View Full Version : Regal
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. 98 Regal Supercharger whinning noise
  2. knocking in the steering
  3. 91 regal gs radio fuzz
  4. Shift Control Cable
  5. 1997-2004 Buick Regal GS Hard to find used?
  6. '95 regal will start most of the time, but not always.
  7. HELP !!! No light on DASH BOARD Buick Regal 1999
  8. Hub replacement...New axle too?
  9. Is my 95 Buick Regal a "W" body?
  10. 89 Regal sounds like a lawn mower
  11. Detailed pics or specs 1992?
  12. Going to drive it off a CLIFF
  13. No Heat! on drivers side
  14. oil pressure sending unit
  15. 93 Regal Problem Starting
  16. 2000 regal radio removal
  17. Vaccum Problems On an 89 3.1L Gs
  18. Gas gauage is not working
  19. Helllllp!!!
  20. Ignition Switch Replacement Help
  21. 2000 Regal GS w/Supercharger Possible ABS Issue?
  22. 1991 regal problem
  23. 1996 buick regal occasionally will not turn over
  24. HELP me make a decision!!!
  25. 1991 Buick Regal Limited
  26. 92 Ragal GS Code 42
  27. 93 regal electrical and idle problems
  28. 99 Regal GS Struts
  29. Regal transmission question
  30. oil pressure gauge problem
  31. Shorty duals
  32. Electrical problems REPLY ASAP
  33. Wheel wells on an 86 REGAL
  34. 1996-2001 Regal's,Any chronic problems ?
  35. Regal 93 rear strut tool help!
  36. 1994 Buick Regal GS
  37. 3.1L v6 code 33 fast idle. any suggestions?
  38. 84 Buick T-type Electrical
  39. 2001 - 2002 Buick Regal Special Policy on Warranty Coverage of CAT Convertor
  40. small gas tank
  41. SKirts on an 86 REGAL
  42. Blown Speakers - New Ones?
  43. Rubber Rear Auxiliary Spring - '95 Grand Sport
  44. 1996- Radio/AC control lights burnt
  45. 2001 buick regal wire short between PCM and DIS
  46. 1994 buick regal brake light problem
  47. Hard turning and clunks
  48. ignition switch for 2000 regal
  49. regal monsoon speakers
  50. 2000 regal starter?
  51. what is this button?
  52. Fuel Gauge not registering correct level
  53. 81 Regal underhood wiring
  54. 1996 Buick Regal - both horns stuck on
  55. 95 Buick Regal GS
  56. Transmission fluid leaking through vent hole
  57. Replacing fuel injectors, plugs and wires
  58. 1999 Regal GS Transmission trouble
  59. 94 Regal 3.8 Stutters
  60. turn signal switch
  61. 1999 regal problems
  62. 97 Gs - Power Steering Leak???
  63. DUALS on a 84 regal
  64. Brake light troubleshooting
  65. air condition
  66. 91 regal custom missing?
  67. 94 Regal takes long to start, struggles when gassed
  68. 2000 Regal right rear caliper sticking
  69. 1995 regal, died need help.
  70. '92 buick regal keyless entry
  71. 2002 Regal fog light button
  72. 98 Buick Regel troubles with starting
  73. RIP 09/06/2005 My Buick Regal
  74. 2002 Regal "blowing out" oil
  75. Cooling fan Troubleshoot
  76. Re: 92 Regal Power Door Locks
  77. How the hell do i get to the rear spark plugs
  78. radiator drain plug location on 2000 Regal
  79. Hmmm...
  80. Buick 98 weird problems...
  81. where is external temperature sensor?
  82. code 43 Knock sensor or Mem-cal chip?
  83. need help
  84. 98 GS couple???'s
  85. 92 3.8 engine assembly question...
  86. 90 Buic Custom Chronic Tranny leak
  87. need help setting radio
  88. Help w/radio station settings
  89. Left turn on, car dies
  90. Driver Window Power Switch wont work
  91. Let's play "Name that part"
  92. Drivers window stuck down
  93. Car sometimes won't start, must wait 40 mins.
  94. gas gauge problem
  95. gas gauge problem
  96. I think i have a record?
  97. 93 GS top speed 3.8L?
  98. 1996 buick regal wont turn over
  99. '92 Regal GS Oil Pump Replacement
  100. Installing an aftermarket stereo in a 92 Regal
  101. 1993 Buick GS Motor Mounts
  102. 89 REGAL GS TEMP STUCK ON "WARMISH"
  103. 3800 Engine Removal - Tips/Comments?
  104. 3.8L Codes
  105. 2000 Regal climate control LED lights
  106. '92' stalling and speedometer reads 0
  107. keyless entry module for 1995 regal
  108. alternator??
  109. battery or alternator?
  110. 91 buick Regal Headlight indicator problem
  111. AC suddenly Blowing Hot air
  112. Only blowing out air on side vents
  113. 3800 Engine Problems
  114. keyless remote 1989 Buick Regal
  115. 94 regal chip needed
  116. Trip Odometer
  117. Replacing the column switch (91 Regal)
  118. how to switch out a pulley
  119. Low coolant light flashes
  120. Head or head gasket..anyway to preserve?
  121. Rear Brakes
  122. Rear end squeak
  123. 96 Buick - HELP!!!!!
