View Full Version : Regal
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12
  1. Electrical Problem / Car Dies and Vent Turns on
  2. getting water under passenger side carpet
  3. 99 regal wont start
  4. Removing Starter
  5. Exaust leak in 87 Regal
  6. 1998 Regal GS Anti Lock Brake warning lights
  7. 1980 fuses
  8. 99 buick regal starting problems
  9. When heater is turned on!!!!!
  10. 94 Regal 3100 TCC solenoid location ??
  11. 1988 buick regal cooling fan relay location
  12. 1991 Regal 2-door
  13. changing rear struts on a 92
  14. Climate control knobs..Regal
  15. 1996 Regal 3.8 Fan Trouble
  16. 94Regal Problem Starting - BRAKES?
  17. No acceleration
  18. 1996 Regal Custom keyless Issue
  19. 89 Regal power steering problems
  20. Parked Regal
  21. Performance Recomendations For 97's
  22. Harsh Shifting???
  23. Turn Signal kills engine. aargh!
  24. Factory Radio
  25. Cannot open door from the outside. Inside works.
  26. Power locks won't work
  27. 99GS won't run help!!!!!
  28. how does DEX-COOL look towards the end of it's life?
  29. CD Changer For a '99 Regal GS to fit factory stereo
  30. what is this wire?
  31. WHat's that light called? (86 Regal)
  32. Regal - 1994 - Should I buy?
  33. 88 regal dead
  34. 2001 Tcs
  35. 91 Regal electrical panel
  36. Buick coolant recall
  37. dash questions
  38. Engine oil level
  39. remote door locks/trunk
  40. replacing cracked mirror glass only for side of 2000 regal
  41. Regal Question
  42. 88 Regal
  43. 2001 tranny input output sensor
  44. 96 regal bucks between 45-50 mph
  45. 91 Regal has been sitting for a year+
  46. 91 regal won't start
  47. My 86 regal wont burn out!!
  48. 86 regal with ticking engine
  49. 1991 Regal fuel filter?
  50. 88 regal keeps dieing
  51. 1991 buick regal won't start
  52. Anyone got a headlight wiring diagram?
  53. power window problem
  54. Buick 455 Regal
  55. 89 regal limited with grond effects
  56. Can't locate turn signal flasher in my 1994 Regal
  57. 01 trans, etc.
  58. 92 regal 3.8?
  59. 92 regal bouncy ball fallen into air vent
  60. Need help: Vent shuts down while driving (96 Regal)
  61. having problems with 1993 regal gran sport
  62. Sideview Mirror
  63. 91 Regal won't start. PLZ HELP!!!!!
  64. fuel pump won't cut off
  65. 95 Regal quit today - ADVICE??? SUGGESTIONS????
  66. car cuts out while driving!! HELP!!
  67. Bad torque converter???
  68. 96 regal knocking engine
  69. 1995 Regal GS Dead Battery
  70. How do I remove the dash????
  71. 1989 Regal LE 2.8 Crankshaft Sensor Troubles
  72. 87 Buick Regal T Type Exhaust Manifold
  73. Car repair Cost Canada
  74. P0336 code 99 GS
  75. MAP Sensor
  76. Stolen Car
  77. bolt pattern and size
  78. buick glow gauges
  79. 1996 Buick rides like a truck
  80. '99 OE struts
  81. 95 buick regal running rough Please help
  82. 92 Regal Problem with the radio volume
  83. Installing new head unit help?
  84. Help With Strange Headlight Switch Issue
  85. Transmission matching
  86. tires for a 98 Regal GS
  87. '99 450clicks per tank...something needs to get cleaned?
  88. Anyone else own a 86 Regal limited?
  89. ABS Warning Light
  90. 86 Regal Limited poor gas miliage
  91. 91' Won't Restart
  92. Anti-Lock brake knocking
  93. intro/headlight problem on 83 Regal
  94. 97 regal serious electrical!!!
  95. Rad Fans
  96. 98 Buick down and out!
  97. 93 Regal GS CD Player?
  98. help car wont stay runing
  99. 3800 Series I needs Alternator:
  100. Black Smoke, STalling, hard to start....
  101. Electrical Issues:
  102. 1996 regal service engine light
  103. Smoke under hood
  104. Ran Out Of Gas wont start now
  105. 1991 buick regal odometer malfunctioning
  106. 2000 Regal Trunk gas lift struts
  107. 1983 brakes dont work properly
  108. assuming transmission going out on 93'
  109. 92 Gran Sport -- Speedometer/Tach problem
  110. loosing coolant into the oil 1995 buick regal
  111. car dies when shifting between gears
  112. 98 GS - starts but won't run
  113. '91 buick regal 3.8 custom
  114. Brake Shimmy
  115. 2000 regal ABS codes
  116. 1993 Regal custom Tranny problem
  117. 92 Regal blower motor only works on the highest setting
  118. Regal Fuel pressure
  119. Paint chipping off 97 regal
  120. 98 Regal LS Shudder and jerking!
  121. 92 Buick Regal replacing power steering pump
  122. Supercharger Rattle
  123. 93 Regal Warning Lights
  124. Car Wont Start
  125. 2000 Buick Regal computer
  126. 1992 Buick Regal- No electrical!
