Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Ford
> Explorer | Explorer Sport Trac
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
po 401
What brand and where should I purchase new rotors and brake pads for 03 Sport Trac?
1995 Explorer XLT Wiring Question
2002 sport trac Miss fire
Heater issues 2003 Explorer 75k miles
Ignition Lock removal
new ac replacement problems
04 Explorer fuel gage stuck near full
96 Explorer with binding front wheel.
accessory power staying on
2005 Power Seat wiring
97 explorer xlt
rear abs sensor bolt rounded
No high beams and ball joint question
AC is not cold and is blowing cool air from one side
engine swap
Multiple Electrical Problems
knock in top-end
Sport Trac 2007 Floor Hook
95 explorer problem
i searched, now i ask-trans slippage
What rotors should I purchase?
Running rough and white smoke
01 Explorer Sport Leaking
97 explorer unlevel
2010 explorer xlt mpg sucks
2006 Rear Hatch Door Actuator
Sounds like an old mattress
'94 Explorer 4.0ltr code 124?
transmission problem
Ford Explorer Self Acceleration/Braking Problem (help)
Marker Lights stay on
2002 Explorer DRL (daytime running lights) pulsating
2000 ford explorer tran slip!!!
2001 Ford Explorer Seats
1996 Ford Explorer Making A Noise
2003 Sport Trac Bed Cover
Engine wont shut off
Abs
06' rear end issues
Blown Freeze Plug
04 po193 fuel rail sensor
fuel damper for 4.0x motor
Rear Hatch???? cracked
2002 Explorer - Heat/AC Vent flapping
2002 explorer 4.0l, will die when turning from stop sometimes
2003 Ford Explorer Steering problems
Electrical problems with a 96 Explorer XLT
98 v85.0 hard starting when cold
A lesson learned
running rough and getting bad smell from exhaust on 2000 ford explorer sport
2002 Ball Joints
gas pedel repair
belt ripping
buying new car- what 2B replaced?
explorer radiator
help!
97 Explorer SOHC water pump
Surge before engaging in drive
2002 Explorer lost reverse
Why won't my car start?
fuel pump stays on
If you have cold and warm air blowing from defrost duct only this thread is for you!!!
2003 Ford Explorer Code P0430
2006 Explore won't take gas
Wants to cut off when I stop at lights
2000 Explorer Sport Trac issues
1992 Ford Explorer Battery Problem
looking at engine swap from 99-2001 4.0sohc
2001 explorer sport with no power.
92 Ford Explorer Head Gasket
Keyless Entry Module Pinout Needed
Rear freeze plug
2000 explorer rough idel at start up
Transmission wont go into drive.
03 Explorer Defrost Problem
99 mountaineer 5.0 hard starting in cold
1994 Ford Explorer Hard starting after it sits.
Explorer 2005 - Charging Problem
99 Explorer Trans "D" issue
1999 exployer problems 4.o sohc
97 Explorer Sport
vaccum leak/intake
2002 Sport Trac
2008 Explorer
98 explorer power mirrors
Brake Bleeding 99 explorer sport
2007 Explorer Eddie Bauer OD/Off Switch Sticking
95 Explorer XL 4x4 problem
starter issue?
2000 Explorer XLS keyless entry
Trans problem explorer
2000 Ford Explorer fuel problem
Sudden Increase in Fuel Consumption
Engine Performance problem
1996 Explorer with blower motor issues
94 Explorer code problems
Starter or relay or other?
99 Explorer No Start
95 explorer 4x4 issue
Ford explorer 2001 healight
04 Sport Trac Electrical Issues
Electrical Demons?
1996 explorer trouble
2000 ford explore Misfire with NO CHECK LIGHT?
Brake pedal goes to floor
What is this cord used for? 1999 Ford Explorer?
98 Explorer has no power
2003 Explorer feels like driving over expansion joints on deceleration
Code P0171
ABS Kicking in when not in a slide
O2 sensors wireing
2004 Explorer Vibration...
00 Explorer bucking at certain rpms
Fuel Line Connectors at Fuel Filter Red and Green???
98 Explorer air/fuel ratio issue? HELP!
replaced IAC valve, idles worse than ever
Hoping someone could help with a Pop in my Tranny.
HElp me im an idiot
ftp sensor ford explorer location
Car overheating
98 explorer AC compressor won't come on
1998 Explorer Driver's Side Upper Ball Joint Removal
Rear spring shackles
Double Din
Explorer airbag
2003 Eddie Bauer Climate Control Cycling
Starter difference 1st and 2nd production?
