View Full Version : Regal
Pages :
1 2 3 4 5 [ 6]
7 8 9 10 11 12
- 2001 Buck Regal Climate Control A/C blower
- 94 buick regal accelerator
- 96 Buick Regal Performance
- Mystery Plug
- rear brakes on 94 buick regal
- Throttle Position Sensor set too high
- Window Reg. How to rig it?
- 91 Regal 3.8 Won't Start
- Need opinions. OEM vs aftermarket?
- 1984 t-type turbo
- hey guys do you think these work???
- Performance Mods?
- 97 Regal Fog Lamps
- What is this thing!?
- 2001 Buick Regal need keyless entry programing information
- 93' Buick regal Code 39.
- 98 buick regal wont start or crank sometims
- Headlight problems 91 regal
- How To Replace Upper Transmission Cooler Line?
- 98 buick ignition switch?
- 1999 Buick Regal HVAC Blower Motor Replacement
- 97.5 GS Holds it's value?
- 1993 Regal 3800 Runs Like Crap
- transmission and engine questions
- 97 Buick Regal LS Ignition Switch
- TSP Bucik Regal 1995
- 94 buick regal bumping or cutting out
- 93 Buick Regal (3.1L) Stalls and poor gas milage!
- 93' Regal 3800 MAF sensor issue
- 99 Regal 3.8 LS Stalls Out
- 91 Regal 3.8 won't start, but idles.
- Can I change keyless fobs to another car?
- 96 buick regal wont start
- Dimmer Switch Installation help 91 regal!!!
- Swapping rear view mirrors
- engine cut-out
- Regal problem
- regal and 455
- Please help
- 91 Air Conditioning
- Cold Air Intake?
- Removing Drive shafts 99 regal GS
- Inop power windows and radio
- 95 Regal grinds and does not turn over
- 2000 gse speaker removal help
- noisy steering
- check eng, trac control,abs light on
- 97 Regal LS door hinge problems!
- Differences between trim models
- 99 regal GS engine troubles
- 87 Regal Limited Steering Wheel
- transmission shudders when shifts
- Electrical failure in my regal gs
- looking at a 2000 regal
- New To The Regal Mods
- Should I buy 01 Buick Regal
- 3800 PCV bolt?!?
- What muffler sounds good?
- 92 Regal Bolt size
- 2001 Regal Reliability?
- Burning Rubber Smell
- Low Beam NO, High Beam YES!
- Need scanner..any idea's?
- Belt Tensioner
- 83 regal ISC problems
- Water Pump Gasket
- 97 Regal LS-Odometer reading blinks
- no OD or lockup
- 1992 3.8 Regal making scraping/knocking noises
- Code 31?
- 97 Regal LS Unknown Antifreeze Leak
- was it 84 or 85 when t type was hybrid
- 1999 Regal with 2004 engine
- 1995 Buick Regal
- fog lights
- 94 Regal brake light problem
- '98 Regal - Odd Transmission Issue - 4T65E-HD
- Failed Smog Check.
- 93' regal gas gauge issue.
- REGAL wanted
- 96 regal limited 3.8
- 2001 Regal very low on power
- Oil in coolant reservoir
- Regal Air Conditioning
- 84 t-type redone engine wont start
- 96 regal 3800 overheating!
- no 3rd gear???
- harsh shift = valves sticking????
- Need some help with my remotes
- '91 Buick Regal throttle?
- Fluid Change and tune up recommendations?!?
- fuel injecters
- 1991 regal 3800
- fuel lines removel?
- antilock issues 94 regal
- Lost Lost
- air bubbles on trans dipstick
- 95 Regal Starting Problems
- Camshaft Sensor=Multiport Fuel Injection Throttle Position Sensor???
- supercharger swaps or other performance parts
- Intermittant Miss
- P/S problem
- Anti lock light anomoly
- 1991 regal gs 3800 eng
- Lift Kit?
- 2001 Regal Brake noise
- 2001 Regal Instrument Cluster Removal
- Buick Regal Questions
- Power Moonroof
- 91 Gran Sport Limited 74k Extended Warranty Worth it?
- 95 Regal 3800 service engine light
- steering wheel rubber repair
- 02 regal tranny problems
- '94 Buick Radio
- 89 Regal cooling fans???
- Fuel Gauge
- 1996 regal 3100 engine
- Topping off fuel?
- 2001 Regal Odometer Dimming
- 2002 Buick Regal Unknown Tranny Problems, HELP!
- 96 buick regal custom
- Burning smell
- 2000 Regal steers hard to left
- Doesn't want to run when engine temp is 220 in warm weather
- REGAL Fuel pressure problem
- Replace to be safe?
- Low Blower Fuse (20 amp)/Power Drop Socket???
