View Full Version : '71-'87 Civic | CRX
Pages : 1 2 3 [4] 5 6 7 8
  1. Starter problems, help.
  2. 87 crx zcsohc swap is it posible need help??
  3. Timing belt install.
  4. '85 Civic coolant bleeder valve
  5. overheating problem
  6. Crank pulley bolt
  7. CRX si
  8. need help with my 86 SI
  9. Civic Mods
  10. 83 civic wagon ZC swap
  11. Tach installion on 83 civic??
  12. Quick Question From Quacker
  13. 86' crx engine swap
  14. 87 CRX-Si for sale or parts
  15. engine swap?? in my 86 CRX?
  16. 86 CRX that smokes some. Anything I can do?
  17. D15A2 HF or 1.5, what's the differance?
  18. car doesn't want to start
  19. fuel filter
  20. 87 Crx For Sale !
  21. '87 SI Cargo/Hatch Cover?
  22. engines for 81 civic
  23. Cheap Cheap 87 Honda Civic Crx
  24. Automatic Transmission Removal
  25. 1986 CRX which head?
  26. One way fuel valve and dashpot vacuum valve
  27. body kits and repair
  28. whats going on with my car??
  29. 83 Civic: How can I tell if my valves are bent?
  30. engine swap into a 78 civic
  31. really need help w/my d16a1 swap ASAP!!!!!!
  32. dash modification
  33. 86 Si BLOWOUT
  34. FS: Time to replace your Timing Belt, Tensioner, and Water Pump?
  35. FS: Reman. A/c Compressor Honda Civic 1984-1987
  36. 83 Civic Timing Belt Replacement
  37. help with cvjoints
  38. 85 honda crx 1.5 hf
  39. 2000 Honda Civic Si enine swap into 1999 Integra Gs is it possible?
  40. is it possible for there to be a 85civic 5sp fuel injection??
  41. bad news guys :(
  42. dual carb 87 civic
  43. HELP! 87 Civic won't stay running.
  44. b16 into 83 civic hatch
  45. need parts?
  46. radiator fan has a mind of its own
  47. 87 DX parts for sale
  48. Help me find Custom Seat covers for my 91 CRX
  49. ATTN cvcc wagon: Iginition Coil Wiring
  50. car don't wanna start
  51. parting out 87 civic hatch
  52. SI motor wants to die
  53. 87 body kit question
  54. Civic valve cover/idle
  55. parting a 1987 crx si
  56. 84 civic smoking
  57. 1985 Crx Si
  58. My engine swap is finally getting off the ground!
  59. 86 civic runs hot....
  60. My 86 civic Si tire shakes on the drivers side.
  61. updated list of SI parts for sale.
  62. Honda CRX Question
  63. '87 Civic starter motor wont work
  64. 1987 Civic Sedan
  65. Hello, new to forum.
  66. 81 civic front lip?
  67. 86 civic trans swap
  68. 85 sedan suspension upgrades? (brakes)
  69. CRX smokes Neon on dirt & finshes 1st place
  70. For Sale: 1987 Honda Civic
  71. Acord engine in Civic??
  72. 87 CRX carbon fiber idea
  73. '85 CRX engine swap
  74. another 86' Si PARTS
  75. '85-'87 Civic/CRX SI ECU codes
  76. spare TPS and fast idle control valve?
  77. 86 CRX parts for sale
  78. don't have a manual... need help with ECU codes
  79. my radiator fan doesn't cut on
  80. brakes
  81. suspension differences? 1500s vs CRX SI 86
  82. 86 CRX SI pgm-FI light in dash cluster
  83. 82 Civic wagon transmission
  84. 81 civic 1500DX fuel /starting problems
  85. Sohc Zc Problems
  86. Carbed 87 CRX Cutting Out
  87. 83 Civic Wagon deq failed!
  88. 87 carbureted motor swap HELP
  89. shifting/gear problem... need help
  90. AC quit - what to do?
  91. help need for my 85 crx si
  92. 85 civic after market carbs?
  93. Bad Idle......
  94. Scammed
  95. Help needed: 1977 for sale in brussels
  96. 1986 CRX DX idle rough
  97. Civic wont start
  98. 86 CRX Header
  99. Looking for CHEAP 88-91 CRX in Ontario, Canada
  100. 87 crx with 88 and later engine?
  101. Kill Switch
  102. I need info on wheel bolt pattern for 87 crx hf?
  103. Weird Question
  104. HELP! 86 crx/89 civic
  105. Source for brake calipers and rotors
  106. 87 crx si driver door rubber trim
  107. 1987 crx hf electrical problems
  108. 1st Gen CRX parts for sale
  109. Need help with pushbutton start for race car
  110. 1985 crx si headlight conversion to 86-87 what do i need?>>>>
  111. CRX finished 2'nd "barely"
  112. I want to buy a 1st Gen CVCC
  113. Civiv actualy made
  114. rims
  115. i need fenders
  116. Tuning a 1980 Civic
  117. 81 civic carb tuning
  118. Does anyone have a '86-87 CRX Si with a blown engine for sale w/in 200 miles of Spri,
  119. '89 Integra dash in 86 CRX?
