View Full Version : Explorer | Explorer Sport Trac
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19
  1. Mysterious Explorer Starting Problems..
  2. "clattering" 2000 explorer sport 4.0 ohv
  3. just got 91 explorer and it has a starting problem
  4. Extreme Power Loss
  5. 1996 Idle increase/decrease with possible hissing noise!
  6. 2002 Explorer Gas pedal vibration
  7. 1998 Explorer Keys
  8. Remote start....
  9. Transmission cooler that come standard
  10. High Pitched Whistling Sound in 98 Ford Explorer Sport
  11. 99 Explorer Sport, loud noise, fluttering idle
  12. Determing witch axle I have on my 94 4wd
  13. DESPERATE fuel line removal tool
  14. 91 Explorer engine removal
  15. headlights not working
  16. 99 Epxl Sport -- Low Gas Mileage
  17. Engine Problem
  18. tranny
  19. 97 Explorer Sport 4x4 Blinks 6 times
  20. skip
  21. What did I do to my trany!?!?
  22. 1998 Ford Explorer Idle Problems
  23. Tonneau cover trouble
  24. 1998 Explorer - High idle, rough automatic shifting, running hot - Water pump??
  25. U-Haul WTF?
  26. '95 Ford Explorer Humming
  27. Cruise Control Lights on Steering Wheel
  28. HP on a 97 SOHC 4.0L?
  29. Check engine light and codes
  30. 1994 Ford Explorer Keyless Entry
  31. CD Player Problems!!!
  32. Electric Side Mirror switch wiring.
  33. Headlights plastic is cloudy: Any fixes?
  34. engine stalls after warm start
  35. 97 XLT Explorer auto start Location ?
  36. transmission question
  37. Rear wheel and Diff bearings on 94 trac-lock
  38. 93 explorer rear door problems
  39. Starter interrupt
  40. billet grill question
  41. Fuse - Drivers seat 1996 explorer
  42. remote starter
  43. 99 explorer with Rear window wiper problem
  44. New 04 XLS in NEED of CD changer - help!
  45. sound from the rear end
  46. Broken Gas Pedal
  47. alarm doesnt disengage from drivers side
  48. 4x4
  49. 99 explorer idles rough at startup
  50. Need help replacing lower ball joints!!!
  51. 97 Check Engine Light/Rough Idle - HELP PLEASE!
  52. vacuum lines for 4x4
  53. 97 Explorer XLT: Installing Reverse Gauges
  54. Power steering air purge
  55. wiring diagram for a ford explorer 4.0L
  56. headlamps and foglamps do not work
  57. 94 Explorer heater works only on high
  58. 91-94 Which tranny is worse?
  59. Power door locks keep re-locking (intermittent)
  60. Engine Lifter Problem?
  61. Check Oil Light wont go...can anyone help?
  62. Automatic Hubs going bad again?
  63. 4x4 problems
  64. vibration on acceleration
  65. push button 4x4 problems
  66. was I taken for a ride?
  67. Dashboard icons & warning lights on a 1997 Ford Explorer
  68. #3 cylender mis firing..why
  69. 1997 Explorer XLT Erratic Alarm!!
  70. 2001 Expolrer-Check Gauge Light/Temp Gauge
  71. Grinding sound from the front end
  72. Subwoofer Wiring Harness???
  73. Are Explorers Not Supposed To Start
  74. Oil in Anti-Freeze
  75. Door won't open. Can I take panel off/elec. latch not working?
  76. alarm stopped working??
  77. Help with automatic hubs
  78. Spraying raw gas out of exhaust, a lot?
  79. Anyone know where the factory amp is on a 1997 Ford Explorer?
  80. fuses
  81. 2002 Explorer Idle Troubles
  82. 2002 Explorer Idle Troubles
  83. brakes replacement 1993 exlporer
  84. Adding a Message Center...
  85. Chirping noise in 2002 Ford Explorer
  86. interior and exterior lights "pulsating" while idling...
  87. interior light staying lit.
  88. Heat only after 45 minutes
  89. Back Doors will not open from the inside!!!
  90. 1997 ford explorer console cd changer
  91. clock goes dim, not the battery?
  92. Check engine light on
  93. Check Engine light on
  94. 91 Explorer Valve lifter noise.
  95. raido
  96. Engine Temp/Loss of Power
  97. Alarming Noise
  98. 4 wheel drive does not engage
  99. rear wiper problems
  100. engine/oil gage problems
  101. Fuse Help
  102. 96 Explorer XLt Engine Dies when cold
  103. Help!!! Temp Guage???
  104. 93 to 98 OEM wheel swap
  105. 1993 4 wheel drive won't engage
  106. Lack of heat in a '93
  107. reading color code from my explorer
  108. Help with coolant leak
  109. Blinking lights problem
  110. I need a parts Explorer
  111. air suspension system
  112. Radio/CD Display
  113. Alarm Going Crazy!
  114. what is the value of a 98 4x2 sport?
