View Full Version : 1st Gen 95-99
Pages : 1 2 [3] 4 5 6
  1. Car won't start - Alarm system at fault?
  2. Owners Manuel - Gas tank size
  3. water pump
  4. sun roof/moonroof needs fixed
  5. 99 neon and has no acceleration
  6. Crankshaft Pulley Bolt
  7. Anyone have an Engine for a 97 Neon?
  8. Fuel gauge and service/maintenance
  9. Overheating Neon ???
  10. Code 42
  11. overheating ???
  12. Gauges are acting funny
  13. need tail lights for 98 neon
  14. Just got a Neon and have some questions
  15. engine problems
  16. Oil Leak
  17. 98 plymouth neon engine codes
  18. stalled. now cranks, no start
  19. Supposed Timing problems..... a tad lengthy.
  20. 96 Dodge Neon dies after warm-up
  21. No start after engine rebuild...
  22. Automatic neon drive problem
  23. 97 Neon not starting
  24. HELP !! Can you covert a sohc to dohc?
  25. Newbie Neon ? - Clutch spring has come off!
  26. Auto Dynasty
  27. Headlight lens cleaner
  28. Cold air intake that looks like the iceman
  29. 1998 Plymouth Neon
  30. neon help
  31. neon help
  32. Do struts have fluid in them? Or are they gas filled? And yes, I know...
  33. Cold air intake
  34. Radiator replacement 98 Neon
  35. 99 plymouth neon fan belt
  36. coolant codes on 95 neon
  37. no results
  38. Rear Strut: Do I Throw The Car Away Now?
  39. Fuel problems...
  40. where is it?
  41. 96 neon coolant leak
  42. PCM issue
  43. Alternator upgrade
  44. Starter
  45. OBDII code p0401
  46. Question???
  47. For Sale 2 Neons
  48. just a few questions
  49. 1995 Stabilizer bar Came Apart on Freeway
  50. looking for a neon as a project car
  51. 97 Neon left rear brake locked up
  52. 1999 ply. neon code 42
  53. Axle Replacement
  54. Manual transmission fluid??
  55. engine help
  56. helppp wiring probs!!!
  57. Needs a 16v dohc for 98 neon sport
  58. Narrowed down
  59. anyone?
  60. SRT 4 Turbo package on 1st gen
  61. My kid has one now I want one too!
  62. 1995 2.0 engine swap
  63. hot cams for dohc?
  64. Cat
  65. I need a fuel pump . . . i think
  66. Neon Power??
  67. A new problem
  68. I have a few questions about my 97 SOHC neon
  69. 97 dohc to 96 sohc engine swap need help
  70. 95 Standard SOHC Engine Pinging
  71. Alternator
  72. crack in the block
  73. Help!
  74. what would you do.?
  75. 95 neon sputters in mid-range
  76. turbo setup question
  77. lowering springs
  78. Fuel Fuse Issues, 1996 Dodge Neon
  79. please help me
  80. neon 95 question
  81. My floor's all wet.
  82. coilovers
  83. Getting a neon
  84. My car won't start.
  85. eyebrows
  86. dimmer switch?
  87. Idle speed??
  88. Alternator bearings
  89. Overheating fuel pump?
  90. help me please
  91. All kinds of ugly . . .
  92. headgasket
  93. vogtland
  94. Coil Pack replacement? Sputtering.
  95. wont start need help
  96. Engine dies
  97. i hate robbers lol
  98. '98 Neon for sale: $2,500 OBO
  99. Gauges don't work
  100. Pulley?
  101. gauges
  102. 95 shifter question
  103. Easy way to Remove airbox from my DOHC 97?
  104. rms question
  105. Please help!!!!!!
  106. Dynamax or Magnaflow Exhaust
  107. neon won't run after warm up
  108. Looking for oem cams
  109. Steering squeal
  110. Swap sohc 16v for dohc in 97 manual tranny
  111. 1997 speedo help
  112. Cam Gears, Magnaflow Exhaust
  113. Yet another starting problem...
  114. Won't Start. Pops into neutral
  115. looking for a place to get dyno tuned. pittsburgh area
  116. need help
  117. Neon main seal
  118. 1999 ply. neon SOHC cam position sensor
  119. Please help, runny funny, key flick code
  120. new car stereo blows a fuse.
  121. 96 Neon Sport Fuel Sending Unit
  122. 98 Neon missesd at idle
  123. car turns off
  124. Friend in wreck, need new hood.
  125. cranks no start
  126. 96 Neon Sport Diag Codes
  127. 96 Neon Sport gas gauge problems
  128. RPM's slow to back off between shifts.!
  129. 1st Gen FAQ's
  130. 99 Neon DOHC won't start
  131. Woohoo I fixed the radiator!!
  132. Battery light on dash!!!!
  133. freebies?
