View Full Version : 1st Gen 95-99
Pages : 1 2 3 4 5 [6]
  1. 95 neon shift trouble
  2. 96 SOHC running rough?
  3. 96 SOHC running rough?
  4. 1999 neon oxygen sensor
  5. 95 transmission question
  6. 95-99 Tail Lights
  7. 99 wiring headache
  8. 1996 Neon - reverse lights/hazards?
  9. 2.0 to a 2.4
  10. 97 cluster swap
  11. 98 ACR strut upgrad questions
  12. 96 Neon, Elec Cooling Fan Relay
  13. 1995 Tps
  14. 1996 Dodge Neon Head Gasket question
  15. I Need Help - 1995 Neon
  16. 95 Neon Radiator Fan
  17. 98 neon sunroof
  18. 95 neon has problems
  19. Where is the EGR valve on 95 Neon?
  20. 99 neon codes?? 72
  21. 96 Neon
  22. 97 Neon Code 35 Radiator Fan
  23. 96 sohc neon dies on highway only
  24. 97 Neon Speed Sensor / Odometer
  25. 2.0 dsm swap,ever been done before?
  26. 4th & 5th Gear pop out while driving
  27. Speakers
  28. 95 Neon- my endless $ pitt.....
  29. 95 Neon Engine Light....anybody have the codes??
  30. 98 Neon R/T Questions...
  31. can I put dohc head on sohc engine?
  32. Water Leak in '97 Neon
  33. Code 25 Neon 95
  34. 95 neon timing belt urgent question
  35. 95 Neon Problems
  36. standard radio removal from a 95 neon
  37. ?'s on Head Gasket
  38. 1995 Neon - Code 43
  39. 1996 Neon >>> Stereo Question
  40. 96 neon radiator fan won't shut off
  41. 1995 Foglight Bulbs
  42. 95 Engine Swap
  43. 97 headlight prblem
  44. Neon instrument cluster troubles
  45. '95 Plymouth Neon Error Codes
  46. 98 Neon Axels?
  47. Howell Crate engines
  48. turbo on automatic?
  49. 1st gen Neon diagnostics codes
  50. 99 dodge neon tranny problem
  51. 1995 neon shakes when driving
  52. NEON 95 cranks, but will not start. Please help
  53. 98 Neon-Transmission Problem?
  54. 99 Dodge Neon Loaded, CF hood, bdy kit, more MINT!
  55. oil pan replacement
  56. '97 neon knocking --car problems
  57. 95 Plymouth Neon
  58. neon's transmission
  59. 97 Neon Starting Problem
  60. 97 neon
  61. 97 dodge neon
  62. 1st gen DOHC timing pics
  63. timing belt
  64. Clear Third Brake Light
  65. 98 neon stock turbo
  66. 5 speed conversion
  67. 95 neon problem?
  68. ***Just bought xenon bulbs and need help***
  69. 96 wondows ratteling
  70. 98 neon wires?
  71. '95 Neon 'Check Engine' light on
  72. 95 Neon engine swap
  73. I have a 1996 Neon
  74. Speedometer not working???
  75. 97 Buick Speedometer Jumps while in park
  76. Mattz Neon... And it continues...
  77. NEED HELP PIMPING OUT MY 97' NEON....any suggestions? NO WEAK SHIT EITHER
  78. Window Noise
  79. Accessories for the 95-99 Neon
  80. 97 neon overheating........
  81. 95-99 Neon Intruder Body Kit...
  82. Metallic Floormats on the 95-99
  83. 98 neon.... timing belt???
  84. Fuel Efficiency
  85. Help Please?!
  86. advice: buying 95 neon highline
  87. Enigine Swap
  88. 95 dodge neon stalling
  89. dodge neon sport
  90. hey guys im looking for a euro-kit for my neon anyone got one???
  91. help
  92. Another Tire Question
  93. anyone have reliability problems?