  120. 86 crx hf w/B16a
  121. 87 CRX Si Hard Morning start
  122. Head light
  123. 3g Civic website
  124. '85 1G CRX cuts off!
  125. Aftermarket & REAL EDM, JDM Parts 4 Sale!!!!!!!!!!!!
  126. Finally got a Honda! Need Help
  127. Can I use ZC Pistons On A D15A2 87 Civic
  128. RARE JDM RHD 1988 CRX Glasstop For sale!
  129. Radiator Fans
  130. 87 CRX SI on dirt / Crank pulley
  131. Raising the Ride Height
  132. Parts for my '83 Civic Hatchback 1.5DX
  133. 1987 civic wagon problems
  134. Vote for my rear panel cover!
  135. Back Seat
  136. 86' Si Venice,FL Engine Trouble
  137. Intake Manifold swap question
  138. Wtb Manual Transmishion, Need Manual for '87 CRX
  139. Building the D15A2
  140. 87 CRX Si color code needed
  141. NeW cAr!!!!!
  142. Clutch problems.
  143. Lurk lurl lurkers...
  144. Can You Put 12V Head on D15a2
  145. Parting Out 87 CRX SI 5 spd
  146. Weird Overheating 87 Civic
  147. HELP - 87 Civic Wagon smokes after valve Job
  148. I need some CRX parts plz
  149. boring the ew4 motor out
  150. Power Windows anyone?
  151. 85 Civic Cooling Fan
  152. sorry about the already covered question(if it was)
  153. New or NOS rubber trim?
  154. PLEASE READ THE THREAD "a really bad idle"
  155. can you use cold air intake kits from a 2nd gen to a first gen
  156. 87 crx dx upgrade to si motor
  157. Anyone else have an old school CRX w/B16 & JR supercharger??
  158. 87 CRX Si ECU help
  159. CRX tails for sale
  160. loss of compression/ help
  161. turbo kit for 3g civics
  162. my hazard lights don't work
  163. transmission fit ?
  164. Engine Code?
  165. Weird Idle After Warm
  166. parts for 3gers
  167. YOU NEED 80s CRX PARTS?
  168. What will bolt into 84 CRX HF?
  169. 85 1.5 High rev miss ?
  170. Temperature gauge not reading
  171. 86 si engine up for grabs...
  172. No. 1 box
  173. valve cover and oil probs.
  174. diplacement
  175. 87 CRXsi electrical help needed
  176. Please Post D16A1 Swap Info Here
  177. engine question
  178. need help with crx engine swap to do list
  179. cuderbone
  180. !987 CRX planing a ZC swap and need help
  181. Timing belt running out???
  182. 86 crx si oxygen sensor
  183. 86 civic si brake conversion help needed
  184. '87 Engine Swap
  185. They do follow you home!
  186. I need a body for a 1987 CRX Si
  187. '84 CRX for sale
  188. 1987 CRX HF engine swap
  189. front speakers
  190. ecu swap
  191. What goes in this hole?
  192. font end mod question
  193. help me plz!!
  194. Fuel filter 87 CRX
  195. 86' crx zcsohc vtec(need help)
  196. 1986 crx si and 1985 crx hf for sale in texas
  197. in need of dc sports header
  198. 86' crx si
  199. parting out 87 CRX Si
  200. should I sale it?
  201. This Old Honda..
  202. buying plastic parts for 87 crx
  203. air filters
  204. lowering a 87 stock 87 crx with stock suspension
  205. euro tails for a 87 hatch
  206. control box
  207. Miss, low compression, and no problem found.
  208. Fuel Pump Voltage
  209. Engine Swap options for my 1986 Civic Si HB
  210. need help?
  211. which ones best
  212. 86 Civic DX and 87 CRX Si Engine Swap
  213. 1994 Honda Civic
  214. Is there Any Out There?
  215. anyone selling ???
  216. ? crx dan?
  217. 1st gen crx taillights for sale
  218. need help with my mini-stock crx pleease!!
  219. Acquired an 85 civic..
  220. suspension
  221. Will this CRX lip fit a hatch?
  222. fuel fouled plugs
  223. 86 Civic Wagon, 1.5 with burned valve!
  224. bodykit?
  225. 87 carbed crx
  226. 87 civic engine swap to a si from 91 hatchback
  227. where do i start?
  228. Need new valve seals for 1985 civic wagon
  229. New crx pics
  230. Clutch Problems
  231. 87 crx carb warm idle
  232. Trans Trouble
  233. tokicos made for hatch&sedan ????wagon?
  234. Breakin down
  235. 86 1.5 overheating
  236. MUGEN brand new muffler
  237. 1986 civic si
  238. My 87 CRX Si
  239. Talk to me daddy
  240. Fuel Problems???
  241. newbie question--why is the perfect sleeper so rare?
  242. WTB: 1st gen Si wiring harness..cash paid
  243. 87 civic motor swap question
  244. 95 civic front bumper on 86 crx si?
  245. Newbie
  246. 86 Civic swapping question
  247. carbed d16
  248. CRX wanted!!!!!
  249. Specs
  250. Track or drag?
