View Full Version : Regal
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. 99 Regal LS stalled abruptly -electric prob?
  2. unusual idle while only in park
  3. 2000 regal-will not start.
  4. help with lights please
  5. Car alarm
  6. 4 lights always on ABS, service vechile soon, Brake and no traction.
  7. Tune up and valve covers
  8. changing fuel filter
  9. Coolant by pass elbows leaking
  10. Fast turn signal syndrome
  11. 3800 cracked head. new engine ideas
  12. Milky substance on oil filler cap
  13. 96 regal custom door stuck.
  14. Filler Neck Leak
  15. Electrical problems
  16. transmission pan leak?
  17. Disabling Automatic Headlights - 1997 Regal GS
  18. Loose door sill
  19. 92 regal limited 3.8 no hi/lo beams or parking breaks. interior doesn't dim
  20. speedometer problem
  21. Flickering & Pulsating Lights Interiror
  22. 99 Regal LS
  23. 94 Regal 3.8 VATS problem
  24. 1999 Regal LS "howling" sound -video included
  25. 2000 Regal ABS ECM replacement
  26. Is this the transmission problem?
  27. '98 Regal keeps dying, getting codes P0102 and P0171
  28. buick regal trouble in morning start up
  29. Remote Door Lock Fob ?
  30. oil pressure switch failures 2000 Regal GS
  31. Using Traction Control ?
  32. 02Buick Regal 3800
  33. 99 regal door lock relay location?
  34. smoking 97 regal gs /stalling.
  35. Tensioner Pulley meaning
  36. 97 Regal-how to clear Change Oil soon light
  37. Wheel Bearings
  38. How to take side mirror apart
  39. 2002 Coolant Leak... bypass hose to blame?
  40. ABS light comes on but no codes
  41. 99 Regal jacking points
  42. 3800 series 2 engine swap 97 LS
  43. 1999 Regal starting issue
  44. 2001 Regal stalling
  45. Heater Fan Stays Running
  46. Help!
  47. 3800 engine failure? 97 LS Regal
  48. Upper Intake Gasket
  49. Dual Zone climate contol issue
  50. Fog Light Bulbs
  51. 98 Regal plug wires
  52. 92 Buick odometer question
  53. Odd Power window problem
  54. 1996 buick regal gransport 3.8L
  55. Fuel pump
  56. Chime Module for 93 Regal
  57. Monsoon Stereo Problem, '02 Regal
  58. tire or rotor?
  59. Major power loss! Engine code P1639
  60. '91 regal wont start
  61. '01 Regal- Replaced ignition cylinder but still wont crank from time to time
  62. Headlight ground wire
  63. '90 regal stalls cold/hot while idling and driving
  64. 1998 regal cooling fans don't work
  65. Headlight not working
  66. Cylinder has only half compression
  67. 2001 Regal passenger mirror
  68. Best place to buy a Regal Window Regulator
  69. Front license plate holder 98 Regal
  70. 90 Regal Alignment
  71. Recommended spark plugs for 98 Regal
  72. ABS/Low Traction Issue 1996 Buick Regal Gran Sport
  73. 97 LS -noisy A/C Compressor
  74. where to buy lower intake gasket ?
  75. 1999 buick regal gs engine swap to na??
  76. TCC Problem 92 regal GS 3.8
  77. Antifreeze smell out exhaust
  78. 1991 regal
  79. Another P0404 and P1404 Code
  80. 2000 Buick Regal LS-vibrations
  81. 1998 Regal Gs battery light and tranny whine after new tranny
  82. abs light
  83. Guys that for error 35, and then can not find anywhere else Buick Regel Limited 91,
  84. 1999 Buick Regal Ignition Switch Replacement
  85. Steering Wheel shakes when I brake
  86. 2002 Buick Regal remote control door lock receiver
  87. wheel bearings
  88. Where to buy a 91' 3.8L replacement washer fluid reservoir tank?
  89. 89 locks/trunk opens when others activate their remotes
  90. Tire Size for 5 slot 16" OEM alloy wheel???
  91. Lound Humming sound from rear..
  92. Noise muffler-but new
  93. quiet tires
  94. ignition switch---2000 buick regal
  95. Car won't start when it rains
  96. Code P0171 system lean
  97. 99 Regal antilock break light on, left signal kills engine
  98. 92 Buick GS stalls with low fuel light comes on
  99. 1999 Buick Regal LS will not start
  100. 1999 Regal GS Blinker and DRL will not operate
  101. 2001 buick Regal ls 3800 series 2
  102. Paint Code ?
  103. air cond.
  104. starter maybe
  105. 1995 3.8 Regal. Died now it won't start!!
  106. 94 regal gs 3.8 engine knocking
  107. 2000 Regal-anitlock brake lights on
  108. over charged refrigerant
  109. rear brake light comes on
  110. 98 Regal GS headlights and fog lights stop working *PLEASE READ*
  111. turning up air/heat knob too high! 97 LS Regal
  112. Windshield Wipers
  113. window trim rusty??? CHECK OUT THE PICTURES
  114. 1999 Buick Regal Electronic HVAC Unit Problem
  115. Hello everyone, I have a machine Buick Regal Limited 3.1 1991
  116. '90 buick regal ignition starting issue.... weird problem
  117. Suspension/Strut 91 3800 V6 vin L 98K
  118. My 2000 Buick Regal LS Issues Thread..
  119. 00 buick regal gs stalling
  120. O2 sensor question
  121. 03 trunk release problem
  122. 91 3800 vin L-Power Window Issues
  123. 2000 Buick Regal Help needed
  124. 97 LS Regal-Change Oil Soon light on!
