View Full Version : General Discussions
Pages : 1 2 3 [4] 5 6 7 8
  1. trany fill up on a manual 2.2L
  2. Trunk latch broke
  3. 1996 Sunfire engine miss at 4000RPM
  4. 1995 sunfire, looking to buy it but have questions
  5. 96 Head Gasket - Removing Intake Manifold?
  6. Changing plugs and wires on Sunfire
  7. fuel pump problem
  8. 2000 Sunfire turn signal flashing rapid...
  9. 91 Pontiac Sunbird 4 cylinder
  10. 1999 sunfire problems need help bad
  11. Strange trans shifting on cold mornings
  12. Strange shifting on cold mornings
  13. Sunfire 03 huge steering problems
  14. Steering sounds like rubbing vinyl
  15. Air conditioning comes on when on defrost
  16. 2001 Sunfire Sqeak or Rattle from Front Strut Bearing Mount
  17. 98 GT Pcv Valve And Fuel Filter Loctions???
  18. No defrost
  19. J-body Parts 4 sale from a reputable member!
  20. Failed Emission Testing
  21. OBDII code problem
  22. 95 sunfire engine prob
  23. 1997 Sunfire - washed car now wont start
  24. 2.4 sunfire GT turbo
  25. 2003 sunfire check engine light
  26. braking problem
  27. Changing the thermostat.
  28. What to look for when buying a 1996 Pontiac Sunfire GT??
  29. Gear shift and check enine light
  30. performance parts
  31. Door was frozen to car with this mornings frost....TIPs???
  32. Power Window problem w/ my 02 Sunfire GT...
  33. 2000 sunfire heade light out dur to wiring
  34. fuel injectors
  35. Start up is sounding harsh... (2000 2.2L)
  36. 2001 sunfire GT problems engine problems
  37. 1998 sunfire o2 sensor
  38. Monsoon Sound System
  39. 2002 Pontiac Sunfire Clutch Problems
  40. cig lighter
  41. 1995 Pontiac Sunfire problems
  42. 96 Sunfire electrical wiring diagram
  43. passlock and security light comes on while driving
  44. Selling A 2.2 2002 to 2005 coil pack
  45. po401 code
  46. Altitude?
  47. 2001 Sunfire check engine light on
  48. can you help
  49. No heater blower, no power windows, no rear defogger?
  50. plug wire hook up
  51. '96 Check Engine Light on
  52. Sunfire 2.2 lifters noisy when warm
  53. noise during deceleration
  54. 00 sunfire sputtering constantly
  55. '98 pin found in oil pan
  56. 1996 pontiac sunfire 2.2 4cyl. 5 speed
  57. Fender/Bumper Replacement
  58. Help Electrical/Ignition problem
  59. 2002 Sunfire wont start on occasion
  60. rear break lock up help
  61. 2002 Sunfire GT Manual Trans Fluid?
  62. 2001 Sunfire. Alternator question
  63. 97 Sunfire GTX General Questions
  64. 95 sunfire, transmission problem?
  65. won't start
  66. Grinding Noise in 99 Sunfire
  67. 99 sunfire not starting
  68. Odd problem
  69. Starting problem
  70. Sunfire won't start
  71. Squeaky Wheel
  72. What Exhaust to get?
  73. No Daytime running or Bright Lights
  74. Need help to german Sunfire: clutch partnumbers
  75. keyless entry 99sunfire wiring?
  76. factory alarm wiring?
  77. Reprogram Keyless Entry 2003 Sunfire
  78. 95 sunfire passenger airbag
  79. 95 sunfire Computer problem
  80. Alarm System Driving me Insane
  81. 97 GT P0303 3cy. misfire HELP!!
  82. 97 Sunfire, Wet Floor
  83. 99' sunfire acting up PLEASE HELP!
  84. exhaust hanger p/n
  85. abs and brake light
  86. First Post - Introduction/Question
  87. Stock AM/FM Stereo to Stock CD Stereo
  88. Sunfire rear speakers
  89. Manual recommendation Sunfire 2004
  90. Automatic Transmission
  91. This is a nice looking Sunfire
  92. How to remoce the headrest ????
  93. Hazards work but no turning signals
  94. I need a belt diagram
  95. No power to fuel pump
  96. Rear strut towers
  97. back seat wont "snap" back into place
  98. 98 sunfire stereo replacement
  99. 02 Sunfire- Revving While Stopped or Idle
  100. The turbinator?
  101. car driving problems, timing chain?
  102. PLEASE HELP ME - 2001 Sunfire Won't Start
  103. ignition coil housing comparison
  104. Engine mounts?
  105. 1996 sunfire loses power and dies
  106. NADA vs. Kelley Blue Book price
  107. anti theft
  108. cabin air filter
  109. Engine chuckles during cold start??
  110. AutoLoc power windows installation?
  111. 2002 Sunfire intermitently stalls
  112. for sale
  113. dim headlights
  114. Help! Popping Noise in dash when ignition is turned on
  115. found problem for head lights
  116. Used oil question...
  117. any thoughts on this turbo
  118. Sunfire/Cavalier Stereo
  119. Creeking door???
  120. Fuel Filter location for 2001 Sunfire 2.2
  121. Sunfire: Rear speakers work intermittently
  122. rear brakes
  123. front speakers
  124. 2001 Sunfire Fuel Pump Reset
  125. sunfire no start
  126. Spark plug replacement
  127. Lights in Radio starting to go
  128. f/s air bag for 95-99 sunfire
  129. problems starting 02Sunfire after 6 weeks
  130. Odometer Messed Up on 2000 Sunfire
  131. Changing ATF/FILTER O-RING HELP!
  132. removing a 95 sunfire dash.