  115. automatic to manual trans
  116. 2001 Sport Trac Question
  117. problems with 94 Expl 4 wheel drive
  118. Transmission or ?
  119. Replacing hinge pins
  120. Engine dies after ride when I shift into park?
  121. Heat 1996 Explorer
  122. 2002 Explorer gauges not working
  123. Multifunction switch
  124. woman question
  125. Chirping Sound new Explorer
  126. Bad subwoofer??
  127. Intermittent wipers on a 97 Ford Explorer XLT
  128. Keyless entry
  129. Dashboard Lighting - 96 explorer
  130. 96 explorer indicator light
  131. 1996 Explorer dome lights & rear wiper
  132. won't idle at cold start
  133. 93 Sport Door Handles
  134. Knocking at noramal operating temp
  135. Sport ride quality upgrade
  136. Clutch problem 98 exp sp
  137. Odometer/Trip Odometer Inop
  138. Grinding/Metal Screech sound when accelerating...
  139. Reset check engine light
  140. I'm Stupid
  141. 2002 Sound System
  142. 1994 EXP tranny ?
  143. Explorer or DUrango
  144. Explorer - TWO solenoids?!? No start!
  145. FS: 96 sport very sharp
  146. no start after hot soak
  147. Tranny question
  148. 96 explorer subwoofer
  149. ABS Idiot Light
  150. 96 Explorer "hesitating" steering in park
  151. Ticking with acceleration
  152. Dumb fuse blowing question
  153. easy to install keyless entry system?
  154. 93 explorer 5 spd
  155. 93 explorer starting
  156. 1996 Ford Explorer Billet Grill
  157. 2003 Explorer Wiring....HELP!!!
  158. 2002 front door seals leaking at 16,000 miles
  159. Rides worse than a lumber wagon
  160. 96 radio upgrade
  161. 99 Explorer Sport Rough Starting
  162. 94 5 speed
  163. 2000 Ford Explorer alarm gone psychotic!!
  164. 94 Overdrive. When to use?
  165. Explorer 5.0 Headers
  166. Rough Idle in 2002 Explorer
  167. 98 explorer eratic idle no w/no engine light
  168. Check Engine Light on '92 Explorer
  169. 98 Explorer Wiring Schematic
  170. OBD2 Scanner Needed Or Not?
  171. Location of vehicle alarm for 1994 Ford Explorer
  172. 98 Explorer Wiring Schematic
  173. 96 XLT Keyless Remot Programming
  174. 96 Air Vents
  175. Ceck Engine Light
  176. 93 explorer Overdrive
  177. Explorer 4.0 ohc block/pan ladder girdle?
  178. wiring diagram for center console heater
  179. 1992 Eddie Bauer power window problem
  180. Removing overhead console
  181. 95 Explorer Blinking Overdrive Light
  182. 1997 V8 Egr sensor?
  183. temperature control problems
  184. center floor cosole wiring
  185. how easy?
  186. Problem with VSS?
  187. '95 Transmission - to where?
  188. Largest possible tires
  189. Rear seal leakage
  190. Starter Problems on 93 FordExp
  191. 1997 Explorer lift and fog lights
  192. 94 Ford Explorer 4 Wheel Drive Problems
  193. looking to buy 93 explorer
  194. 98 Explorer shock absorbers
  195. explorer auto locking in Drive
  196. 99 Explorer knocking
  197. Scan Tool for 95 XLT
  198. wiring 94 explorer
  199. 98 check engine light...
  200. Woman question here.
  201. 6 cd changer
  202. what is this?????
  203. Keyless Entry Code
  204. Odd Engine Sounds, Please Help!
  205. Xenon Lights and Dome Bulbs
  206. 2001 Explorer Limited - Rear Defroster, Backup Sensor, Overdrive button, Auto Lock
  207. HELP O2 Sensor!
  208. 99 Explorer Overdrive Light Blinking
  209. Wheres the amp
  210. Grinding/clicking noise from the front end
  211. Heat!!!!!
  212. 2001 Sport Trac Starting Problems (Fuel Related?)
  213. 18" Detata Profiler 6LUG Wheels On Pirelli Tires FOR SALE!
  214. 4.0 5 speed 4 wheel drive question?
  215. truck overheating but gauges do not indicate overheating
  216. Motor Madness 10/18/03
  217. 94 Explorer - Replacing Factory Speakers
  218. 1993 Ford Explorer gas gauge question
  219. Rough & Noisey ride???? I am thinking of buying a Explorer
  220. Travelling problems
  221. 92 Explorer trans problem
  222. Minor Paint flaws
  223. 92 Ford Explorer power window
  224. Explorer 2003 woes
  225. '92 Explorer Heater Core Replacement
  226. check gauge light
  227. Idlie problems 97'
  228. 93 explorer loosing transmission fluid
  229. 1997 loweing springs?
  230. 97 Explorer - Check Engine P0153 code
  231. hitch wiring for 95 Explorer
  232. 1992 Explorer head gasket replacement
  233. Engine Light on after Oil change
  234. gauge lights going out one by one
  235. gauge lights going out one by one
  236. PCV Valve location on 96' Ford Explorer
  237. I Can't open my 1997 Explorer with my keyless remote but it open with a tahoe remote
  238. spinning rims
  239. 2000 XLT door entry programming
  240. 2002 woes
  241. Ford Remote Keyless entry module
  242. hoping for a quick fix on my tail light!
  243. Programming a 94 Explorer Key Fob
  244. 2000 Explorer Overheating
  245. ford keyless remote alarm programming
  246. Air Ride System
  247. All Interior lights to blue
  248. body kits
  249. Interior light color change
  250. differential seals leaking
