 11:20 AM
Suppose the tranny is leaking and out of oil. Would it cause the problem I mentioned? All of a sudden stopped working while driving?
What oil should I add for a manual transmission?
das2123
01-12-2006, 12:30 PM
Suppose the tranny is leaking and out of oil. Would it cause the problem I mentioned? All of a sudden stopped working while driving?Low fluid will give you all kinds of problems...
What oil should I add for a manual transmission?Make sure you use the A578-specific semi-synthetic fluid (p/n 4773167) that's available at the dealer. It is specifically matched to the synchronizer material for good shifting, and has special friction modifiers to last a lifetime.
