View Full Version : General Discussions
Pages : 1 2 [3] 4 5 6 7 8
  1. Oxygen sensor replacement
  2. Resistance on Plug wires
  3. 1999 sunfire 2.2L wont start
  4. cylinder head replacement
  5. 1996 Stalled then No start situation
  6. rear struts ?
  7. 1999 2.2 sfi electrical problem
  8. 97 sunfire needs engine
  9. Engine problems, 01 2.2L sunfire
  10. auto to manual
  11. 1997 Sunfire Wiring Question
  12. spark plug
  13. Shifting issues
  14. 2002 Sunfire arm control bushings???
  15. Thermostat? 97 2.4
  16. 1997 Sunfire Starter Wiring Help
  17. 2.2 01 Sunfire Power Loss
  18. Tcc
  19. back-up lights
  20. headlights 80 / 100
  21. 1998 Sunfire: one dim headlight ?
  22. Overheat!!! 1999 sunfire
  23. Leaky injector 2
  24. '97 Sunfire AC Vibrates!!!!!
  25. New computer for my 98 sunfire...
  26. 2000 sunfire lights and starting problem
  27. Not 1, not 2, but 3! 97 Sunfire 2.4, alert lights
  28. 2003 2.2L ecotech oil capacity
  29. 2003 2.2L ecotech oil filter
  30. Pontiac 2.2L head change?
  31. blowen head gasket or cracked head?
  32. power loss 2.2L
  33. 97 Sunfire 2.4 Signal Control Arm
  34. Bleeding Air from Radiator
  35. Tires
  36. 1997 Sunfire, 2.2L Check engine light on..
  37. 96 Sunfire Difficult To Start in Rain
  38. 97 Sunfire 2.4L Wont turn over
  39. auto vs standard again
  40. new exhaust
  41. 1996 - no tach, no temp & all dash lights lit up
  42. Alternator in 97 Sunfire, 2.4
  43. 2002 Sunfire Trouble
  44. Someone?? Anyone w/ knowledge? Please??
  45. sunfire 1997 speakers
  46. How do I know my water pump needs to be replaced?
  47. 96 Sunfire Convertible SE 2.4 stalls constantly
  48. FS: 1996 sunfire 2.2 ohv
  49. Switching Turn Signals from a '99 GT to a '02 SE
  50. Is 2.4L engine a bad engine type
  51. need help with 2.2 sunfire
  52. wheel bearings
  53. 97 sunfire problem with antitheft
  54. 98 sunfire 2.4L missfire when ideling
  55. Sunfire GT for sale low miles 8900
  56. e85
  57. wheels
  58. klunk when starting.
  59. rad fan problem
  60. Leaks!
  61. '99 Sunfire GT questions
  62. 2001 sunfire trans problem...
  63. question
  64. Trouble Codes
  65. enging missing or something?
  66. need 2.2l engine info.
  67. Re-Mounting Rear Speakers '02 Sunfire
  68. Need help replacing front struts on 01 sunfire
  69. 2.4 numbers
  70. Cavalier For Sale (so i can buy another one lol)
  71. New and Clueless (no back up lights
  72. ETS problem
  73. Exhaust Leak
  74. overheating problem
  75. '96 Sunfire 2.4L, Auto tran. Is this a problem worth fixing?
  76. Removing calipers on 01 sunfire
  77. 2.4L Tranny Fix
  78. 2003 Sunfire
  79. Stereo Problem
  80. Sunfire Wiring Problems (I think)
  81. 2002 Sunfire, Speaker Removal
  82. where is the tcc solenoid?
  83. No Spark
  84. 1998 Sunfire GT ?'s
  85. 95 sunfire, bad gasmileage and low coolant light
  86. Adapter for 5 1/4" door speakers
  87. Momentary hesitation at highway speed (2001)
  88. Clutch Problem 99 Sunfire
  89. Gas Tank Question
  90. "96" sunfire rough idle no power
  91. Are Sunfires fairly reliable & good to buy used?
  92. high RPM
  93. Heater control not working on low
  94. Chick with no clue
  95. Shaking/jerking at high speeds
  96. misted windows
  97. stall
  98. Codes
  99. Rough shifting
  100. Door Hinge Bushing Replacement?
  101. Fuel line leak
  102. DRL headlights: please help!!!
  103. rotor or bearings
  104. how to check codes
  105. 2003 Sunfire Repair Manual
  106. Sunfire Wont start
  107. Headlights
  108. Help! Noise coming from tire area
  109. Another alternator dead
  110. 1998 Sunfire need help fast
  111. new radio
  112. Radio antenna
  113. Cold at 2500RPM+... doesn't quite overheat?
  114. Terrible noise
  115. Remote Replacement--warning!
  116. idle speed control motor
  117. 1997 Sunfire Non Shifting Transmission
  118. Light problem
  119. oil light
  120. 1999 Pontiac Sunfire Question
  121. 97 SF overheating and blowing coolant
  122. 99 sunfire
  123. Door won't open - wind whipped door back
  124. Problem with one of my power windows
  125. 99 Sunfire misses at idle speed
  126. 97 Pontiac Sunfire Xenon 9007 Bulbs
  127. How to Remove Air Trapped in Radiator
  128. 98 sunfire rad fan not coming on!
