not firing on all cylinders.. my car either....
bmowery
05-02-2009, 09:01 AM
92 sc DOHC center two cylinders... replaced the coil that wasnt firing.. didnt resolve the issue. i know its that one because with out the plug wires connected there it doesnt spark. i checked ALL my fuses... but randomly it will start up and fire great but within 5 minutes goes to not firing... i was messsing with it one day pulled a wire off electricuted myself... then it worked for a week flawlessly! already replaced my ects too...also no check engine light i know the bulb works i just replaced it.. any ideas??
Cat Fuzz
05-02-2009, 03:47 PM
Remove the coils and module and clean the pad underneath the module and on the transmission. This is where it gets it's ground.
bmowery
05-06-2009, 12:00 PM
Update... Took off both coils and switched them.. Working fine for two days do far..
Eagle70ss
05-07-2009, 12:27 AM
If you have further problems, suspect the Crankshaft Position Sensor. My 97 was doing almost the same things once.
bmowery
05-25-2009, 03:43 PM
so. replaced my CPS, still not firing. all my fuses are good. still crap.
bmowery
06-10-2009, 08:57 PM
so still no go on all 4 cylinders.... bad pcm? it came unplugged somehow.. plugged it back in and car ran great for 5 minutes.,.. but now when car is off sometimes clicks and my left trun signal blinks with the clicking...
bmowery
06-15-2009, 09:33 PM
so maybe its not my pcm that i unplugged.. what type of computer module is on the drivers side of the center console that controls some of my electronics??
