95 SL2 Transmission won't engage
rksand
04-29-2009, 09:09 PM
Auto transmission started whining today. Drove it home, now it will not engage. Added 1 quart of fluid, no change. Will engage immediately after starting engine, then starts whining and will not move. Any ideas?
Thanks!!
Thanks!!
RC1488
04-30-2009, 08:40 AM
last time for fluid and filter change?
Miles on the car?
Reverse slam before this?
Miles on the car?
rksand
04-30-2009, 11:28 PM
146,000 miles. Records show transmission was overhauled at 115,000. I bought the car from my sister at 130,000. Fluid has not been changed since overhaul. No slams. Has shifted great until yesterday!
RC1488
05-01-2009, 11:32 AM
Is there any tranny (red) fluid leaking from the tranny? Especially the bell housing. Im leaning towards a busted differential pin.
All gears the same?
Any codes ? (SES LIght on?)
ECTS Replaced with a brass one? Your car has two, you need to replace the one with the two-wire connector.
All gears the same?
rksand
05-01-2009, 10:30 PM
There is some fluid leaking. Replaced ects last month. No lights showing. All gears the same. My mechanic told me today the trans was toast. Guess I will go ahead and overhaul it. Hate to spend that kind of money!:mad:
RC1488
05-02-2009, 02:32 AM
Check the differential pin. Ive posted the video to check it thru the VSS. I think yours busted a hole in the tranny.
Get a tranny from the junk yard. '93-'97 MP& will work no issues
