95 dodge neon hard to start
skatendestroy
02-26-2006, 07:32 PM
This problem has got me on my neon if i go out and i try and start my car for the first time of the day it is a rediculous task to do. I have to give it gas and it will want to start. it will start but then just die off in like a second I have to give it gas to get it to start. Now I have recently replaced the egr to see if that fixed the problem but it didnt. I can hear the fuel pump turn on when i go to try and start the car.
I have recently switched my metal gas tank to the plastic gas tank from my 98 parts car i also switched the fuel filter from it aswell. I am not getting any code thrown and once i first get it started. I dont have a problem with it for the rest of the day. when i first get it started i have to let it rev allittle and then it will be fine but its al lilttle boggy at first. but then its fine. there isnt any acceleration issues. when I rev it high and it drops off after I let off the gas the motor will maintain itself and not bog out. also
so im lost lol
das2123
02-27-2006, 07:53 AM
When I had a problem like that, the battery was slowly dying on me. One day it completely died, put a new battery in and no more problems. I'd check for corrosion on the wires and/or terminals and under the battery tray.
skatendestroy
02-27-2006, 06:14 PM
its a brand new 650 amp battery. it been relocated to the trunk with a 2 gauge wire running from front to rear. but aperntlty the problem has disapeared when I put gas in it yesterday. I wonder if there was water in the gas in the tank:rolleyes:
das2123
02-27-2006, 08:05 PM
I wonder if there was water in the gas in the tank:rolleyes:Then it would be in yur filter now! Could have just been a bad batch of gas like you said though. Keep an eye on it just to make sure.
BlazerLT
02-28-2006, 12:02 AM
The filter assembly is different for the 1995 and the 98.
The 1998 has the filter in the sending unit. The 1995 has a separate filter outside of the tank. Two different systems.
On the 1998, the outside filter like thing is not a filter, it is an accumulator. If you swapped that into your 1995, that will cause you problem.
das2123
02-28-2006, 01:47 AM
If you swapped that into your 1995, that will cause you problem.Where would the problem be?
BlazerLT
02-28-2006, 01:51 AM
If he swapped the accumulator thinking it was an external filter which the 1998 does not have.
das2123
02-28-2006, 07:50 AM
If he swapped the accumulator thinking it was an external filter which the 1998 does not have.He swapped the whole gas tank though...
http://www.automotiveforums.com/vbulletin/showthread.php?p=3832923#post3832923
skatendestroy
02-28-2006, 08:56 AM
yes i switched out the whole entire gas tank the fuel filter on the 95 has three connections and the accumulator on the 98 only had two so i was forced to switch it over its the exact same setup just a different car.
BlazerLT
02-28-2006, 01:46 PM
Have you checked fuel pressure yet?
