View Full Version : General Discussions
Pages : 1 2 3 4 5 6 [7] 8
  1. 99 Sunfire Odometer Out
  2. AC Fan problems
  3. 1995 Sunfire Factory Antenna
  4. need help installing 6x9s in the rear
  5. Question about ac not working?
  6. 97 sunfire auto transmission shift problem
  7. 98 Sunfire - Where's the block resistor?
  8. my brand new 04 sunfire burned up in my driveway
  9. back seat
  10. Diagnostic trouble codes.
  11. error code 440
  12. 97 Sunfire .....3k Rpm Sounds Like Tap Dancer
  13. 1997 sunfire timing chain
  14. Removing stereo in a 2001 Pontia Sunfire
  15. 1998 4dr body kits?
  16. sensor problem?
  17. fuel filter
  18. 95-99 Sunfire Questions
  19. Need an aluminum wheel (16" 2 spoke) in Vancouver BC
  20. having trouble with my belts
  21. FS: Factory in dash CD
  22. Sunroof Won't Close
  23. Can any one help with a Drive Belt Problem
  24. List Performance/suspension Upgrades
  25. jacked up radio
  26. speed limit
  27. valve cover torque specs
  28. Theft system light on , no theft sysytem
  29. Please HELP!!!!!!!!
  30. getting a bodykit WEEEE!
  31. How hard is this going to be?
  32. interior
  33. track off?
  34. timing chain in 2.4
  35. engine is hard to start
  36. 1995 Sunfire Needs Help
  37. 85 olds stalls when hot
  38. Reactive Strut Bar?
  39. pedals
  40. Sounds Like Motorcycle!!
  41. More horse power
  42. 2002 sunfire
  43. 1997 sunfire No headlights
  44. help shifting plz
  45. How bad is it...?
  46. Drain plug
  47. '99 Engine
  48. Engine Issues with 2001
  49. 2001 Sunfire GT High-pitched whistle
  50. fuel problem
  51. Doesn't look good for me
  52. Sounds like...grinding?
  53. strange noice, maybe the axle?
  54. Parking light problem
  55. Brake light not working
  56. What Engine can fit for 96 Sunfire
  57. Theft system causes no start
  58. Putting rims on 2001 2.2L
  59. poor mileage 2.2L
  60. "ETS Off" light. Can Someone Help me?
  61. 1991 Sunfire Stereo Replacement
  62. 1998 Sunfire Stock Deck Wiring Specs
  63. Radio won't turn off after door is opened.
  64. Odometer display flickering
  65. Passlock alarm problem
  66. how do i get to the oil filter on 98 sunfire 2.2l
  67. 1998 sunfire 2.4 quad engine
  68. fog light problem
  69. odometer cannot switch
  70. Lights working now
  71. Exhaust Questions.
  72. Can't Handle It ~ No Music
  73. HELP:Does anyone know the firing order for spark plugs?..
  74. anyone know how to change air filter DIY
  75. Door Panel Removal
  76. Check engine light! need parts
  77. 2 sets of sunfire tribal letter decals
  78. Squeak in dash. Do I have a mouse?
  79. Parking Light problems????
  80. 1997 Sunfire Cigarette Ligther Cap and Gas Cap
  81. Sunfire steering noise
  82. Installing a CD Player in a 2000 Pontiac Sunfire
  83. 2.4 L engine timing chain noise
  84. another prob
  85. Front End
  86. rotten egg smell
  87. ETS AND ABS light on. Any thoughts?
  88. defrost
  89. Euro Gauges for 1998 sunfire?
  90. Brake pads wearing out fast???? Help
  91. Daytime Running Light Failure
  92. creaky front end
  93. 1998 Sunfire acting strange
  94. Pic's of there Sunfires
  95. Selling any accessories for sunfires?
  96. KYB AGX Shocks and Struts
  97. Bumper Inserts
  98. no spark after engine rebuild
  99. spark plug wire diagram!!..help me!
  100. what to replace to get smooth engine?
  101. Antitheft Deterrent
  102. o2 sensor and ohter questions
  103. odometer
  104. backup light sensor location
  105. need help
  106. How do you reset the dash lights?
  107. Please help me with an oil change
  108. replacing fuel filter - tips?
  109. sunfire head gasket $700 to $1000 to replace? AHHHHH!
  110. 99 Gt ETS light on
  111. HELP! injector replacement gone bad....?
  112. car cutting out
  113. High Beams not working????
  114. Gauge cluster
  115. throttle body temp sensor
  116. throttle body temp sensor
  117. ceramic brake pads and new rotors
  118. Preventing lettering from rubbing off
  119. 1997 Pontiac Sunfre ABS Brake problems
  120. carbon fiber hood
  121. 3.5 V6
  122. '96 Sunfire cranks in park but will not start
  123. 3.8L Supercharged Sunfire?
