2000 Ford Explorer No Heat Defrost Only
WATERWOLF
03-15-2005, 12:53 PM
Hi,
I have a problem with my 2000 Ford Explorer. No matter what position the selector is in hot air comes out of the defroster only. The floor heat in the back works when the blower is on in the back.
way2old
03-16-2005, 10:52 AM
Look for a vacuum leak at the lines going to the switch or the vacuum reservoir under the hood. Happy hunting.
WATERWOLF
03-28-2005, 01:49 PM
I found the problem. There was a firewall connector on the inside passenger side which had become disconnected. I hope this helps someone else. Thanks
way2old
03-28-2005, 06:42 PM
Thanks for the fix. It may help others. :smokin:
