View Full Version : Sentra | 200SX (USDM FWD)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. B13 Sentra Ignition Problem. Please Help.
  2. Mazda 3 Vs. Spec V
  3. Can anyone help me find specific rotors?
  4. Windshield Washer Pump
  5. carb to tbi
  6. Help
  7. 1987 nissan illustrated parts breakdown
  8. knocking sound
  9. Shifts harder after longer drive w/ air
  10. Sentra will not idle
  11. Nismo Lower Tie Bar
  12. Question about my clutch
  13. I just got an 87 Sentra...
  14. brake pads replacement guide for NIssan sentra 96
  15. Crank position sensor
  16. will it fit????
  17. For Sale: VQ35DE Throttle Body
  18. engine swap
  19. For Sale on eBay
  20. Installing amp/subs with factory fosgate system
  21. Cold start and hesitation
  22. help with some issues
  23. Discontinued OEM parts
  24. Vacuum Hoses
  25. Update to Steering Problems
  26. Ignition switch replacement?
  27. 87 nissan metallic rattle during operation
  28. help on usdm 96 200sx se-r swap
  29. Grinding sound between gears (Spec-V)
  30. My new project
  31. Differences between B13 and B14
  32. Nissan Sentra upgrade ideas . . .
  33. LMFAO Carbon Fiber Film
  34. Spec V After market/bolt ons
  35. Steering Problem
  36. For Sale... 02-05 Nismo Lower Tie Bar
  37. im startin to get depressed....
  38. how to remove c/v shaft from trans?
  39. spec-v and srt-4
  40. Idle Re-Learn and ECU Codes for Spec-V Make Sticky!!!
  41. SE-R Automatic Engine put into Manual Spec-V read
  42. where's that one thread part 2.
  43. Back bumper dent and trunk won't close right!
  44. a/c problems
  45. removed balance shaft question
  46. aftermarket tail light for spec-v?
  47. silencer on catback question
  48. Short shifter on B13 ga16de
  49. 1999 Sentra SE-L Problems...be gentle, first post!
  50. SE-R Engine into a Spec-V? Answer this for me
  51. Spec V tires
  52. For Sale - Factory CD Player 2005
  53. Muffler rust
  54. Grill Painting
  55. Catalytic converter
  56. Grill Painting
  57. Grill Painting
  58. Huge problem, possibly transmisison
  59. Spec V Lowering
  60. Rattle under hood 96 Sentra
  61. 95 Sentra Ignition Noise on the radio
  62. Anyone own a Sentra 1.8S Special Edition?
  63. PARTING OUT Nissan 95 200sx GA18de (typo)
  64. 200sx parting out 1995 CA18de
  65. 4 to 5 lug
  66. Car Makes Clicking Noise When Going Over Dips
  67. FS: Hotshot header 2.0 L 94-99
  68. synthetic
  69. help
  70. 1.6 head replacement
  71. automatic to manual
  72. My 97 Nissan sentra gxe for sale
  73. Buying 92 Sentra - No start
  74. Anyone had a P0420 code??
  75. INTAKE PROBLEM- Need Connections
  76. need bolt on HP
  77. Retrofitting A/C
  78. sr20DET problem in my b13 sentra
  79. 92 sentra help pls
  80. Dropzone springs for budget B14?
  81. A/c Problems Noooo!!!!!
  82. Front End Damage
  83. lug nut screw broke off
  84. I am about to buy a 93/94 SE-R for $500!!
  85. cleaning headlights
  86. most original swap.....ever
  87. 06 SE-R Spec V OEM Radio/Cd Player For Sale
  88. B13 silencer...
  89. sr20 swap
  90. Recharging air conditioning
  91. oxygen sensor
  92. my sentra seems to be giving me some serious problems
  93. 1998 Nissan Sentra GSE won't start
  94. 95-99 Sentra?
  95. Lookin at the Sentra or 200sx
  96. Sounds like a loud knocking
  97. Yes, back again for help.
  98. No Compression
  99. shaking
  100. Replace cv axle on a 1996 200sx
  101. Adding refrigerant to a/c myself
  102. Can't get my right brake rotor off
  103. side skirts for a b14/96 sentra
  104. help with parts
  105. 91 Sentra, transforming, any tips?
  106. Need Parts
  107. Need Parts
  108. Need Parts
  109. newbie- question re: bomz short ram
  110. Sentra's can take a hit.
  111. SE-R SpecV
  112. wheres that one thread?