Fuel Filter and Water Pump Replacement
99 OHV Plenum sensor
2000 Explorer XLS front suspension questions.
Chance to buy an 04 Explorer 4.0 l w/40k mi
odd problem new to me, '98 explorer sport
Power windows 1990 exp
Tow hook add on question
2002 engine head removal
03 Expl EB DriveTrain Windup Noise
93 starts in reverse?
Explorer/Explorer Sport Trac
06' explorer trans. computer update?
help with tranny on 97 explorer
2000 exp sport OHV mis-firing.
Quick HELP! Engine revs up, shakes, and shuts off
Ignition problem?
Ford Explorer (Fuel Problem)?
03 Exp loud clanking on top of engine near firewall
a/c compressor makes clicking noise
Wiper arms
4R55E Front End Play Check Gauge Bar T93T-77003-AH
Cruise Control Help
2002 sport trac
got my a/c fixed, I think it still leaks.
2002 explorer, random no idle
03 Explorer Pass. Sun Visor Mount Replacement
Explorer that wobbles
2003 explorer door ajar
4R55E tranny rebuild problem
Sunroof Doesn't Move
message center shows errors but none are present
99 Explorer electric totally gone !!??
Wheel hub removal
need help on a c clutch
Wire set question
Rear passenger wheel knocking....
drivers power window does not work
92 Ford Explorer Wont Start
98 explorer with many problems, please help
Replacing Door Handle
98 explorer has od light flashing
Rear Turn Signals Flash Wrong
Front Seat stuck forward
Cylinder 7 mis fire??
'98 explorer 5.0L P0133
New Owner
93 Transmittion (4x4)
99 Explorer need to by pass key chip module PLEASE HELP!
Over Head Console
2002 explorer won't shift past 1st
Weird hum/whistle.
power locks
a/c leak
'01 Sport Spark Plugs
98 Explorer high revs in gear and stalls in reverse
98 Explorer, I do not have coil springs?
Gas Gauge Not Reading Properly
Frustration
2007 cluster problem
Explorer 2001 sport track sparks from distributor?
How to remove a broken intermediate oil pump drive shaft
2002 A/T fluid level
Check Fuel Cap light
Crazy Explorer!!!
95 Explorer - Rear Main Seal Advice Please
engine codes
4wd indication blinking?
06' keypad code?
Wheel hub - ABS
95 Explorer Transmission sensor - can you identify??
97 explorer chirping sound
06' explorer- cabin filter?
P0402 code on a 1996 4.0
airbag code
1998 SOHC, not sure if flowmaster will fit
98 SOHC, idles better WITHOUT IAC valve
2002 A/T fluid change
Brake Controller adapter
ford explorer missfiring ?
2002 Exployer Flasher Unit
Misfire on 1,2 and3
wiring diagram for 99 explorer windshield washer pump
2003 Explorer, Transmission Question
1998 4.0 litre -- motor died while driving over bump
Dash Lights & Battery Light
96 transmission
Where is oil sending unit 98 Explorer 5.0
Time for some repairs.....
99 Exlorer Oil Pressure Gauge Issue
98 explorer bad gas milage wit p0430 and p0420 codes
1995 explorer awd
98 explorer, bad idle and rough start --MAP, MAF?
Steering Binding - Irratic Power Assist
2002 explorer v8 4wd eb high idle and shifting problem
What exactly is wrong?....
Allignment Issues
94 explorer cruise control quit
How hard is it to pull engine on 2002 Exployer?
1999 frd Expl. 6.0L, xlt, 4wd
intake manifold and sludge
P0741 TCC stuck code, trans expert help?
Transmision oil pan leaking..how hard is it?
2004 AWD- Front end Vibration at 60+
left bank o2 sensors reading 0, P0171, P0174
98 ford explorer stalling, error 171 174
want to disable 4x4 auto on 2002 Explorer
2003 Ford Explorer - No Start but spark and fuel
Ford Explorer 2003 no start - engine rotates
2005 Explorer sport trac
New shocks
Thermostat goes up/down, no steady heat
99 Ford Explorer Leaking Antifreeze
Need Advice:Looking to buy Explorer that needs a little work
2000 explorer 4.0L 3rd cylinder misfire
Key fob battery replacement
transfer case/vss gear
4x4 module
Front end vibration when driving.
2003 sport trac idle surge
2001 explorer swaybar link
Explorer sport vibration
'98 Explorer starting problem
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
