View Full Version : Camaro Discussions
  1. 84 Camaro Z28 restoration project
  2. 3.8L to LT1 in 97 Camaro
  3. Sweet I think........
  4. Looking for a couple parts
  5. 01 rear ss bumper with center mounted exhaust cut outs in the bumper skirting
  6. FOg Light
  7. rear axle(camaro 2 blazer
  8. Daytime Running Lights?
  9. Overheating 96 Camaro Z28
  10. 454 Bb In 88firebird?
  11. 82 camaro z28
  12. Cat
  13. 73 power steering pump
  14. LS6 build up, 2000 super sport
  15. Ignition bypass mode
  16. Shifter For 700r4?
  17. engine in my t/a
  18. Installing upgrades.
  19. 96 TA Drivers window won't move
  20. curiousity??Front wheel drive engine work in Camaro? 2.8 v6
  21. Rear Bumber Stong?, Accident, {Important}
  22. door panel speakers??????
  23. Handling Upgrades that are worth the $’s
  24. engine knock
  25. Cowl Induction Hood?
  26. rear end thumps when i pull out.
  27. New to forum
  28. rear end thumps when i pull out.
  29. help
  30. Is it possible
  31. Tire recommendations!
  32. what tha happened ?
  33. Quadra jet Manifold for the LT1.. .Why?
  34. 3.8L to LS1 swap cost.
  35. LS6 intake?????
  36. whats the HP for 69 camaro
  37. i am retarded
  38. Headers and Y pipe suggestions?
  39. anyone wanna buy a 3000 stall
  40. Do I really need my smog pump?
  41. Recent trouble starting my '76 strange noise
  42. need some mechanical help
  43. CRACK found in cylinder head intake runner
  44. Z28 guage cluster ( ridge runner )
  45. Skip Shift Elimination
  46. GM aproved upgrades??
  47. to drag or not to darg you be the judge
  48. What is the best AFFORDABLE exhaust system to get to make my car obnoxiously loud?
  49. Keep the Monsoon head unit or replace it?
  50. LS6 intake on a LS1?????
  51. rear-end
  52. FS: 89 firebird v6 5 speed. Asking $2500
  53. Foglights...Ideas?
  54. speed sensor
  55. So do i need a whole exhaust system or just cat back....whats the difference?
  56. A hole in the Oil pan
  57. 2000 Super Sport Camaro, ram air setup.
  58. f*ckin aggrivated
  59. power windows and doors?
  60. im a little lost with these shift kits.....
  61. ASR and ABS question
  62. exhaust system help
  63. American Thunder 3.8L Catback #17358
  64. jet pcm
  65. ENGINE SWAP ON AN 84 v6
  66. Reseting the ECM on LT1
  67. Laptop Datalogger
  68. Shifting weird after new intake???
  69. Torque Converters?
  70. replacing steering column in 2nd gen T/A ?
  71. 3rd gen trans am: price range??
  72. Whats the biggest Rim/wheel size that will fit on a 94 Z28?
  73. broke down
  74. Turbocharging Help
  75. 84 tranny to 86
  76. 96-99 Gmc 350 for third gen??
  77. Exhaust Question
  78. 1996 'Howling rear end'
  79. 1996 Camaro 3.8 Pinging issue
  80. muffler or complete system???
  81. new Z28 Owner
  82. A.C. delete cover,still need heater
  83. viper t56
  84. late model SS
  85. Can anyone suggest a chip
  86. need help 89 firebird
  87. Shift Kit?
  88. Exaust Flames
  89. 1984 RS Camaro
  90. MSD Question
  91. Stock injectors or SVO 24 lb?
  92. SVO 24lb injectors?
  93. 98-02 Camaro Aluminum Drive Shafts
  94. cant find sensor
  95. 3rd gen Z28 camaro rims
  96. Few Questions
  97. lights...again
  98. dif between impala lt1 and camaro lt1?
  99. even i make mistakes :)
  100. LS1 2002 for 20G's?
  101. Is This Fake!?
  102. 35th anv ss rims for sale
  103. Aluminum Driveshaft
  104. 93 z28 dies
  105. Dyno Day + Track Day
  106. what does the SS stand for?
  107. 79 Firebird after $2000.
  108. tell me what you think of my new 99 formula...... give me opinions and mod ideas!
  109. Dashpad
  110. Head light covers for 90 camaro
  111. off topic question
  112. 98 Trans am Top speed after 3.73 install?
  113. Supercharger
  114. Me vs. 455 GTO
  115. Mods for a 1994 camaro LT1
  116. aluminum intake manifolds, is it safe?
  117. t-56 rebuild ?'s
  118. T-65 rebuild Questions
  119. Insurance how much am i looking at?
  120. XE 230/236 cam
  121. Cavalier to Firebird
  122. my first thread. And some pics of my car 56K WARNING
  123. I fix one thing and two more go wrong.
  124. dash question
  125. Belittled V6 3800 Trying to Be GREAT!
  126. exhaust
  127. how do i find swap meets in my area?
