View Full Version : Explorer | Explorer Sport Trac
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19
  1. '93 dead tranny. Options/Suggestions?
  2. Faulty Oil Pressure Gauge
  3. 2 questions... tires and bumpers
  4. 97 explorer tape deck
  5. Bumper color code
  6. 98 Explorer heater
  7. 97 explorer 2500rpm vibrations
  8. Tornado results
  9. o/d light flashing....again!
  10. WTB- 5.0L Explorer serp set up
  11. Stall Stall Stall
  12. starting problem 94 explorer
  13. Overheating!!!
  14. Fuel Injector Cleaners Safe???
  15. 99 Explorer Cylinder #4 ruins the Spark plug in 7 months?
  16. Need 4.0 engine 97 Explorer which engines fit?
  17. Head gasket leak-95 Explorer
  18. Nice 02' ST for sale with a warranty
  19. 2001 Sport Trac Fog Lights
  20. 97 EB Exploer rear subwwofer
  21. Power steering noise
  22. Stuck In neutral!
  23. 2001 Explorer Transmission Issue
  24. 94 Explorer head gasket
  25. 97 Explorer makes a grinding sound only when turning
  26. Rear wiper
  27. 1996 ford explorer jbl subwoofer removal
  28. Trouble Code
  29. 2002 sealed rear bearings
  30. 98 explorer 6 cyl. 4L Oxygen Sensors
  31. 1996 Explorer
  32. 94 Explorer problems...
  33. 1997 Explorer Starting Problem
  34. White smoke from exhaust
  35. -98 explorer leaning left
  36. more questions about tires, lift kits, and gas mileage
  37. Explorer makes noise when driving
  38. Clunking Heater
  39. door locks
  40. rear view mirrors not working
  41. head gasket
  42. 92 explorer $250 NJ
  43. trans. help
  44. starting problems
  45. tones when starting
  46. 1996 remote entry
  47. Check engine light
  48. Speaker problem
  49. Need info
  50. To crank or not to crank.............
  51. 2003 XLT Axle Howling
  52. cannot find engine number
  53. 2000 5.0 Explorer EGR valve change (or clean)
  54. 1996 Explorer 4.0 egr valve location
  55. klunking while driving
  56. Intermittantly won't start
  57. 2000 Explorer 4x2 rear differential
  58. 2000 Explorer rusted freeze plugs
  59. 97 Eplorer - press brakes and dash lights come on
  60. Transmission Issues.. plus voltmeter
  61. Missing Under Power
  62. Cargo cover application by year
  63. 1997 paint. help me please
  64. 2003 Explorer shudders at sharp turns
  65. 2002 Explorer Back-up Sensor
  66. Can anyone help?
  67. How much to sell 01 Xplorer Sport?????
  68. AWD at the Beach?
  69. 99 Explorer horn problems.
  70. 91 explorer
  71. '96 Radio Controls no Backlight
  72. radio setup
  73. 94 Explorer has lost alot of power
  74. cruise control
  75. Will not turn over!!!
  76. 96 Explorer Stutters when warm
  77. Explorer Fuel Problem
  78. Tire noise, maybe not...
  79. 97 Explorer Steering Rack leaking & Noisy
  80. exterior step light
  81. Where is the PCV valve on a 2002 Sport Trac
  82. A/C Problems!!!
  83. my '92 explorer sounds like a diesel
  84. Is the XLT capable? Need help
  85. Change all oils at 60,000 miles
  86. 1994 explorer won't start
  87. trouble getting at one spark plug
  88. Battery/Charging Issue
  89. A/C Problem..how difficult? Any advice?
  90. 2002 Ford Explorer V8 Transmission Problem
  91. 33" tires??
  92. Airbag Problems! Worried!
  93. NEED HELP BADLY.. SEVERE OIL Leak, Hitting Exuahest Manifold
  94. Tornado to improve explorer gas milage
  95. Fuel Gauge
  96. A/C Comp???
  97. just got a 94 explorer xlt and have a few questions
  98. Engine noise
  99. Randmonly will not start
  100. 97 explorer cd changer control
  101. explorer ipod hookup
  102. 94 ford explorer help
  103. 97 electrical problem?
  104. New to board, couple of questions-1993..
  105. 1996 Explorer A/C problems
  106. hydraulic clutch line
  107. Installed new starter and it's making noise...
  108. 1991 Automatic - Dumping massive amounts of fluid
  109. Spark Plugs-How often do you change it?
  110. Which would u choose?
  111. 2002 Sport Trac four wheel drive issue
  112. Heater blowing cold air only
  113. 97 explorer- check guage lite
  114. 93 overhead console removal
  115. Spindle thread problems
  116. Weak spark during cranking: Strong spark when running.
  117. Cold Air Intake
  118. Squeeking noise from front-end
  119. squealing noise
  120. Trouble with shaking speedometer; and trans
  121. stereo wiring diagram
  122. selling a vehicle question
  123. Fuel filter
  124. 91 Explorer catalytic converter questions
  125. 97 explorer shifting from rev to drive
  126. Crackling sound at low speed
  127. Unable to open hood
  128. 1994 Explorer in low range (stuck)
  129. Can I reprogram auto door lock feature-97 Explorer
  130. 1998 explorer engine noise
  131. turn signal fuse burns out
  132. 2000 Ford explorer will not start
  133. wanted: boxextender for sporttrac
  134. Faded Wheel Lip Moldings
  135. 97 Explore sport.