  134. 95 neon code 44
  135. torque spec
  136. rocker arm torque 96 neon?
  137. turning right what the f*ck
  138. Crusie Control
  139. Where Do's This Ground Wire Go???
  140. crank
  141. 1998 Neon Rad Fan not coming on
  142. So I had to repair the radiator...
  143. wont start need help
  144. neon doesnt want to shift right away
  145. 97 neon dies randomly code 12
  146. headlight bulbs...
  147. 95 clunking noise and wheel play...
  148. Check Engine Light & Hesitations
  149. code 72
  150. Suspension issues
  151. Self Radiator repair?
  152. car stumbles then dies
  153. turbo questions!!
  154. 1999 neon highline shoc
  155. Quick neon question for a friend
  156. 96 neon trouble codes
  157. stealth .... neon??
  158. Alternator replacement
  159. water pump replacement
  160. car shuts off/ only starts sometimes
  161. Injectors
  162. would this work??
  163. Need some advice...
  164. What is best way to get to alternator?
  165. Codes after timing belt change
  166. New front, left axle options; help me decide
  167. where is torque converter solenoid located?
  168. tourqe converter lock up
  169. 1997 Dodge Neon - Crazy problem, dont think any1 is goin 2 know what 2 do but plz try
  170. 97 Dodge Neon Tie Rod
  171. srt4 exhaust
  172. Bad ECU, 97 Neon.
  173. 95 non ac radiator (half sized)
  174. pimping a 96 neon
  175. Has anyone done a SOHC Magnum head swap?
  176. Need to change the Front Strut Mounts
  177. Fuel System Problem
  178. 1998 Noen Going Bonkers!
  179. new project
  180. radiator fan relay?
  181. the longest lasting brake pads
  182. neon 97 wheels over heating melting hubs
  183. 95-98 engine swap
  184. 1995 front wheel bearing suggestions
  185. switch in the ecu
  186. problems?
  187. 2.4 swap help?
  188. fuel pump?
  189. 96 neon help
  190. Bad Efficiency
  191. DIY 3.0L Intake
  192. Help Me PLEASE My Neon Shifts hard
  193. Clicking and grinding on the front end
  194. Neon Engine issues
  195. help!!!!
  196. yeaaa.. emissions and exhaust problems
  197. removing hand brake
  198. Mopar gear oil for 1995 Dodge Neon is expensive!
  199. 95 Neon Surges
  200. Cylinder #2 not firing
  201. Suggestions for rough running 1996 plymouth neon
  202. 1996 Dodge Neon Transmission
  203. transmission troubles
  204. oil around #4 sparkplug
  205. exhaust....?
  206. Mopar Performance PCM
  207. Problems with overheating
  208. Problems after 60k maintenance
  209. HELP!!98 Dodge Neon SPORT DOHC; where are the timing marks
  210. 97 neon Code questions
  211. How do I replace my starter?
  212. Radiator Fan Problem
  213. i have a 2.0 sohc and i want to swap with a srt4 neon engine
  214. Overheats when air conditioning is on
  215. Overheating when engine off..weird
  216. I drove my Neon for the first time in 16 months!
  217. Just got my Neon
  218. Rebuilt Motor Leaking From Head - Why?
  219. would you use this??
  220. neon, cooling fan(s) continue to run
  221. 97 plymouth neon will not turn on to start
  222. Installed new Clutch Cable! HOORAY!
  223. How to Replace 2.0 DOHC EGR Valve
  224. problem when driving
  225. 99 Neon Overheating on hwy
  226. awww my poor baby
  227. 98 ac problems
  228. Worth racing an ACR Neon?
  229. Looking to get a Neon
  230. Help! Problems after clutch install
  231. 1999 Neon DOHC Problems
  232. 1998 inconsistent starts
  233. 96 Dodge Neon shifting problem
  234. 1997 Dodge Neon SOHC radiator fan relay
  235. Irregular engin activities and engine codes
  236. Dead gauges .... speed, gas and temp all read zero no matter what.
  237. head bolts ??
  238. Unknown connectors Dodge Neon
  239. Anyone having problems with their Speedo?
  240. no ac compressor or power steering
  241. misc gen 1 parts for sale
  242. 1998 Neon A/C doesn't work - Need Help!
  243. 98 Neon water pump and timing belt
  244. gear problems
  245. What goes on end of clutch cable?
  246. Wiring Halos
  247. neon reliability?
  248. 98 Neon Trunk Light
  249. Ignition Lock Cylinder
  250. Removing stock tape deck from 98 Neon