  124. 2003 Buick Regal - shifter park brake interlock
  125. oil life
  126. codes ask for mass air flow sensor
  127. Need help with an OLD's Cutlass
  128. my 1990 3.1 lumina died on road
  129. Window Tracks, Is There A Better Way?
  130. 98 Buick Regal--Blower Motor Help!!!
  131. 1996 REGAL GS fuel filter?
  132. 1985 regal - rattling noise
  133. 92 Regal - idles - kills on throttle and when put in gear
  134. engine mount trouble
  135. What tires are best?
  136. 98 Regal GS Horn Relay Location
  137. Hard Staring when Hot (Buick Regal 1996)
  138. Buick Regal 78-84?
  139. 98 GS S/C perf.shift and trac control
  140. 2000 regal climate control display
  141. Car runs "heavy" when A/C is on
  142. Service Vehicle Soon/Anti-Lock/Trac Off
  143. (ABS) & Brake lights keep coming on... suggestions
  144. Figured out the part number, can't find part
  145. 1993 Buick Regal Custom help
  146. Antifreeze smell
  147. New to Buicks
  148. 92 regal 3.1 dies after 20 min
  149. 1992 regal custom dashlights
  150. Help... 96 Regal Dashboard Darkness! Grrrrrrr!
  151. 1992 buick regal custom...IN HELP BAD!
  152. 98 GS spoiler brake light
  153. Fuel pump resistor-do I need a new one?
  154. A/C Compressor Not Getting Power
  155. Help! Dash Light Blinking Crazy
  156. '98 Buick Regal Window motor
  157. Rear Brake Calipers, Why do they Suck? Still!!
  158. Pcv Valve 2000 Buick Regal Ls 3800 Series Ii
  159. 1987 buick somerset
  160. 2000 regal gse
  161. Doors unlocking in Park
  162. 1992 Regal Stalling out in heat
  163. 90 Buick Limited Runs Rough
  164. 98 Regal brake rotor warped?
  165. Struts for a 91 buick custom
  166. e--brake cable
  167. Power Window Problem
  168. 94 Regal Power Locks Short
  169. 99 Buick Regal Hard Shifting
  170. DIC or DID
  171. Replacing the Radio in a 1992 Regal
  172. Ignition Troubles!
  173. 1998 Regal Climate Control
  174. Water in passenger footwell
  175. Stall,spit,sputter,die,REPEAT
  176. Will a Monsoon head unit work w/out the trunk amp?
  177. 93 Buick Regal Custom keyless receiver
  178. Regal to a clone?
  179. Need to replace part, don't know what it is
  180. service engine light??
  181. 1994 Regal, Misses, getting worse
  182. 91 buick regal; check engine engine light?
  183. Programming Remote
  184. 94 regal horn switch
  185. 89' regal custom GS 3.1 rating and hints
  186. 98 Regal problems
  187. A/C fan only works on High
  188. Regal Repair RipOff
  189. wrong tranny installed?
  190. 92 Regal Cooling System Flush & Fill Procedures
  191. help i need a diagram
  192. EGR valve - do I have one??
  193. so called security chips
  194. proceedure to remove rear view mirrror
  195. 1991 Buick Regal Horn
  196. 1994 Regal - Getting to the 4" dash speakers
  197. Your Opinion of the 2.8L V6
  198. '92 Custom has a problem starting
  199. '96 Regal AC condensation drain
  200. location of EGR valve 1991 buick Regal
  201. Peice of Scheiss Stereo
  202. 96 regal stereo
  203. cant get signals to work right
  204. low pressure A/C port
  205. Problems with VENT setting.
  206. Ignition problems
  207. Brake Light Problem
  208. LOW TIRE pressure indicator?
  209. 97 Regal-radiator drain plug
  210. 1992 Gran Sport -- Driver's side window
  211. '91 Custom v6 3.8l Battery Drain?
  212. Poor milage in 01 buick regal LS
  213. Disconnecting automatic door locks
  214. 1994 Regal Tranny Shift Problem
  215. Dashboard
  216. check guages light
  217. 97 Regal AC HELP! Please!
  218. dash lights gone crazy
  219. low coolant light blinks on/off
  220. 1991 Regal stereo
  221. 95 stalling problems
  222. '91 buick regal radio question
  223. '98 buick regal a/c
  224. Torque Specs
  225. 97 Regal fan motor in/op- repaired
  226. Object behind glove box
  227. code 63 1988 2.8 Regal?????
  228. Loud noises when pressing gas 1991 Buick Regal
  229. 88 regal 2.8 engine making noise Help
  230. 91 Buick Regal ECM
  231. 98 Buick Regal GS won't start
  232. Need Help !!!!! Please
  233. A Big Thanks...specifically "malimag99"
  234. 98 Buick Regal Will Not Start
  235. '91 Regal Firewall Grommet
  236. Monsoon Rear Deck Speaker Options for 99 GS?
  237. Turbocharger or Supecharger
  238. Question about accessing fuel pump area
  239. 96 regal custom 3800 series ii
  240. 1995 Regal stalls intermittently when in drive/reverse; hard to restart
  241. Squeal/ squeak
  242. on my cluster ..what is it?
  243. How to make my Buick 78' 350 faster
  244. Remove Drivers Power Seat- 93 Regal
  245. 1998 Buick Regal GS ABS Control Module
  246. Knock Sensor?
  247. Making new dashboard
  248. 87 Buick Electra Park Ave
  249. How to move steering
  250. How many miles or kilometers on your Regal?
