96 SL1 Over-Revs at Start
stb100
05-04-2009, 10:06 AM
Thanks in advance.
My daughter's '96 SL1 does this often (not always) at a cold start.
Starts fine and idles up to at least 2k RPM. Stays there till it warms up a bit I guess. Sometimes RPM can be lowered with a quick stomp on the gas (not always). Normal idle is 600-800 RPM (?)
ANY ideas about how to fix?
Steve
Steve
RC1488
05-04-2009, 09:08 PM
Clean your throttle body.
Replace the ECTS. Ive posted a video for this around here somewhere.
Then if problem persists:
During a high idle, shut the car off then back on. See if the idle returns to normal. A cold start idle is around 1100-1200. If it does, this indicates an issue with the TPS.
stb100
05-15-2009, 11:22 AM
Thanks. Haven't diassembled it but shot it w/a carb cleaner.
Hasn't happened again...so far.
RC1488
05-15-2009, 11:29 AM
Take it off and clean it. Dont be lazy!!:iceslolan
saturntech
05-19-2009, 08:22 PM
If cleaning the throttle body doesn't work, it could be a bad Iac motor, it doesn't necessarily mean its the ect sensor, maybe check the ect sensor to see if its the old ceramic 1 or if its cracked. The only real way of deeming the etc and the Iac is with a scan tool making sure that the parameters are within range.
shark7000
07-31-2009, 05:08 AM
I just got a 97 SL1 and it dose this too. When it warms up, the RPM's go to normal, but when I go to shift gears, the RPM's go up about 2-3k, then it slowly teturns to normal. It will go up, eventhough my foot is off the gas peddle. I will try the cleaning the throttle body to see if that works. I even have one out back to put on that looks cleaner already. Its from when I rebuilt my 92 SC2 engine, I used an SL1 for the bottom end, so I still have the block, head and intake for the SL1 just sitting around.
RC1488
07-31-2009, 07:37 AM
While your under there, replace the ECTS with a brass one. Also check the intake manifold gasket. Spray it with brake cleaner with the car on and listen for idle changes
saturntech
07-31-2009, 12:46 PM
If its not the intake, its IAC motor.
shark7000
07-31-2009, 09:09 PM
Just happens that the spare parts out back had the IAC still on it. I replaced that and it works normal again. At first, the engine almost slalled a few times, I guess the computer was learning the new inpute readings. After a test drive, it works normal now.
saturntech
08-01-2009, 08:51 AM
Yeah, they can be a real pain to learn sometimes, expecialy when they are new, they rev really high for a long time. Good to hear its fixed :biggrin:
