99 Explorer washer pump
jaykan11967
03-10-2005, 12:31 PM
My first post so please bear with me. I have a 99 ecplorer xlt 4door. My front and rear washer died. The wipers work but the fluid doesnt come out. I hear no pump noise at all. I was thinking I have a bad washer pump, but is there one pump that feeds both the front and rear washers? If they have seperate pumps then I cant see both going out at the same time. I checked the fuses and they are all good. Any ideas?
way2old
03-10-2005, 12:55 PM
If all the fuses are good, the pump in reservoir has quit. You may need to remove washer bottle to access the pump. If you have a test light, check to be sure you are getting current to the pump first. Good luck.
punmaster7
03-11-2005, 12:34 PM
I also have this problem because for some reason the fuse keeps blowing. See this thread for a possible solution.
http://www.automotiveforums.com/vbulletin/showthread.php?t=368511
I have not had opportunity to fix mine but another person has. I'm hoping my fix will be as simple.
Curt.
