View Full Version : '71-'87 Civic | CRX
Pages : 1 [2] 3 4 5 6 7 8
  1. 83 civic hb 1300
  2. Very fast idle on warmup
  3. Dissasembled the fast idle thermo valve cant get it back in one piece. Help!
  4. Is it safe to open the 1985 Civic 1.5Si injectors for clening?
  5. I really need help now.
  6. 87 wagon wat gears
  7. Honda 1500 won't start...still
  8. New to Hondas Need Cyl head help.
  9. D16a1
  10. 84' CRX starting/running problem
  11. Parts for 87 CRX SI
  12. performance parts
  13. motor swap / need some help
  14. b16 + 87 crx si = ????
  15. How do I lower the idle on 86 CRX injection
  16. How do I lower the idle on 86 CRX injection
  17. How do I lower the idle on 86 CRX injection
  18. How do I lower the idle on 86 CRX injection
  19. How do I lower the idle on 86 CRX injection
  20. How do I lower the idle on 86 CRX injection
  21. How do I lower the idle on 86 CRX injection
  22. How do I lower the idle on 86 CRX injection
  23. How do I lower the idle on 86 CRX injection
  24. 2nd Cylinder In Mi 87 Crx Full Of Oil
  25. pcv valve
  26. D16A1 or ZC?
  27. Wire tuck things to remove
  28. engine swap 87 civic si help
  29. Need help asap
  30. Keihan carb on 87' civic
  31. Tax Return HELP?
  32. engine mod??
  33. Honda CRX alloy rims
  34. 87' Civic won't start
  35. what happen
  36. fender swap
  37. engine
  38. help me 87 civic SI hatchback body kit?
  39. Electical Issue?
  40. motor swap
  41. 87 civi si Bogs on accelreation, eventually will stall
  42. wheel spacers
  43. how do i remeve the brake rotor???????
  44. smoking when car is still cold
  45. Oooops
  46. Throttle body swaps for 87 si
  47. 83 1500s EM1 head swap
  48. starting up
  49. 87 heads
  50. 85 crx motor swap
  51. Location of the coolant temp sensor and the crank angle sensor
  52. A good little link for christmas from me to you
  53. ZC1(D16A1)Piston question and some other
  54. Firing orders
  55. D15A2 to D16Z6 questions.
  56. Long time no see
  57. 87 civic crx idled funny, now won't start.
  58. engine swap
  59. 87 civic loses power on interstate or going up hill
  60. She idles so rough
  61. hf vs dx/si motors
  62. selling a 4th gen civic
  63. Rover 213SX - 3rd gen Sedan
  64. Cold start unit removal???
  65. 87 CRX battery draining
  66. 83 civic swap
  67. Sponsorship
  68. Hood pully problems
  69. 1987 Honda CRX engine swap
  70. Complete Honda Civic Wagon 1500 engine
  71. clicking?
  72. Instrument panel brake light
  73. 87 CRX quit running
  74. parting CRX
  75. d16a1 integra motor in 85 crx
  76. d15b2 swap into a 87 Si?!
  77. Engine Swap Help!
  78. Heater Core?? Or Thermo??
  79. OT: She said what???
  80. Need D15A2 Head - Quick
  81. i need some info on d16a1
  82. 86 crx hf stalling itself
  83. dual webers vs 3bbl edelbrock
  84. Fuel Pump for 87si Civic HB 1.5L EFI
  85. polyurathane bushings??
  86. 86 HF running hot
  87. 2nd gen fenders
  88. Static Timing for an 83 1500 cc Civic
  89. baseline (static) timing on 84 1.5 liter ?
  90. 87 Civic HB Fuel Tank Removal /Cleaning
  91. 87 si front camber problem
  92. Looking for spare parts for my 87 crx hf
  93. Rip 1983-2005
  94. Front-end Swap
  95. Sunroof problem
  96. 84 CIVIC DX 1.5 eng.
  97. 87si to ZC swap parts list
  98. '84 CRX where are the relays
  99. carb vs fi
  100. Engine swap Civic 86 EW1 to EW3
  101. Sick and tired of missing.
  102. 87crx tranny?
  103. '84 CRX wont turn over help!
  104. crx d15 swap with 93 civic dx
  105. Honda Turboz
  106. 87 crx si alternator removal
  107. motor swap question
  108. 87 crx flashing battery light
  109. off topic, but 1st gen crx related
  110. WTB: 85 CRX Si Distributor
  111. will this tire size fit?
  112. Car wont start, no oil...
  113. Water on the spark plugs...
  114. crx brakes
  115. '86 CRX SI EW4 motor/tranny for sale
  116. Sudden Dying
  117. URGENT: major leak, lots of smoke
  118. coil cracked
  119. ok car guys this is a tough one
  120. 87 Honda Civic Si running problems
  121. junkyard carbs?