  128. rochester quadrajet
  129. Rear End Upgrade
  130. Problem!!!! w/ 94 z28 automatic
  131. HUGE swap meet!!
  132. Exhaust Tips; Sound
  133. Elle's (Darryl hanna's) car in Kill Bill vol. 2
  134. ignition help
  135. How many Hp does your camaro have?
  136. 10-Bolt power?
  137. NOS.... Your views.....
  138. Should there be oil here?
  139. project cars
  140. Carb for 67, 427
  141. when i start my camaro rs it puffs smoke
  142. referrals??what??
  143. help out a fool
  144. Electrical problem
  145. New Shocks???
  146. Tokico Shocks?
  147. temp gauge/ probe
  148. Horn question
  149. Tbi Vs. Tpi
  150. brake troubles
  151. Upgrading 1989 Camero Rs 5.0 Tbi
  152. 69 radiator options?
  153. insurance costs $_$
  154. how many miles does your Camaro have?
  155. Tranny Sounds Like It's Grinding When Put In Reverse
  156. Rear End Shaking
  157. switching to Bigger Wheels
  158. 86+ Iroc Z for a 17 yr old..??!!!
  159. what are the specs on a stock 94 Z28
  160. speedometer off
  161. New Paintjob
  162. like the new car?
  163. How To Replace Front Turn Signal Bulb?
  164. Tune up suggestions ....
  165. talking in inches
  166. '99 Trans-Am Headlight replacement
  167. The new 2000 Pontiac Firebird urethane kit!!11
  168. camaro -97 doesnt start
  169. new project 3.4
  170. Check Out This 5th Gen
  171. 1995 Camaro Base for sale--$2200 199k miles runs/drives great
  172. i need help
  173. hey brent!!!!!!!
  174. Fiberglass Sound Sysytem........ For Sale!!!!!!!!!!
  175. a clicking noise
  176. Modifying my Camaro RS
  177. 3.73 Odd problem?
  178. stroke or bore?
  179. tranny slippin?
  180. Will a TH350 handle 400hk? (An a little bit more)
  181. one-wheel burnout
  182. The 4th Gen rule??????
  183. For Sale LT-1 Swap. 3rd Generation Firebird
  184. Problem with interior
  185. HP loss with bigger rims
  186. Need A Race Seat
  187. Clear Coat Damaged On Iroc-z Rims
  188. body work decision (need HELP!!!)
  189. How do I shrink my pics to post on AF Gallery
  190. Fuel Pump
  191. Need HELP with 1967 RS Headlights
  192. 79, 403 lifter problems
  193. mustangs
  194. 92 rs mods advice
  195. Running to high of a temp
  196. end result of a bored ADHD child
  197. Interior Parts
  198. in bad need of some rims
  199. Confused on order
  200. How many quarts of oil?
  201. F/S 275 40 17 Dot slicks, also 315/335 35 17's
  202. My $10,000 73' Camaro engine compartment.
  203. bad driving in bad weather
  204. 4th gen engines
  205. headers
  206. 17" Dot Road race slicks, 275 40 17 315 335 35 17
  207. T-56 Clutch, new, Valeco, $150
  208. Lowering gear ratio and street legal cam shaft
  209. Tranny question?
  210. performance chips
  211. Owned
  212. Hmmmm
  213. which mod next?
  214. i need help!!!
  215. why i hate volvo station wagons
  216. Dont Do This!!!!!!!! Aarrgggggg!!!!!
  217. car won't idle after high rpm
  218. Hotest camaro ever!
  219. replaceing 81 nose and hood, for a 72 0r 73, any tips ?
  220. Help needed finding 77/78 Trans Am to buy
  221. Sensor Problems
  222. Power Programmer III for a V6????
  223. Automatic into Manual
  224. Looking for good set of headers and exhaust system for a 400
  225. Not Starting
  226. ws6 air filter
  227. Water in the trunk
  228. AT shift knob
  229. from Cavalier to Camaro
  230. can u put a turbo one a 88 v-6?
  231. Help me please!
  232. 91 RS Camaro choked on me.
  233. 1986 berlinetta
  234. Firebird mods
  235. New to forum and with backfire question
  236. puting in exhaust?
  237. Ram Air
  238. Anyone w/ V6 3rd Gen? or some Ideas
  239. Scared Camaro owner
  240. 1999 z28 performance upgrades
  241. Looking for Chrome Valve covers for a LT1
  242. 1994 and 1995 formulas for sale
  243. Engine Swap for 1984 Firebird
  244. emissions help
  245. 1991 z28 5.7 tpi quick question
  246. Obsessed with the Fbirds. <<HELP>>
  247. Car is up on autotrader.com
  248. torque converters? what?
  249. Oil Cooler
  250. no spark 93 formula