  129. 96 Sunfire GT rough Idle no power and sucking gas
  130. Bunch of small problems
  131. 2000 Sunfire GT with noises! PLEASE HELP!
  132. Check Engine Light
  133. '96 Pontiac Sunfire Losing Power
  134. Koni Shocks (Rear) Install
  135. help with 98 sunfire 2.2
  136. ABS, Trac Off, Service lights
  137. do i have a plugged cat.?
  138. Fog Light Relay?
  139. Warped rotor
  140. power steering pressure hose line question
  141. 2002 Sunfire Gauges going crazy
  142. drivers side doesnt defog
  143. rear defrost switch buzzing
  144. Fluid leak-weird place
  145. new air intake
  146. 2001 sunfire
  147. Theft code car will not start
  148. 98 Sunfire P440 Code
  149. Safety Feature
  150. 1997 Pontiac Sunfire GT FOR SALE
  151. Engine coolant light comes on
  152. first car help
  153. Thermostat Housing - 95 Sunfire
  154. No wheel lock key
  155. Desperate need of a wiring diagram
  156. Ecm
  157. for sale
  158. V8 Sunfire
  159. 03 Sunfire Headlight wiring problems
  160. Annoying Problem
  161. Bumper repair
  162. No high beams or daytime running lights
  163. Loose BOLTS!!!!!
  164. Transmission Dipstick
  165. MAP senser
  166. dash dimmer switch
  167. 1997 Sunfire Pontiac
  168. 2002 Sunfire VLX
  169. 1996 Sunfire Engine Wiring Harness
  170. press. test
  171. fuel pump relay going crazy
  172. 94 Sunfire/sunbird that sounds like a lawn mower
  173. 2002 Sunfire Wont Turnover
  174. Intermittent Starting problems
  175. 2002 sunfire help needed
  176. Low idle problems
  177. 1997 Sunfire start problems
  178. Engine Swap
  179. 96 Sunfire...fuel pump isn't coming on
  180. Eco-Tech oil filter cap
  181. 98 Sunfire Stalls On Slow Left Turn
  182. 2000 pontiac sunfire just bought yellow light on wont go off circle w/slash though it
  183. oil light comes on and check engine light comes on
  184. remote start help
  185. Did I break something?
  186. A/C Blows out of all Vents. Why?
  187. '96 sunfire Daytime running lights help
  188. interior leak from rain
  189. Blower Resistor
  190. 2003 sunfire headlight problem
  191. 1995 Sunfire GT won't start
  192. Frosty windows
  193. 2002 Front Door Woofers
  194. 96 Sunfire, 2.4, auto
  195. Door Switch
  196. Im thinking alternator problem
  197. radio problems
  198. Starter/Solenoid how to?
  199. 2000 Sunfire GT
  200. Light problems
  201. 2003 Sunfire stalls while driving
  202. 1996 sunfire starts and dies
  203. Installing air intake
  204. Do I have a blown head gasket?
  205. Sunfire transmission problem
  206. fuel needle
  207. Seat belt replacement
  208. Wont come out of park
  209. Crankshaft Position Sensor
  210. can i
  211. 2.2 ltr questions
  212. 2002 Sunfire Coupe door speakers
  213. How reliable are 03-05s?
  214. monsoon?
  215. Rear Brakes
  216. engine swap
  217. where is electronic flasher
  218. Faster
  219. 2001 sunfire wont start!!!
  220. Upgrade to a MP3 player
  221. Door window replacement
  222. question
  223. OK Need Serious Advice Major Engine Problems
  224. What is good gas mileage for a Sunfire
  225. Fuel Filter
  226. New owner for 1 month
  227. Are These Two Related?
  228. Manual Door Locks completely stuck
  229. heater fan making lots of noise
  230. Fumes & burning oil
  231. 97 sunfire heating
  232. 99 sunfire w/o driving lights no high beams
  233. 2001 Sunfire Windshield Washer Reservoir
  234. How do I take off my Dashboard on my 2000 Sunfire
  235. 99 pontiac sunfire, check gage light on
  236. Dash Removal
  237. 1998 Sunfire 2.2L, charging system problems
  238. removing interior door panel
  239. hard to start
  240. 1999 sunfire braking problem
  241. Alarm won't stop going off
  242. How do you remove a Pontiac Sunfire Head Rest
  243. 03 Sunfire all dash gauges gone beserk!
  244. broken timing chain = bent valves? 2.2L OHV
  245. trunk release
  246. grinding noise coming from hood
  247. 2000 Sunfire Engine Noise (HELP!!)
  248. Tranny problems ...
  249. 97 sunfire won't start sometimes
  250. 1997 Sunfire engine dies when standing in hot condition