  125. 98 Buick Regal
  126. ignition short
  127. 1998 Regal GS will start but dies/ stalls after 30 min of driving
  128. Regal with sensor problem
  129. 1995 Regal Brake Light
  130. Valve Cover Gasket
  131. 1995 Regal GS with the typical transmission issues
  132. Ignition switch problem
  133. 1996 Regal Master Power Window Switch
  134. poor fuel economy
  135. 1988 Buick Regal
  136. No key return & immobolizer
  137. 3.8 LS Fuel pump test
  138. 02 Buick Regal v6
  139. 92 Buick Regal - Error Code 41
  140. Rusty Light Sockets
  141. '00 Regal LS No Climate Control AT ALL!!!!
  142. '98 Regal.... no oil pressure after changed oil
  143. 94 Regal, ABS, ground issue?
  144. 93 Regal electrical problem
  145. locked up 84 regal
  146. 02 GS fuel tank?
  147. '93 TCC issue
  148. 97 Regal alignment question
  149. 99 Regal LS stalled now won't start
  150. 02 Regal LS, dies when turn signals used.
  151. Fuel Filter Location
  152. 200 buick regal ls
  153. Flashing dash lights, but engine starts
  154. Windshield wiper size? 97 LS Regal
  155. 99 regal gs strange window problem
  156. Problems, just bought the car after flipping my truck
  157. Lights out
  158. 2001 Buick Regal horn problem
  159. Getting some gas out of my fuel tank
  160. 98 GS-Fuel Pump or Resistor
  161. 94 regal GS stalling, oil gauge bouncing
  162. Sluggish Transmission
  163. Gran Regal starting problems, oil pressure
  164. 2001 regal strange sound
  165. '93 Regal TPS problem
  166. 97 Regal LS- howling steering!
  167. Strange electrical problems
  168. 92 Regal blown fuel/ECM 20 amp fuse
  169. Driver side dimming heated mirror problem
  170. 94 regal starts then dies??
  171. Horn or no horn
  172. Bad MAF Symptoms 98 Regal GS
  173. 1991 Regal Custom- Possible Fuel Pump Problem
  174. 98 Regal GS Dash Lights not working
  175. Power window issue...need electircal advice
  176. 1998 Buick Regal Won't Start Help!
  177. Fuse for Third Brake Light
  178. 1995 Buick Regal Smokin Hot!!!!
  179. 1998 Buick Regal Losing Coolant
  180. 02 GS squeaking driving me nuts, HELP
  181. Anybody have a scanner?
  182. HVAC Calibration, 2000 Buick Regal
  183. 1999 regal door side mirror problem
  184. 84 regal t-type backfiring in BRAND NEW turbo
  185. water leak
  186. HVAC control problems
  187. trunk issues
  188. 97 buick regal ignition problem
  189. 94 Regal GS-lots of issues
  190. Service Vehicle, Anti Lock, and Trax lights coming on.
  191. 2000 Buick Regal Driver info issues
  192. 2000 Buick Regal GS heater stops at highway speeds
  193. Door Handle Broke
  194. fuel pressure 01 regal
  195. 2000 regal shocks
  196. 1995 Buick Regal 3100 motor
  197. 1999 Regal Outside Temp
  198. Low coolant indicator 00' Regal Ls 139K
  199. Sway Bar package for 00' regal Ls and front end vibrations.
  200. HVAC Trim Panel
  201. 2000 Regal ABS Connector
  202. Replacing the ignition switch
  203. 1995 buick regal no electrical power
  204. No Driver side heat: HVAC climate control
  205. Wheel Stud
  206. upper heater hose..dealer only?
  207. Dash Lights unique Problem
  208. steering recall?
  209. 92 Regal Heater Blower Fan
  210. '02 Regal starting issue
  211. 93 Regal: Engine won't shut off, ignition switch turns freely
  212. 2000 LS NO POWER TO AC/HEAT controller
  213. 1990 Regal 3.1L gives high idle cold or hot ONLY during initial startup!!
  214. 2002 fuel injector leaking
  215. 99 buick regal GS
  216. Anti lock brake light
  217. Fuel Info Display (MPG, Range) Reset
  218. 97 GS, Fuel Pump Not Running
  219. Another stalling problem (95 GS)
  220. 2000 Regal GS Heater Core Replacement
  221. Climate Control acting weird
  222. rusted frame
  223. Holy Crap!!!
  224. Head gasket replacement video
  225. Regal Rims
  226. 98 regal starts then dies
  227. 02 Buick Regal won't turn over
  228. headlight help please
  229. 02 Regal GS Vibration
  230. Help for 96 Regal GS
  231. headlights what happened ?
  232. idler pulley
  233. 91 Buick Regal Problems
  234. 92 Regal 3.8L Starting Problem
  235. LSE power rack leaking again
  236. Headlight Woes
  237. 01 Regal wipers
  238. waterpump or gasket ?
  239. 2003 Regal tranny
  240. 1994 Regal Custom 2dr Fuse Diagram
  241. 1991 regal gs
  242. 2000 buick regal ls wont start
  243. Engine misses after TC lockup
  244. Vehicle Speed Sensor
  245. Door handle
  246. Oil pan gasket replacement
  247. Problems
  248. Doors won't unlock
  249. Electrical problems with my 96 regal
  250. help with coil packs