- Window trim restore/replacement
- 98 Buick Regal won't start (intermittent)
- Engine Noise in Radio
- trans problems, no 3rd and noisy
- 96 Buick Reagle wont start, please help
- 98 regal motor knocking
- The Dancing Gauge...
- 1995 3800 Knock!!!
- Automatic Door lock Help!!
- 91 regal trans slips
- Backup Lights on with Tail Lights
- 1992 regal voltage problems
- 2001 Regal Acceleration Problem
- 95 gran sport questions
- 2000 Regal Acceleration Problem
- How Much???
- Cooling System?
- 1991 Buick Regal GS cluster swap?
- Stranded - Need Help! 2000 Regal Won't Fire
- no cooling fan operation 1994 Regal, 3.8L
- mystery noise for 94 regal
- 97 Buick
- Bad Brakes
- Supercharger Oil Change
- Where is the TPS??
- 1995 Buick Regal GS Ignition Problem
- 1997 Regal TPS Malfunction
- 2001 Regal Average Miles
- 2001 Regal Cruise Troubles
- regal 2001 passenger side mirrow
- 1993 Buick Regal
- Car Stumbles at 60k
- Ball Joint Replacement, '96 Regal
- 92 Buick Regal Air Conditioner Broken
- Nylon fuel line?
- '01 Regal Wiper "Park Module"?
- My buick 200 regal brake lights stay on when car is off and cold!
- 90' Regal Dash Removal
- R and R of 99 Regal Blower Fan
- Light indicating the gear the car is in?
- firing problem
- Regal FOB Not Working
- 2001 Regal no dash lights
- '93 regal gs start problem
- changing brakes on a 2001 regal?
- 1999 regal ls fan/blower problem
- 97 Regal GS Hesitates while driving
- transmission band adjustment
- 1993 Regal, Engine Cutting Out...
- 92 Regal strut plates seize
- 92 regal wiper problems
- fans
- `91 Buick Regal (3.1L) probs accelerating!
- 92 Regal Voltage problem
- 2001 Regal LS - no dash, or tail lights
- 90 Buick Regal
- 93 Rear sway bar
- 1991 Regal GS chassis computer or?
- 2000 regal gse-serve engine light
- 2.8 to 3.8? Maybe?
- ABS Module , How to bleed?
- "Smart Auto Management"
- Series II 3800 upper intake fix
- 2000 Regal - Cooling Fans running all the time
- backfiring from my 91 regal
- Tapping noise and vibration when cold, Regal 2001 3.8 v6
- weak fuel pump.?
- 1992 regal get to battery
- 98 buick regal GS intermittent turn signal problem
- Will steering wheel controls work with aftermarket head unit?
- Buick Regal Computer Replacement
- 1989 Buick Regal Turn Signal Failure
- 96 3.1L Engine noise
- 91 regal limited no power going uphills. gutless. why?
- 1983 regal v6 to v8 swap questions
- Power steering resevoir location
- 91 Regal GS f*up starting
- 92 buick regal leaks antifreeze when heater is on but not when heater is off
- 92 Regal rear spark plug access
- 96 Regal Intermittent starting problem
- 2003 Regal Key FOB Programming
- How to change spark plugs on 87 Regal Ltd. 5.0
- Various problems with 1990 Buick Regal GS
- update on electrical woes (95 Regal)
- Glasspack muffler?
- 1994 Buick Regal GS engine swap
- 96 Regal Custom: Headlights
- Strange noise above 30mph
- 96 Regal Limited Oil ?
- Engine noise oil light help
- No headlights at all- 98 Regal LS
- Replacing Oil Pan Gasket
- help 1991 buick regal limited has a few issues
- 92 Regal charging system problems
- Another Programming Question!!
- trouble removing oxygen sensor
- '92 Regal with engine surge
- Value checker point please help
- 2000 Regal Headlight Problem
- Transmission Question
- Door Panel Removal
- GS towing?
- 96 Regal Limited
- 97.5 GS Towing Capacity?
- 87 regal/gn front transplant
- What size speakers can fit?
- Green stuff
- voltage reading
- 94 Custom 3.8L Misses at Cruising Speeds
- 94 Custom 3.8L Diagnostics
- What headers for my 83 regal+350?
- '92 Regal failed CA emissions
- drive are overdrive?
- 93 Regal Check gauges - sometimes
- 96 Regal auto power locks
- Oh the joys of trannyville
- Flashing gear indicator on 89
- Brakes, and Muffler questions
- Marvel Mystery Oil?
- 1992 regal 3.1 no start, backfires
- 99 Regal GS - Tensioner Assembly
- Tranny Problems?
- battery dead & key stuck 01 regal
| Quality Real Meat Nutrition for Dogs: Best Air Dried Dog Food | Real Beef Dog Food | Best Beef Dog Food
