View Full Version : General Discussions
Pages : 1 2 3 4 [5] 6 7 8
  1. Remote Start Stopped Working?
  2. Convert from Power to Crank
  3. 00 Sunfire OEM/Wires & Color Codes Help
  4. intake
  5. ETS and Check Engine Light
  6. 1998 sunfire gt light
  7. 95 sunfire... lack of power when cold?
  8. Wanted: Sunfire Body Kit
  9. 1995 sunfire-stalling,pick up weak and burning smell
  10. 1998 pontiac sunfire
  11. Engine rattling noise
  12. New Members Please Read!
  13. ignition still on when you remove the key
  14. CD Player 01
  15. Intake install on Manual Tranny
  16. Leaky trunks
  17. my vibrant performance intake doesnt make ANY noise
  18. Which Pulley
  19. 97 sunfire, clutch = funny noise, crankshaft bearings??
  20. heel toe-ing
  21. Pulls to the right
  22. Turn Signal Fuse Shorting Out in Reverse
  23. suspension problem?? help!
  24. '96 Sunfire SE Convert -- Whole Host of Problems!
  25. 97 sunfire fuel issue
  26. buzzing noise
  27. Dumb question from dumb fat man
  28. brake calipers
  29. WTB - Ash Tray
  30. 99 Sunfire Headlight Change
  31. CD Player Error
  32. New timing chain
  33. new short ram intake messus up sensor 02 sunfire
  34. tranny or electrical issues?
  35. '96 sunfire hard starting
  36. Programming Connector?
  37. Tranny Issue 01 Shitfire 2.2
  38. Oil light and battery light came on, car quit running
  39. 1997 sunfire keyless entry
  40. Turn ignition and doesn't click-won't start
  41. Car stalling for no reason, help
  42. Love an honest mechanic!
  43. installing a blower motor for a 2001 sunfire
  44. test
  45. has anyone installed a blower motor in a sunfire prefer 2001
  46. car stalls at stoplight
  47. 1997 Sunfire AC
  48. 98 sunfire gt overheating
  49. Hey! I'm the new guy!
  50. 02 Sunfire starting problem....
  51. 97 Sunfire Cigarette lighter
  52. alarm and serivice lights are on
  53. wont start
  54. fuel leak at the injector
  55. My exhaust droped to the floor all of a sudden.
  56. 97 sunbird license plate lights help?
  57. HELP!!! Radio wiring harness colors
  58. Car won't start FUEL PUMP?
  59. Sunfire fuel pump / gas gauge. Need help
  60. help me with this car!!
  61. Sunfire Gt Check Engine Light
  62. Engine Swap for 1994 Sunbird
  63. 2000 2.2 into 98
  64. A/C Problems 99 Sunfire
  65. sunbird stall
  66. Sunfire wiper problems fixed!!!
  67. mods available
  68. question about 'Fire radio loc
  69. Note to self
  70. Im New .hello Everyone
  71. After Makret shifter
  72. Hit a curb with my car.
  73. wipers
  74. loss of power, dash lights flicker
  75. Replacing Head!!! Need help ASAP!!!!!
  76. 1995 Sunfire oil light and transmission trouble
  77. stiff steering at slow speeds (2000)
  78. Please Help if u can
  79. just making an observation
  80. cavalier trunk
  81. 2002 sunfire wont start
  82. 2004 Sunfire Check Engine Light / Bad Trunk
  83. '99 Sunfire Radio in LOC
  84. cracked exhasust valve
  85. Check engine codes
  86. My 97 sunfire has no pickup plz help
  87. 96 sunfire will sometimes crank but wont start
  88. '98 Sunfire SHUTS OFF while driving
  89. 2004 Sunfire stereo replacement
  90. window roller removal?
  91. 1995 sunfire recalls
  92. 95 Sunfire Jerking/Bucking
  93. Caliper Removal
  94. radio problems
  95. '96 Sunfire horn location
  96. Cannt get my 89 sunbird to start!
  97. changing headlight bulb on a 98 sunfire
  98. power windows for 2000 sunfire?
  99. 2000 sunfire for 2700 USD good buy?
  100. Door speakers on "upgraded" stereo
  101. 00 Strut Mounds
  102. Motor swaps
  103. Sunfire trunk help!!!
  104. 95 sunfire ABS
  105. good cams
  106. HELP! 98 Sunfire Cams gone!!!
  107. cruising control problem
  108. What Body Kit?
  109. radiator leak, noisy fan
  110. 95 sunfire coils
  111. 97 Sunfire Number 1 cylinder no spark
  112. 97 sunfire number 1 not firing
  113. Parts required for a 3800SC v6 swap
  114. adding cd changer to factory deck?
  115. fuel pump problems
  116. driver window
  117. 98 Sunfire GT... is there a rad cap?
