Still no start 97 geo metro
Blownpiston
03-20-2006, 01:20 AM
97 geo metro 1.3 with auto trans. need help to get started. Battery charged,plugs cleaned & gapped,cables clean and tight,cranks over really good,spark from coil high tension lead to distributor,cap and rotor o.k. No spark at plugs. I suspect the crankshaft sensor, ecm, or dist. pick-up coil is bad. Anyone know how to test these parts? or at leat a way to rule any out. Thanks guys. It dosent make sense to me to have spark up to the dist. tower, but not out to the plugs, cause rotor and cap are good. What am i missing or not understanding here?
Geozukigti you out there anywhere?
geozukigti
03-20-2006, 01:44 AM
Did you check your timing belt? Assuming you did, You said you have spark.. So the sensors are fine. Have you checked your spark plugs, and wires? I'd replace the cap and rotor on your dizzy. Sounds like your problem lies in that area somewhere.