  122. 87 crx si budget mods??
  123. how EZ 87SI to sohc ZC swap?
  124. wireing harness
  125. will 87 crx si front shocks bottom out
  126. 78 cvcc wagon motor swap
  127. 86 1.3
  128. What does crx stand for?
  129. crx dx
  130. 84 civic dx - can't get alternator out of engine compartment
  131. rear bumper removal
  132. need help please!
  133. Replacing Battery Cables
  134. FS D16a1 motor parts from 86 integra FS
  135. intermittent wipers
  136. 1986 honda civic, HORRIBLE gas mileage and why?
  137. Wanted: Throttle Position Sensor--86 Civic Si
  138. intake question
  139. getting into the game '87 Honda Civic
  140. 'de-vac' question
  141. 87 crx front suspension?
  142. WTB 87 Honda CRX Lower Dashboard
  143. D15 Bottom D16 Head
  144. are 87 civic bumpers same as crx
  145. d16a1 in a 87 crx turbo question
  146. Sticking throttled position sensor????
  147. new exhaust set-up
  148. b18c5 to 87 RT4WD tranny
  149. In need of a cylinder head 4 a 87 carb'd civic DX..help..!!!!
  150. 87 civic sputters? HELP!
  151. Front fender question...
  152. rad hole
  153. Bent Valve
  154. Sunroof
  155. 87 civic problems
  156. Rad Pepper Racing
  157. Vacuum Hoses
  158. AHH Car wont crank.
  159. Crx Body Kit---help!
  160. need side skirts
  161. engine prob
  162. will a 86 civic dx tranny fit a 87 crx hf?
  163. 87 crx will not start wen hot outside
  164. I hope this isn't one of you!
  165. Pull a Part
  166. 87 CRX SI goodies forsale-ecu, mirrors, etc.
  167. 87 Wont Start.
  168. how can i make a short shifter?
  169. FS:87 crx si shell-integra d16a1
  170. Oil Weight?
  171. interior door panel re-apolstering, How?
  172. Carburetor 1983 Civic 1500
  173. need front shocks from 87 crx
  174. fender situation
  175. 1986 Honda CRX SI Axel Removal
  176. 1986 EICV valve
  177. Lights won't turn off
  178. Lining
  179. 87 CRX Si -- Throttle sticking. HELP!
  180. Will an '85 HF distributor and coil swap into my '85 DX?
  181. E-Brake
  182. Seat Cover Template?
  183. Look at the price
  184. 85-75 power sunroof
  185. New Guy....
  186. Ignitor and coil for '85DX...donor cars?
  187. Installing the serp belt
  188. Project car = confusion
  189. A/C Compressor
  190. 86 crx hf engine swap
  191. ZC Generations
  192. rear drum stuck in 87 crx
  193. crx front
  194. Help me find an engine please !
  195. Changes
  196. fiberglass fenders, nose panel
  197. Wont Start Ran Fine! Help!
  198. Surging but on a Fuel Injected
  199. AaaHhh...(passenger brake)
  200. Compression Test results? Need Help
  201. car problems
  202. Broke Timing Belt
  203. swapping in a d16z6 int 87civic
  204. Odd Brake problem
  205. 84 civic performance websites...
  206. Need info for after market parts 86 Civic Si
  207. Civic Gasket Kits!
  208. 13" Mugen CF-48's
  209. 1986 Honda CRX engine removal
  210. cheapest place to buy oem crx part
  211. How To Tell Car Type
  212. replacement floor pans...
  213. 1st gen crx parts forsale cheap
  214. I need help with Brakes!
  215. 87 crx parts forsale
  216. 85 crx engine
  217. d16a1-zc, d16a1, and d16a8 motors
  218. 86 crx head light switch
  219. transmission problem
  220. Underheating problem
  221. cly head 83
  222. 86 CRX Si Unique Hard Start
  223. H22a in an 87 crx????
  224. 87 crx si 88integra motor swap
  225. civic with issues
  226. cant find anywhere
  227. new to the honda scene
  228. cam shaft torque settings
  229. 1987 crx si want to turbo
  230. Hood opening problem
  231. transmission hondamatic
  232. cat
  233. tappet clearance
  234. 1987 Civic stalls at an idle
  235. removing the OHC Wheel
  236. Best 1/4 mile times?
  237. 85 crx si - side sill metal panels
  238. 87 civic 4wd wagon
  239. DX to Si conversion
  240. Opinions On Purchase
  241. wierd noise from Lfront
  242. fiber glass fenders for 84-87 crx
  243. 87 civic fuel pump question
  244. Miracle Product!
  245. 1987 civic wagon 1.5L dies
  246. 1987 honda civic wagon real time 4 wd
  247. new crx owner
  248. b16?
  249. help suspension/engines
  250. Really bad gas!
