View Full Version : Explorer | Explorer Sport Trac
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. 2004 ExplorerXLT_HatchCrack
  2. 99 Explorer LOUD pulsing hum and vibration from the front end
  3. 98 Explorer ocassionly will not start.
  4. 1999 Ford Explorer problems
  5. 95 explorer eddie rear axel removal
  6. 2000 Explorer tranny and electrical problems
  7. 2001 4.0 sohc automatic 4x4
  8. dome lamp switch??
  9. Vaccum smoke test port
  10. 95 explorer 4.0 4x4 power problem
  11. 97 Ford Explorer- rough idle-and missing top end
  12. towing turn signal
  13. anyone have a wiring schematic???
  14. 2003 Explorer 2wd
  15. 91 explorer fuel pump?
  16. 02 Eddie Bauer V6 4.0 Rattling Noise While Stopped in Gear
  17. 2002 explorer fuse location
  18. 1998 Explorer 4wdhi and 4lo light keeps blinkin
  19. 2002 Eddie Bauer Fog Light Grill Removal?
  20. new fog lights needed
  21. ford explorer abs problem
  22. 4.0 SOHC supercharger
  23. head swap
  24. HELP- 2002 Explorer Eddie Bauer- Radio, Interior Lights Not Working, No Fuses Blown?
  25. 1999 ford explorer
  26. 1996 tranny problem
  27. Tranny
  28. 2003 Sport Trac Differential Identification
  29. 2004 Ford Explorer XLT tow hitch question
  30. Window Regulator
  31. Where is the PVC vacuum hose
  32. 1995 Explorer Stalls at Idle
  33. airbags
  34. Door lock Actuators not working
  35. 99 Explorer Making Strange Vibration After Timing Chain Replacement
  36. od light flashing
  37. Help, poor gas mileage...
  38. Upper Intake manifold gasket
  39. 99 Exploer - Malfunction Indicator Lamp (MIL) Method
  40. 2106 tac system forced limited power
  41. 98 AWD Clicking sound from front
  42. steering shudder
  43. Help with air ride controle module
  44. 2001 Thermostat assy remove & replace
  45. Front locker for 1999 Ford Explorer Front differential.
  46. Drivers door lock not operating properly
  47. Trouble Codes P0300, P0316 on my Sport Trac.
  48. Coil Pack Question
  49. 99 explorer beeps 5 times @ startup
  50. 99 sohc timing chain repl.: what special tools are needed?
  51. 92 Ford Explorer Sport Cranks but wont start/ missing part due to parent
  52. Oil Leak Around Oil Filter?
  53. accessory lights
  54. O2 sensor problems
  55. problems filling up tank
  56. Child Locks!
  57. 98 ford explorer
  58. 01 sporttrack p1633 code????
  59. Possible PCM failure?
  60. Rear Wiper Arm
  61. 2001 Ford Explorer V8
  62. 02 explorer passenger window problem
  63. Is it a thump or a clunk?
  64. Screwed Up Dashlights
  65. 2004 Ford Explorer Front Washer Fluid Doesn't Work
  66. Fuel Gauge issue
  67. Engine tach going to 2-3k when applying brakes.
  68. Upper intake plenum OHC 4.0
  69. Air bag light, code 3-6, 3-7 99' Exp XLT-Update
  70. headlights
  71. Freeze plug leaking
  72. transmission troubles 2000 explorer sport 4x4
  73. 99 Expl stuck in low?
  74. 99 explorer wont start!!!
  75. coolant temp sensor issues
  76. my 96 squeeks
  77. bumper advice
  78. 98 Explorer Limited Washer Motor
  79. 1996 Explorer Power Windows not working.
  80. Hesitation and burning smell
  81. 2003 Explorer Xlt Problems
  82. 2002 Explorer 4 Dr, Code B2292, 4.0 Eng
  83. i NEED HELP
  84. unable to pull ABS code on 1996
  85. set timing on a 97 sohc
  86. 04 Sport Trac rear end question
  87. Overdrive
  88. 2000 Explorer..4x4 won't engage
  89. Catalityc converter on explorer 96 XLT V6
  90. Where to Buy Fog Lights for 1994 Explorer
  91. Keyless or not? 1994 expl. xlt
  92. Increase Milage chips
  93. Doors do not stay open 94 XLT
  94. Daytime running lights on 94 XLT - Like to turn off
  95. Mileage 2007 Ford Sport Trac 4.6L
  96. 2003 Explorer Xtl Key System
  97. side view mirror
  98. Rear tail lamp assembly
  99. 98 4.0 sohc explorer died in operation
  100. 94 Exporer Transmission noise
  101. 1994 Keyless entry - does mine have it?
  102. Explorer transmission module?
  103. Emissions
  104. 99 explorer problems with climate control
  105. Air Bag light code 3-6. 3-7 99' exp 4.0l good fix
  106. Merry Christmas
  107. rim sizes
  108. squeaking/grinding noise
  109. Another 1998 Heater Problem
  110. locating starter 2003 sport trac
  111. 2000 explorer AWD problem
  112. 1997 XLT 5.0L AWD - Jammed Wipers
  113. CD Changer tempermental 97 XLT
  114. more 4x4 problems
  115. electric windows stick in cold weather
  116. 2002 Explorer XLT aftermarket wheels and tires
  117. 1997 4.0 Oil Filter Adapter Question...
  118. Brake problem
  119. 02 Crack on hatchback panel under rear window
  120. 1993 5.0 into 1996 explorer with current 4.0 engine
  121. tps location
  122. 99 explorer misfire when cold
  123. Possible PCM issue?
  124. CheckEngine light on Explorer 96 XLT
  125. Buying a used Explorer 97-2001
  126. 96 4.0L ABS motor comes on/no ABS light?