  124. Theft System 99 sunfire
  125. 2000 Pontiac Sunfire
  126. Installing new car deck
  127. Power Window Switch for Sale?
  128. transmission dipstick
  129. body kit
  130. Stupid Question from a beginner
  131. 1995 Sunfire fails to start occasionally
  132. Headlight Help
  133. Oversize oil filter
  134. !997 Sunfire Speedometer
  135. Is it possible to do this with a Sunfire
  136. Where is the headlight fuse? (98)
  137. 98 sunfire bogging out when idling
  138. easy ways to improve 0-60 time frame?
  139. I need a windshield for a 96 sunfire
  140. Back speakers giving me troubles
  141. Am I on the right track with my SunFire??
  142. Whats wrong with my car?
  143. 3.8L Supercharged V6?
  144. Interior light delay
  145. head gasket problem?
  146. Whats up with the seats in the new Sunfire?!!
  147. 1997 Pontiac Sunfire Headlight Replacement
  148. head light buzzer out
  149. new ignition switch 97 sunfire
  150. Timing Belt Change??
  151. 2002 4dr body kits
  152. why wont i accelerate
  153. car won't start
  154. Break Problems, ABS and Break Light
  155. 97 sunfire parts
  156. car acting odd
  157. 99 Sunfire Transmission
  158. underbody car kits
  159. ETS and Engine Light and head lights
  160. Where Is The Spark Plug??? 2002 2.2l 4 Cyil. Sunfire
  161. Car Stalling
  162. Oil leaking from oil filter....PLEASE HELP
  163. jbody site
  164. Keyless entry problem
  165. 2003 Sunfire, Headlight Problems due to a small accident...
  166. Oil Light Keeps Coming On!
  167. 1996 remote keyless entry
  168. ABS, BRAKE, AIR BAG light stay on
  169. stupid 4 door!
  170. Blitz Body Kit
  171. crank sensor?...more
  172. Shocks / Struts Upgrade?
  173. Sunfire headlight help
  174. engine removal
  175. breaking problems
  176. More Rear speaker Q's..
  177. steering noise
  178. Accessing/Clearing Fault Codes From OBD-II Connector On 1998 Pontiac Sunfire GT
  179. 2K SunfireSE Few help questions...
  180. Just Joined!
  181. Several problems...can anyone help?
  182. check engine light
  183. turbo...anything else needed
  184. Heat/AC Fan Works in only 1 of 4 Positions
  185. 2003 Sunfire
  186. Chip for the fan?
  187. noisy lifters
  188. Air Bag light on 97 Pontiac Transport Montana
  189. coolant light
  190. Mysterious clunking sound when braking
  191. 2003 sunfire car mounting kit
  192. Pontiac Sunfire gt Parts for sale
  193. Help...Car is shutting down after 2-3 kms.
  194. 1996 Sunfire Headlights
  195. Stiff steering
  196. Car glass fogging up deffoger not clearing
  197. clear turn signal for 2000 sunfire
  198. Lookin for a few pointers, Plz help
  199. '96 Sunfire dies at stoplight !HELP!!
  200. no heat
  201. 2001 sunfire abs light comes on
  202. Should I buy?
  203. Radiator plug problem - 1997 sunfire
  204. 1996 Sunfire Headlight Disassembly??
  205. major problem.. please help
  206. Cold air intake
  207. wire harness problems, PLEASE help
  208. Car Wont Start?!??!
  209. remote starter/headlight fuse problem
  210. 1996 engine hum
  211. MP3 Player
  212. Remote car starters
  213. Car stalls when put in gear
  214. Wheel speed sensor
  215. Haynes manual
  216. Need a new engine for 95 GT fast, please help!!!!!
  217. Air fuel meter
  218. 2004 sunfire sound system,annoying feature(cd player)
  219. Headlight Adjustment Guide?
  220. Possible Alternator problems??
  221. 2003 sunfire oil filter!
  222. installing new seat covers
  223. sunfire seats/mounting brackets
  224. removing headrest: 2dr 2001 Sunfire
  225. Rear Speakers
  226. Where can I get an ECU chip for my 1996 Sunfire GT?
  227. whirring noise when starting
  228. Late Model Sunfire Custom Interior Trim
  229. Exhaust Tips
  230. Transmission Trouble
  231. Painting Interior brushed metal look
  232. Cheap Speed Chip Mods
  233. 95-97 intake vs. 2000+ intake
  234. Cold Air Intake
  235. Transmission vacuum whine?
  236. Passenger Side Mirror Installation
  237. need info from manual, PLEASE!
  238. transmission problems
  239. 1996 sunfire
  240. Engine Swap
  241. Water Pump
  242. HELP! 95 GT cuts out while driving?!?
  243. Trannys!
  244. Wiring Diagram
  245. ABS & ETS
  246. Sunfire Torque Converter Problem
  247. Banging sound when turning
  248. Restrictor Removal?
  249. Boost my Sunfire's output?
  250. Dim Right Headlight?