  127. 1993-1995(?) Regal Limited
  128. 98 Regal Tensioner
  129. GS vs GSE?
  130. Dependable,mid-sized,4 door,RWD car
  131. Any significant differences between 3.1L engine and 3100cc engine
  132. 1994 regal oil pan removal
  133. 92 Regal 3880 oil filter
  134. 1988 regal odometer failure
  135. 99 Regal with 3800 Dies while in Park; Then won't start!
  136. 94 Regal Tail Light
  137. 98 Buick Regal Heater Control problem
  138. New manifold, new sound
  139. crankpositionsensor location
  140. Fuel Pump Resistor
  141. 99 110,000km service check
  142. 91 regal turns but doesnot start
  143. 1999 regal automatic transmission-overdrive problem
  144. location of oil sender switch
  145. 99 Regal HVAC problems
  146. Fuel pump stays on
  147. 98 regal gs
  148. Need Advice-'96 Regal
  149. catalytic
  150. 1995 Regal Tranny Problem
  151. 99 Regal Steering Problem
  152. 92 Regal Trans modulator
  153. Regal engine rotation & other questions
  154. Problems starting 90 Buick after car is warm
  155. Intercooling an 85 Grand National...
  156. Many Thanks
  157. Sick Buick Lover, Regal owner
  158. 2000 Buick Regal idles rough, 3rd cylinder misfires
  159. 89 regal heat problems
  160. 2 Door vs. 4 Door
  161. 95 Regal - Security Light Staying On
  162. 99-01 Buick Regal Wanted
  163. '88 regal cruise control
  164. Leaking water
  165. Mr. Freeze Locks
  166. 1978 regal wiring diagram
  167. 94 regal, Interior dash lights
  168. 4T60E Transmission
  169. 2000 Buick Regal Windshield Washer Pump
  170. New plugs, now car shudders
  171. 98 Rear wheel bearings
  172. 1996 Buick Regal
  173. Headrest removal
  174. 94 Regal "All the sudden" Problem
  175. 1988 Regal Suggestions??
  176. 88 Regal Idle Jump/Sputter/Jump/Sputter
  177. 95 leaking something yellow
  178. day time light
  179. 98 Regal engine runs fine; can't get into gear
  180. gas gauge
  181. A 17 year old girl driving a regal??????
  182. 94 Regal Custom power steering help
  183. electrical problems?
  184. new batteries die very quickly NOT ALTERNATOR
  185. '94 ball joints/wheel bearings
  186. whine noise 94 regal
  187. '93 Regal Keyless Program
  188. 1991 Buick Regal Limited 3.8litre Supercharge
  189. Lost Keys
  190. cd changer installation
  191. Neutral Switch
  192. '95 Regal Column Shift
  193. buick tranny problem
  194. 95 Regal GS
  195. Starts but shuts off within five seconds.
  196. 1995 regal warning light problem
  197. Dead battery & ABS light on
  198. Help Me
  199. FYI - Security blinking - No Start info
  200. Cold air intake
  201. Coolant IN Exhaust
  202. 96 Buick Regal Custom "low trac" warning light
  203. check engiine light
  204. Line going to carb, pinhole leak..
  205. 1998 buick regal GS (suprecharged) wont start
  206. 1982 buick regal need to get the heater working again in the car
  207. Aftermarket parts
  208. Qdm????
  209. 3800 coolent and ATF
  210. 95 Buick Regal
  211. 1992 Regal- Cd player install.
  212. 98 regal Intemittent runs rough and dies when warm
  213. 1990 Regal GS
  214. 1978 Regal
  215. Buick regal 1993 - no startup at all
  216. Heater fan making awfull noise
  217. 1986 Buick Regal For sale 6850 miles!!!
  218. 96 Regal heatless heater
  219. 2000 Regal - CD changer socket?!
  220. OIL FILTER/ Trac control 95 regal
  221. special keys
  222. 98 GS constant Stalling
  223. 1991 Regal Parking Brake
  224. 93 Regal 3.1 Stalls when warmed up
  225. sparkplug
  226. 2000 Buick Regal Transmission
  227. Rear Brake calipers on a 1996 Buick Regal
  228. low fuel light
  229. Transmission wont shift into second!!
  230. 1993 Buick Regal Remote
  231. '91 buick regal....No start?
  232. 1998 Buick Regal oil pan removal
  233. How to get to the battery - 93' Regal
  234. coolant level
  235. 1984 Buick Regal Grill
  236. no spark
  237. My wife doesn't know
  238. 81 Stereo Diagram
  239. Hood Release Cable
  240. 1996 GS supercharged won't run
  241. 1991 Regal 3.8 ran great-stalled, ran great-stalled, don't run
  242. sensor for anti lock brakes 93 buick regal
  243. '96 Buick Regal in an Accident!
  244. Chocolate milk in oil
  245. 78 Regal Reverse Lights
  246. 93 3.1 troubleshoot
  247. 96 Regal Head Unit w/ CD player
  248. 1983 regal 3.8 oil problem
  249. 1999 Buick Regal won't start...
  250. 97.5 Regal Interior Vent fan off