  127. Abs light .99 Explorer 4.0l 4wd
  128. ABS light - Clear cut answer needed
  129. Replacing alternator on 91 explorer
  130. Question on clearing trouble codes
  131. Unballanced drive train
  132. '99 ford explorer rotors seized -fixed part 2
  133. borg warner 4405 transfer seal.
  134. '99 explorer front rotors seized - fixed!
  135. 97 explorer 2dr.AWD,replacing rear(transfer) output seal...
  136. Manual hubs
  137. Location of Oxygen Sensors '00 Explorer
  138. 95 explorer 4x4 problem
  139. Clutch Won't Disengage
  140. 93 Explorer will not start <Need help finding starter
  141. My latest off road stuck story
  142. Where should i start? (A CHALLENGE FOR SHOROD and ALL)
  143. 93' Explorer blinkers not working
  144. 1994 Explorer XLT - does it have Keyless?
  145. 1994 Explorer 2 doors,4x4,Camber Adjustements
  146. 1998 Explorer XLT Fan Motor
  147. Front Rotors siezed 1999 Ford Explorer
  148. 2002 explorer blend air temperature motor removal?
  149. brake trouble
  150. 2002 Explorer 4x4 XLT preventative maintenance
  151. 95 exploder : 3 CODES . . . 114 327 636 HELP ! ! !
  152. Manual Lever Position Sensor???
  153. My "new" '91 Explorer
  154. 92 explorer gas tank removal
  155. What would you do?
  156. 02 Explorer HomeLink
  157. 2001 Explorer Sport 4.0 SOHC
  158. keypad not working...Rock did the trick. I HAVE THE CODE
  159. 93 Exp.starts OK, runs bad after heated up
  160. 99 xlt front washer relay
  161. 94 Explorer: Is the PCM the issue?
  162. Removing Filler Hose - 96 Explorer
  163. Cruise control lights in steering wheel
  164. 96 Explorer - Fuel Pump?
  165. I had my keypad reprogrammed
  166. 95 Eddie pass side headlight out
  167. 02 Explorer Climate Control Squeak
  168. 94 Ford Exlorer Electrical
  169. 2003 Eddie Bauer heated seat problem
  170. 2002 Explorer Rear Differential
  171. 02 explorer glove compartment light wont go off!
  172. No heat control 97 EXPLORER EDDIE BAUER
  173. check engine light on
  174. Idle Question...
  175. what can i get for my explorer
  176. Keypad code
  177. noise in front end
  178. front parking light bulb
  179. Engine Coolant Temperature sensor housing
  180. Its "hot" in my 96 explorer!!!! Whats a girl to do???
  181. Oil Leak in 2000 Ford Explorer XKS
  182. 2004 Ford Explorer Dash Light????
  183. 2000 Evap Inc and 171 and 174 Codes
  184. 99 Explorer Hard Start and Rough Idle
  185. valve tapping
  186. 2001 Explorer Sport - Seat Belts
  187. 2001 Explorer Sport - Rear Window Wiper doesn't touch rear window
  188. 2001 Explorer Sport - Power lock on driver side is broken
  189. 99 explorer probs
  190. O/D OFF blinking on 99 Explorer
  191. Fuel Filter Replacement w/pics
  192. 95 explorer shaking badly at idle
  193. '03 Sport Trac heated seats
  194. 04 XLT ABS light stays on?
  195. 2003 explorer sport trac fuel problem
  196. leakage from head gaskets-95 Exployer
  197. rough idle
  198. alternator issue
  199. 2002 4.6 Liter Engine Knock
  200. Location Unknown
  201. 2003 Explorer, Assorted Problems
  202. Best Leather Conditioner for Ford Leather?
  203. Vents won't work...
  204. 2001 Ford Explorer-Shaking at 3,700rpm in Neutral
  205. 93 ford Explorer 4WD selector switch problems
  206. 93 Explorer 4wheel drive selector switch problems
  207. Explorer won't start unless gas pedal is depressed
  208. 2000 Exporer oil problems
  209. 02 Explorer Serpentine Belt Tensioner Problems
  210. wheel bearing spacer
  211. Fuel tank leak
  212. 1997 AWD 4.0 Gas Mileage
  213. More Horsepower wanted
  214. Od Light Blinking
  215. no air coming out of front vents
  216. Pitman arm
  217. 2003 explorer upgrade to Dual Climate Ctrl./other mods
  218. small problem....
  219. 2000 Ford Explorer-Idles up and down
  220. Break lights don't work on 98 explorer
  221. Help (related to EGR)
  222. Fuel filter location?
  223. Evap system hiss....need input!
  224. 97 explorer drivetrian grinding noise
  225. 2002 Transmission Slipping
  226. 2002 Explorer stuck in 4 low
  227. 2003 Explorer Sport stalls at idle
  228. 96 Ford Explorer - Transmission
  229. blower motors stays on
  230. Window Switch Not Lit
  231. Thermostat and tranny shudder
  232. 00' Brakes
  233. Engine greasing
  234. Electrical issues with 96 Eddie bauer edition
  235. 90,000 mile service
  236. help needed 94 exploder
  237. 94 explorer wheel problems
  238. purchasing 2002 Explorer XLS
  239. Replacing the door behind the front ducts on an 2004
  240. synchronizer settings
  241. 2001 Sport Trac Winding Noise
  242. 95 Explorer electrical issues
  243. 00' Tailgate woes and drivers lock issues
  244. 00' Tailgate replacement/Drivers door lock issue
  245. 99 for explorer suspension squeaky
  246. '92 Explorer 4x4 stalling
  247. Problem - Driver Window Only
  248. Diagnostic Codes
  249. 98 Explorer Sport Not Blend door issue
  250. Should i buy...'04
