electrical help
sammy004
01-01-2005, 07:12 PM
Can anyone help me out I have a nissan micra and it does not start I checked all these in order.
-I checked the spark plug wires no spark.
-then I checked the coil no current.
-then I cheked the wires going into the coil for 12 volt still not power.
can anyone tell me where I can look next. I check the fuses under the dash all good. (well the seam good)
any help would be greatly appreciated.
RandomTask
01-02-2005, 01:03 AM
Fuse... is it blown?
sammy004
01-02-2005, 02:14 PM
where would i find this fuse I looked under the dash and they all look ok should i test all the fuses instead.
rollin_on13s
01-03-2005, 12:38 PM
alot of japanese cars have a fuse/breaker block under the hood- it has a plastic cover with labels on it, and often there will be a lead from the positive terminal on your battery connected to it- It is usually within site and labeled plainly.
Do you have a service manual for your car (Haynes, Chilton)?
They usually pay for themselves the first time that you use them- or, if you're short on cash, check the library.