  113. door hinges
  114. coil over
  115. headlights not working
  116. sunroof
  117. engine swap
  118. fenders
  119. Starter went out on my '00 Sentra SE
  120. 98 200sx 1.6l engine swap plz post input
  121. 97 GXE No Power/Whine/Shaking
  122. More mpg?
  123. manually driving me nuts
  124. Mods for a 2001 sentra xe
  125. Engine Swap Help
  126. Synthetic Oil
  127. Searching Desperatly For A 91-94 Ser
  128. Short Ram Intake System Help
  129. Engine sound help
  130. Interior
  131. Exhaust? Any Suggestions?
  132. engine swap 1.6 to a 3.0
  133. what transmission to use?
  134. driving lights
  135. Alternator or Battery?
  136. Aftermarket installation problem
  137. Factory Speakers
  138. 91 Sentra Stalling
  139. In need of a Cluster
  140. Injen Intake?
  141. 200 SX/Sentra won't start?
  142. Nice headers
  143. stock pipe
  144. Tokico HP's and after market springs....
  145. Fugiot, i really need your help on this one : engine swap
  146. Gas Mileage, '91 E
  147. 87 sentra
  148. water pump going??
  149. 1996 200sx se Power Lock Problem
  150. Aftermarket Steering Wheel/Airbag Q?
  151. replacing timing chain on 93 sentra
  152. Tire recommendation
  153. Tein SS damping force
  154. How to change center brake light on a Sentra?
  155. Fault code PO171 system too lean
  156. Ecu
  157. ecm location
  158. Parting Out 92 Ser
  159. how reliable are sentras?
  160. 94 sentra left high beam doesn't come on
  161. What's your dream FWD Nissan?
  162. Recently Purchased 91 Sentra
  163. Remove Fuel Pump?
  164. 4.0 whaaaat
  165. FAQ Possibility
  166. 205/55r16
  167. Service Engine Soon Loght on Sentra.
  168. Purchase Opinions
  169. NEeD help with wiring headlights
  170. Roofracks for 1996 Sentra wagon?
  171. Fuel tank
  172. 92 nissan sentra
  173. Starting issues
  174. Spec V years
  175. 525hp b15.....
  176. trunk vibration
  177. 92 Horn doesn't work
  178. How many miles???
  179. Tachometer.
  180. random skipping
  181. i got Questions on upgrades
  182. my se-r if funny!!!!!
  183. 1996 Nissan Sentra disappearing oil
  184. RE turbo on a QR25
  185. Rumor has it...
  186. Sentra OIL?
  187. exhaust
  188. Sentra electrical quandary
  189. aem cai
  190. Precat on the outs?
  191. nissan sentra 1993 IAT sensor LOCATION
  192. rims for sale!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  193. acid?
  194. Temperature Gauge
  195. Rim Size Question
  196. Speed Sensor Question
  197. need opinon
  198. Fuel filter?
  199. Alternator Short?
  200. CV Joint
  201. shipping a trans
  202. Bolt Pattern Check
  203. Strange Alarm Problems??
  204. SE-L 15'' Rims
  205. ALARM question
  206. remote starters
  207. Low Oil Pressure on 44k Engine
  208. Service and struts for stock 96 GXE 1.6 cc auto
  209. Squeaking sounds...
  210. nissan starter help
  211. Nisssan Sentra SE R Spec-v
  212. No Heat/AC 92' se-r
  213. Upgrades and Replacement Advice
  214. rad
  215. 205/50/16?????
  216. 1997 Sentra -Service Engine Soon Light
  217. 93 grand am fuel injection
  218. ok...im lazy and dont wanna pay to install the subs...
  219. JWT popcharger or CAI?
  220. Where can i find this piece?
  221. problem with 2004 sentra
  222. Audio Question
  223. reverse
  224. fried rice
  225. Check Engine Code: Exhuast Gas Line
  226. dimensions of 95-99 grill/headlights/corners
  227. Great Parts Car
  228. Cai For An 06 ?
  229. GA16DE or SR20
  230. Sentra spec v( turbo or 3.5)?
  231. 97 sentra code P1147 Aux. Emissions Cntrl
  232. battery being drained?
  233. 1995 200sx se-r
  234. Fastest B15 Sentra Ever!!!
  235. Another check engine light problem.....
  236. another sentra
  237. speedometer
  238. oil pressure dropping
  239. a danger in Sentra (..a woman :))
  240. Spec-V vs GT 5.0 Stang
  241. Sentra Light Switch Broken
  242. 1992 sentra XE
  243. 1994 sentra xe with some major problems.help!!
  244. fuel/air controller
  245. Surge around 5000rpms?
  246. Sentra README! Make sticky!
  247. Differences between 2003 SE-R and Spec V?
  248. Before swapping sr20...
  249. about Sentra....
  250. B13 Fuel Consumption very high :(
