Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Nissan
> Sentra | 200SX (USDM FWD)
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
93 sentra problems
Car dies when on idle in the morning.
how do i improve horsepower on 2007 Sentra 2.0?
vacuum hose diagram,00 sentra 1.8
Power Window Relay Help
Cruise Control Not Holding Speed
2008 Sentra - Larger Oil Filter ???
WTF! My 2000 Sentra Did NOT Pass Smog
Power door lock - defroster - interior lights, Not working =(
car makes white smoke but not overheating
Need help reattaching the side mirror
96 200SX SE Auto Timing Belt issues
2003 spec v head bolt torque value
04 Sentra right front rattle/noise
Wtf?
99 Sentra engine rotates but will not start
Did Nissan offer a NISMO edition of 2003 Spec V
whistle sound when turn on and off
hydraulic lifters
93 Sentra charging issues
Flashing O/D light
96 common a/c problem=??
cut the 96 cat converter=??
Turbo?
Inside Door handle bent
Is this true?
2006 Sentra Radio Help Sirius Radio Hook Up?
Sentra project
2004 sentra se-r spec v stalling help!!!
Pilot Bearing Repair - Shop or home mechanic?
Overheating!!!
Window freaking out!!!
2002 nissan sentra gxe key won't turn in ignition
How can you figure out what CAT is going out?
HELP!!! Sentra 2001 ECU Problems
Gutless 97 GXE, can't figure it out
Gas Grade Question
nissan sentra hard starting
Cruise Control
turbo sentra?
Front end vibration
91 sentra AT shift issues
Revs Drop and Engine Stalls Out???
An Absolutely Hilarious Story!!!!!!
clutch issues after a 4 wheel replacement and front end alignment
97gxeMT 1'st gear wont work
Engine Squeal!!!!!
New Sentra SE R torque peak...
Cam gears reverse thread?
87 Sentra Q:
92 Sentra Govenor Gear?
head swap?
Wtf!!
Headgasket issues perhaps?
Knocking in front suspension
2001 sentra 2.0
Nos
2005 transmission flush *need advice/info*
Bolts for caliper bracket
kaminari body kit
'03 Rear Brake Question
96 Sentra alternator draining battery
FYI: Brake lights and Cruise Control not working
2000 Sentra SE 2.0 Engine Idle problem STALLS OUT!!! HELP!!!
Bogging Down
Bogging Down
96 200SX Won't Start
1991 Sentra
1991 Sentra no start
hard starting
01 Sentra SE Idle Fixed
air intake problems
2005 nissan sentra 1.8l problems
01 Sentra Won't Start
Idle Problem - Sentra SE 01
O2 sensor on 96 sentra
Fuel Filter Flow Direction
Any idea of what this sound it?
programming keyless remote.
Please help!!!
2002 Nissan Sentra engine dying.
94 Sentra Help
04 sentra factory radio question...PLEASE HELP!!
Tires Sizes and Suspesion Kit.
Stalling only during idle...
HELP for a 1999 Nissan Sentra
Idle , hesitation problem 2000 sentra
I need another Ga16
thread size on ball joint nut?
Are new wheel bearings necessary when installing new axles?
FS Cams + WRP Variable Exhaust Cam Sprocket
2007 se r
B13 Injectors
Need Help My Only Car
Launch control
Launch control
Stripped Spark Plug ?
Remote Keyless
wheels spin when accelarating full throttle
Sentra "freezes up" - Please help!
2001 Nissan Pulsar(Sentra)Aircon HELP Please!!!
t3h shennanigans thread
1991 Nissan SER half shaft
Code P0183 Fuel Temp Sensor??
1999 sentra 1.6 wont start
SE-R rim advise
Overheating/out Of Oil
driver's side mirror popped off
Resident Technician
Shifter boot
tranny doesn't shift outta 1st
A Few New Pics
1.6 sentra racing fuel rail
Not sure what this is.
new to nissan
Stock Steel Rims
Gauge faces...