  133. Loud humming sound from fuel pump or gas filter
  134. Loud humming sound from fuel pump or gas filter
  135. Does a non-cruise control car have the workings installed?
  136. 2002 brake drums
  137. air bag light stays on
  138. 2000 Sunfire For Sale
  139. Spark plugs
  140. Engine Whine - Based on Engine Speed
  141. Adjustable coilovers
  142. Camber kits?
  143. can u put a v8 in a 2001 Sunfire?
  144. 97 Sunfire GT 2.4L 90k miles.
  145. 95 2.3 dohc engine repair or replace
  146. Instrument panel 1997 question....
  147. 2.4L starter
  148. Transmission wont shift into 3rd or 4th gear
  149. 98 sunfire has no pickup... whats going on?
  150. cd player help for a newbie
  151. sunfire mileage
  152. smoking in steering column
  153. smoke in steering column
  154. 95 Sunfire AC Stop Leak
  155. Hey all New member
  156. transmission
  157. key stuck anti-theft light on
  158. Which impedance of resistace i need to up some HPs.
  159. Governor
  160. 2000 GT Engine Noise
  161. 2000 sunfire 2.2l Not starting
  162. Price Estimate, Transmission, Starter, Signal Problem
  163. 2000 sunfire - coolant leaked and overheats ?
  164. Tried all that I could think of, HELP
  165. Location of stock module alarm.
  166. Not Working remote entry.
  167. Coilpacks/spark plug removal
  168. Positive or Negative?
  169. 1999 sunfire need help
  170. need motor
  171. 99 Sinfire radiator fan replacement
  172. 2000 sunfire mysterious problem
  173. Looking to buy soon and wonders about common problems
  174. My sister wants to upgrade her sunfire.
  175. 1991 Sunbird LE - High Idle
  176. 98 sunfire needs jump to start
  177. 02' sunfire speaker upgrade?
  178. PCV Valve
  179. 1999 Sunfire Buzzing Noise Behind Dash
  180. 2.4L throttle jumps and sticks
  181. 2.4 twin cam
  182. popping sunfire
  183. 95 Sunfire hesitates while driving!
  184. misfire
  185. 2003 Sunfire Rear Brake Issue
  186. Car bogging out when accelerator pressed
  187. how much is my car worth?!
  188. Dipstick is broken?
  189. p-flow of 2.4L
  190. Muffler hanger
  191. Sunfire - Needs New Engine
  192. 2001 Sunfire...Radio help!!
  193. music
  194. Need to Change PVC Valve? Where is it?
  195. A/C for 98 2.2 auto sunfire
  196. 98 Sunfire 2.2 automatic-motor mounts?
  197. Wheel Bearings going bad
  198. 1998 Sunfire 2.2l code PO301 misfire cyl. 1
  199. Electrical System Problem
  200. Sunfire Radio Display Hot
  201. 2005 Sunfire - fan runs after engine off
  202. 2000 pontiac sunfire keeps running hot
  203. any help?
  204. 2000 Sunfire needs new ignition key ?
  205. is it a fuel pump?!
  206. 1997 sunfire gt keyless entry
  207. body interchange years for 02 sunfire gt
  208. R134a Can Orientation
  209. 1996 sunfire stalling in warm weather
  210. Want to drop...
  211. annnoying drill noise from stereo
  212. Pontiac Sunfire 90,000 mile service is it a rip?
  213. 2005 Sunfire engine question
  214. died on interstate
  215. noisy chain
  216. 96 pontiac sunfire engine just stopped at stop light then turned over on restart
  217. Sunfire Error Code Help...
  218. 96 Sunfire w/00 2.2 Cavy engine
  219. CD player installation on a 95 sunfire
  220. 2005 M/T Sunfire Intake?? Does It Exist????
  221. 2000 pontiac sunfire- starting problem
  222. 1995 Sunfire 2-Door SE PLZ HELP!
  223. 96 Sunfire- transmission problem?
  224. sunfire revs to high when i start it
  225. 98 Sunfire Baffling Problem...
  226. 2005 at dealership
  227. Cluster light isn't working...
  228. 2002 sunfire Airbags.. WHat fits? PLEASE HELP!
  229. bad day
  230. A/C Help, New Compressor, no power to it
  231. 2002 sunfire 2.4L a/c compressor problem
  232. 1997 Sunfire Stopped & Won't Start
  233. Sunfire fuel problem
  234. howto remove window rollers
  235. 97 Sunfire Horn Problems
  236. need help with racing
  237. Rattling noises
  238. o2 sensor, bank 1 sensor 2?
  239. help
  240. 2001 Sunfire fuel problem....Will not start
  241. AC problems
  242. RK Sport Dual Exhaust System
  243. 98 sunfire 2.4 lifter question
  244. 02' Sunfire
  245. 1998 sunfire 2.4 engine knock
  246. 2000 Sunfire FOR SALE...
  247. Sunfire GT engine swap
  248. A/C Recharge
  249. Looking for cylinder head
  250. My emissions box fell off...