  118. Fuel pump?
  119. Engine Warning Light On/ Gear Indicator Not
  120. 96 Headlight intermitant Mystery
  121. Headlights are SCREWED!
  122. Shift at High RPM
  123. Its official GM NEVER AGAIN
  124. DRL problem plus radio problem
  125. Help Me!!!
  126. gears
  127. water coolant light
  128. More problems with 2001 Sunfire
  129. Help
  130. DRL relay frustration
  131. fuel pump
  132. Fuel Pump
  133. head gasket
  134. Odometer Problem - Lights out
  135. well, been a while, I gots updates
  136. 2001 trac & check lights ??
  137. D D D De Frost.
  138. Washer Fluid
  139. ETS light came on.
  140. Break Problem
  141. 2003 sunfire DOOR & fender rubbing HELP PLEASE!!!
  142. 2001 Digital Odometer
  143. Please Help Me With My Coilovers
  144. 2000 sunfire check engine light
  145. 2003 Sunfire radio replacement problem?????
  146. Coolant in snow
  147. Question about the windshield washer bottle
  148. 02 sunfire dies while driving - clutch is IN....
  149. 96 Sunfire GT Idle / Power Problem - Question...
  150. 95' Sunfire Help
  151. Ecotech?
  152. cold start
  153. DRL and Headlights out HELP!!!!
  154. Bodykits
  155. Transmission Help!
  156. 2001 Sunfire stalls_will not start
  157. High compression heads
  158. Question Urgent Please Help!
  159. 1997 Sunfire wiper problem
  160. Teenager in need of help
  161. Sunfire GT '99 Lock Question
  162. 96 2.2l Timing Chain Noise
  163. 95 sunfire 2.2 Clutch help?
  164. Location of Water Pump in 2.4L Sunfire?
  165. Heater not quite right-any ideas?
  166. Fuel problem??
  167. Coolant in oil problem source?
  168. Need help
  169. Changing shifter knob
  170. Oooh ....ADMIN?
  171. Engine Swap
  172. RPM drops below 1k when wheel turns
  173. 98 sunfire se stereo problems
  174. Sunfire 1998 rear struts
  175. tail light terminal
  176. Yeah please someone help
  177. Looking at getting a Sunfire...
  178. 1999 sunfire transmission dipstick
  179. Won't crank/coolant problem...related?
  180. transmission problems
  181. 1996 pontiac jerks a little......
  182. Removing side panel
  183. 99 Sunfire Something's Up With My Brakes!
  184. Dashboard Lights
  185. 98 sunfire DRL problem
  186. Need some input (about car audio)
  187. Thermostat
  188. JVC KD-S5050 displays "See you" then turns off
  189. CD Receiver issues
  190. installation instructions for coilover kit
  191. Headlights-wiring harness
  192. Body effects
  193. ABS and BAT light
  194. driver door locks
  195. Car running missing at times
  196. Ets
  197. Clutch Plate Drag
  198. 98 sunfire GT brake problems
  199. 1996 sunfire w/ 2.2 running real cold
  200. 2000 sunfire question
  201. 2002 power steering
  202. Pont. Sunfire Backup lights
  203. 2000 Sunfire - engine light on/flashing
  204. Help Please!
  205. 2003 sunfire need help fast
  206. heater in 97 sunfire
  207. 2002 Sunfire GT and Doors/Locks Freezing :-(
  208. 1996 Sunfire GT starting problem
  209. Real Stupid question.
  210. 96 sunfire wipers
  211. 04 Sunfire
  212. service and abs light always on
  213. 04 Sunfire
  214. Fuel pump relay
  215. 95 sunfire grinding noise
  216. need help!!!!!
  217. sunfire radio
  218. needles don't work help!!!!!!
  219. New Car Troubles
  220. Monsoon Stereo Calibration 02 Sunfire-
  221. engine dress up
  222. Help on 1994 Sunbird LE
  223. Ignition misfire
  224. monsoon Stereo Install on 2002 Sunfire
  225. Keyless entry pad programming 2002 Sunfire
  226. 2001 sunfire hood
  227. Water Pump Leak 1997 Sunfire Gt
  228. shifting problems
  229. 2000 Pontiac Sunfire coup
  230. I have no idea. You have to read thread to understand.
  231. New problems after the -35 degree weather
  232. NO REAR Defrost, need major help
  233. Serpentine Belt Replacement Tip
  234. 96 Sunfire stalls for 15min, starts agian
  235. Replacing Amber Turn signals with clear
  236. Cat... removed
  237. 1998 sunfire cd player registers "E 20"
  238. 2000 SE: AC Compressor/blower motor/speakers
  239. forum woes
  240. New Subforums
  241. Overheating
  242. Magical Mystery wiring 95 Sunfire
  243. clutch i think
  244. RPM and Milage gauges go haywire
  245. code P1887
  246. 2000 sunfire timing problems HELP
  247. Recently got a 95 Sunfire
  248. 96 Sunfire Acceleration problems
  249. Bright Headlights
  250. 96' Back light for insturment cluster won't work