Service Engine Soon - Air pressure in gas tank
nissan sentra miss out
91 sentra coupe 1.6
Oil dip stick broke off
How Do you Turn Off the CEL Light
water leak
wont stay running...
1990 sentra performance help
Nissan Sentra SE 01 Fog lights
92 sentra 1.6 swap to sr20de
Belt issue . . .
Problem Starting.
Leaky windshield glass/roof
2003 Sentra question: Low fuel Pressure
Opinion's Please
Should timing chain be replaced?
Short Ram Intake for SpecV?
Knocking Sound in Right Front Wheel
Rust Prevention/Undercoating
Need help with power locks
FS:02 Spec V in socal
1998 Sentra GXE: Replacing speakers, stereo, maybe fan switch.
Atf level----does anyone know?
turbo spec-v help
1998 nissan sentra trans slipping. Please Help
1994 Sentra coolant system (1.6)
Help
need help with a name
bogging
SES light
help
problem with head lights
96 200SX SE-R Motor Swap
2002 Sentra with stays at high rpm
gas gauge goes up and down
Bump......
Blower Moter Resistor...
Scraping Sound
2001 Sentra. MIL/DTC falsely condemn O2S. Why?
help needed with 2000 nissan sentra
Looking to buy '02 Sentra SE-R
2002 Starting Issues
The rack?
Strut Problem ~I Think~
93 Sentra Starting Problem
torn cv boot
Cobra Maf 65 shipped+3% PayPal
50lb MSD injectors 180 shipped+3% PayPal
rear motor mount
Turbo Kit for the 1.6L ?
Eating brake pads and discs: 1999 Sentra GXE
Recently Purchased Used 02 Spec V, Questions
For Sale: exhaust parts
i have a nice blue nissan
96 sentra sputter/shake
95 Sentra Power Steering Return Hose
Sentra timing chain
Purchasing question
Muffler Smaller than exhaust
Short!
94 XE - White smoke comes out of exhaust
Help Me Make A Decision!!!!!!!!
92 sentra tranny
Vacuum Hose Leak?
1997 Rear Speaker removal/install
Prices for cylinder head work '02 Sentra
Sun Roof Stuck Tilted
major help needed!!!!!
i need a programable engine managment
safc
help with cold air intake anyone??
'97 200sx SE-R, Governer disable????
No Parking Lights
No Parking Lights
filter adapter
Washer Nozzler Removal "Help"
odometer
96 GXE side mirror????????????????
Its leaking!
95Sentra GSX AirBags
Final Cosmetic Stage
How do I remove...Help
Sentra 2005 1.8s gas tank reassembled
Recalls
92 sentra..clutch cable recall????
catback question....
'97 SER anti-theft problems...
Shocks or struts
97 Se-r A/c
07 se-r /cvt
92 Sentra..idle switch..where?
Trimming teh shifter knob. (93 Sentra XE)
My Spec vs. Mustang GT, top end
'93 Nissan Sentra XE won't start.
93 sentra E won't Start
Hard to fill gas tank
1998 Sentra axle replacement strut problem
96 200sx performance????
'98 Sentra rear wheel thumping noise
Gas Pedal Stuck!
'97 Sentra GA16DE How to replace alt/AC Belt
Rough Start
FS: Boosted 1995 nissan 200sx se-r
nissan etesting (sentra)
Drive Axle Replacement
03 Silver Spec, new wheels
Headlights
won't start
sr20 question
Running sliggish.
1995 200sx se-r for sale cheap!!!!
1996 200 sx se-r
02 spec v tow hooks???
Wrong Drum Brakes on My Car????
Coolant bypass on throttle body.....?
Valve Cover Installation Torque and Sequence
For Sale: Turbo 200SX SE-R
oil leak
Not Getting my MPG & Gauge Problem
6 speed
205/40/17 rim 125/45/17 tire??
lowering?
2000 Sentra 2.0 SE - MAF Problem?
Clutch chatter ftL?
gear oil?
N1 cams for sale
92' sentra motor swap
Fuel Smell from Car Cap Tank
2004 Sentra SE-R Spec V
Advancing timing on 06 specv
Cai
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
