Pulleys
evilbeef
01-26-2005, 01:10 PM
I was going to put AEM pulleys and underdrive pulley on my 97 civic ex i was wondering how hard they are to get off. The little ones dont look bad but i cant even really see the underdrive pulley.
exman98
01-26-2005, 09:47 PM
I am looking at doint the same thing very soon myself.
anyone know anything
GScivic7
01-27-2005, 12:16 AM
Underdrive pulley? Correct me if I'm wrong, but they call light weight pulleys underdrive pulleys cause that is what they do. The lighter weight lets the pulley spin just as fast with less force. You don't have a pulley that is called an underdrive pulley.
You have a crank pulley, power steering pulley, alt pulley and A/C pulley. So which one are you talking about?
BTW: replacing the crank pulley is a bad idea. The crank pulley has an integrated vibration damper/harmonic balancer. If you get rid of this your engine will do bad things like spin crankshaft bearings.
superbluecivicsi
01-27-2005, 03:29 AM
i personally believe underdrive pulleys are a waste of money.
i also believe the only time you should change a crank pulley is if you were SCed to increase boost.
dat1laosguy
01-28-2005, 07:52 AM
i had it on my car it fell off because i didnt put a tread lock on it so dont forget that if you do swap it
luckily nothing happen it fell off as soon as i pulled up to my house, right when i turned the engine off
evilbeef
01-28-2005, 12:02 PM
So are they hard to change or not
GScivic7
01-28-2005, 01:59 PM
not at all. Just don't replace your crank or alt pulley. The drag that the alt pulley's weight creates helps get that sucker spinning. I've witnessed a weaker electrical system due to a lightened alt pulley.
