muffler or complete system???
housy_bigmike
04-24-2004, 08:43 PM
should i buy a flowmaster 80 series muffler or the full exhaust kit for my 97 rs v6 5 speed?
z28 boy
04-24-2004, 09:06 PM
I just got the muffler. Still sounds good.
DaMoNe6969
04-24-2004, 09:13 PM
I think Just the muffler will do fine for your 3.8.. You could also look at highflow cats..
Genopsyde
04-25-2004, 02:35 AM
i'd get the whole thing
Deadcarny
04-25-2004, 11:11 AM
for a 3.8 just the muffler is fine. Really do not NEED the 3" I pipe that comes with the whole catback. Won't hurt anything to get the whole setup, but is cheaper to just get a muffler.
sykotic1
04-25-2004, 11:50 AM
what is the size for the stock piping? Could always go for custom piping into those mufflers. then you get the benefit of the larger diameter without the cost.
Deadcarny
04-25-2004, 12:59 PM
2 7/8 is stock I pipe size I believe.
ridge_runner
04-25-2004, 03:23 PM
if it was me and i had the money id go ahead and invest in the hole system, if you plan on having the car for a long time its a good thing to do, and you could go with a like 2 1/4 diam. pipe, you dont reallyneed the 3
DaMoNe6969
04-26-2004, 07:07 PM
3" exhaust is too much for a n/a V6.. It'l rob you of much needed torque...
2 7/8 sounds big for a V6 from factory?? BUt ive never looked under it.. Stock pipe diameter is perfect.. So if your not changing the diameter, why change the pipe? If its all still in good shape, Ide just get a muffler
tacoma man
04-26-2004, 07:17 PM
my 2000 camaro ss has the 40 series, sounds
damn good, has a loud rumble to it. i used to
have a 91 rs with a 3.1. i put the 80 series on,
sounded like a V8 at idle and at low cruise speeds.
but under heavy excelleration. awwww. it was
like a swarm of pissed off bee's. but the 3.8 is
more beefed up and will sound a lot tuffer.
sykotic1
04-26-2004, 08:33 PM
yeah i dont think its fair to compare the ss to the smaller engines. ive heard em with american exhaust systems but when you really open it up its hard to imitate 8 cylinders. id still go for the mufflers :-D
DaMoNe6969
04-26-2004, 09:46 PM
It doesnt matter what you get.. a V6 is gonna sound like a V6.. Specially in the higher RPM range.. But a good performance muffler helps out a lot at idle and lower RPM's.. at the cost of a smooth high rpm..
zboom86
05-03-2004, 02:44 AM
Go blue streak glass paks they are the shit less back pressure but not to much and the sound so frikin good