  136. 1996 Explorer Hood Won't Stay Up
  137. Alarm System
  138. Check Enging Light on 99
  139. 94 explorer makes noise and engine light
  140. Tekonsha 2030 Mark 12 Brake Controller
  141. Programing remote for 97
  142. 1993 Ford Explorer XLT - Winding then THUMP
  143. 1994 Explorer No Neutral Or Reverse
  144. Possible to change shift points on 1998?
  145. Miss in 97 Explorer 5.0 CYL 7
  146. explorer 3rd row seat
  147. Horn or cruise control dont work.
  148. Buzzing noise when turn signal is activated
  149. tire rotation
  150. Still Wont Start..after all the repairs???
  151. parking breaks
  152. Another Check Engine light thread
  153. '97 - Speedometer problems/battery light
  154. is it any good?
  155. Svt St?!
  156. headlight problem, sooooo close to fix HELP!!!
  157. Contemplating 98 V8 Explorer
  158. fuel pump
  159. Basic tune up
  160. '96 Explorer trans shiftig problems
  161. Check Engine Light Diagnostic help.
  162. Chirping Noise
  163. rear window sporttrac
  164. 4x4 High light on instead of 4x4 Low
  165. 00 explorer rear wiper stuck
  166. Drivers door/ lock, elec. mirrors, int. lights, door ajar light
  167. 91 explorer over heats after going uphill
  168. 94 Ford Explorer FOB/Keyless Entry Reprogramming
  169. Reverse problem
  170. 93 Explorer Remote Entry
  171. Ford Explorer 94 Problems
  172. '96 explorer limited 'air ride' problem
  173. Ford GR-1
  174. 92 Explorer Parking Park Serious Problem!! Need Help!!
  175. Car wash, Wax, Tire cleaner, etc.
  176. Motor Oil Brands to Use
  177. Rotor Thickness - Service Limit
  178. Do i have an alarm? (explorer 1998)
  179. 2000 Ford Explorer No Heat Defrost Only
  180. fuel kill switch
  181. '98 Explorer sounds like rattling under valve covers
  182. 01 Explorer Sport Rear Turn / Brake signal
  183. ford explorer for sale
  184. rattling sound under valve case cover!!SOS
  185. Ford explorer 2001 sport trac
  186. Oil mixing in antifreeze? HELP!!!
  187. Spedo problem, Electrical?
  188. rebuilt transmission issues
  189. 1999 Explorer XLS Remote Programing ???
  190. 97 explorer radio
  191. front end vibration at slow to 50mph. ok at 50+mph?
  192. 98 SOHC Ticking
  193. Help!!!!!! rack pinion prob. S.O.S
  194. 95 explorer instrument cluster
  195. blink,blink,blink
  196. 4X4 hubs
  197. 98 Explorer rough idle no codes
  198. sounds like horn
  199. 99 Explorer washer pump
  200. changing trasmission filter/fluid
  201. Noise Source? - High pitched vaccum/damper sound.
  202. How to remove? - rear passenger spark plug wire
  203. The Last Resort Heater/AC Blend Door Fix
  204. 1993 Explorer turn signals not working
  205. 91 Explorer stalls when I step on accellerator
  206. Defrost causing idle problems
  207. 2000 ford explorer bad vibrations after hitting bumps
  208. Transmission fluid
  209. Anyone Who Has A 92 Ford Explorer
  210. Compressor problems?
  211. Remote Control Programming keyless entry for a 2002 Explorer eddie bauer
  212. Air compressor burnt out
  213. TRanny Fluid Change
  214. break noise
  215. Hot start 96, Explorer
  216. 97 explorer hard pedal
  217. Ford Explorer Compass
  218. Another Transmition question (1997)
  219. Steering Wheel Pulsating Help?
  220. Please answer this question
  221. 1991 Explorer Air cond.
  222. I know this is a dumb question but how do i take the spare off a 94 explorer sport?
  223. lower intake manifold
  224. dimming headlights/brights don't work
  225. 98 explorer trany filter
  226. I will never buy a ford again!!!
  227. Keyless door entry programming??
  228. 91 Ford Explorer Wiring Diagram
  229. Help Rear Hatch
  230. odometer dies
  231. 92 explorer no spark
  232. 2002 Fuse/Power issue?
  233. 97 Ford Explorer Rear Windshield wiper problem
  234. 1992 explorer leprosy questions. Please help....
  235. airbag light stays on
  236. factory cd changer
  237. 95 Exploder: Vibration/Hum from front end...
  238. Loud humming at 35mph
  239. 96 Explorer, Loud Humming Noise
  240. 01 explorer 2 cluster lights out
  241. 2004 Explorer Break Job
  242. 1996 Explorer Air Suspension
  243. Vacuum hoses.
  244. Flasher Unit Location For 2001 Explorer
  245. NEED Fuse Panel Information
  246. what do you check if it's not getting fire?
  247. engine swap 4.0 to a 351
  248. abs light on
  249. No 4X4 Engaging....
  250. 02 explorer lift kit
